Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
Passport external hard drive
My wife unplugged and dropped the hard drive. i can hear it running but pc wont recognize it and it does not light up.thx
  • 108 Answers
Your Hard Disk is crashed. Better you change and get another one.
Posted on Feb 09, 2008
Cant see my passport external drive on new windows 8 laptop
Try unplugging from usb and plugging it back in. Also, you may need a SAS driver for your computer to recognize the drive. Some drives have internal encryption and require a driver before the computer recognizes them. Check the Mfg website to see whether this drive requires one.
Jan 03, 2014 | Western Digital 1TB My Passport Essential...
PC will not recognize the external harddrive passport. PC has been rebooted and passport has been unplugged and replugged to get PC to try and recognize passport. Light on the passport comes on, and the...
3 beeps its searching for a connected device
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps you
Sep 13, 2011 | Western Digital 1TB My Passport Essential...
My hard-disk is on-Warrenty basis.On hardisk light is blinking but unable to detect on pc ,So Please tell me the procedure how to recover my data. P/N-WDBAAA5000ABK-00 S/N-WXM1A80N4025N
Can you hear the drive spinning when you connect it to your computer? A spinning sound means your external drive is being powered by the USB from your computer - there are several reasons the drive is not being recognized.
If you are not hearing any spinning sound the drive could be damaged.
Does the drive get recognized by any another computer? If yes - check disk management and see if security is enabled on the drive. Also - check to see if there is a drive letter assigned to your external hard drive.
Link
Feb 28, 2011 | Western Digital WD Passport 250GB Portable...
Device is not recognized
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked. I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 22, 2010 | Western Digital Passport WDXMS2500TN 250...
I accidentally dropped my 350 GB WD Passport external hard drive and now my computer does not recognize it. Is it still repairable and can i recover the files stored there. Do you have a service center...
Try it another computer.
If it still fails, there are alot of online companies that will be able to retrieve the data for you- although Im guessing the drive its self will be unusable.
Sep 16, 2009 | Western Digital Passport WDXML800UE...
External Hard drive wont show files or name
Even though you may hear the motor turning in your external drive the drive may not be able to read the information on the platter(s) because the arm isn't working. This cannot be fixed; you'll have to buy another external drive.
There are services that can retrieve the data on the broken drive. Google "data recovery services" and prepare to spend big bucks.
Jul 09, 2009 | Western Digital Passport WDXML800UE...
USB ports on my laptop and others wont recognize my 320GB Passpor
we have to check in BIOS weather the "USB EMULATION" option is enabled or disabled.also if you have usb 1.0 and not usb 2.0 this external hdd will not be recognised.
Apr 24, 2009 | Western Digital Passport 320GB External...
WD Passport 250GB External cannot be recognized.
Go to BIOS (Press DEL or F2 to enter BIOS). Check if the Power state is in S1. Ensure that USB setting is in Hi-Speed.
Restart the computer and try using the device. this should fix. Let us know the result.
Thanx
Jan 16, 2009 | Western Digital Passport WDXML800UE...
Need help to locate Western Digital Passport 160GB External Drive
Could be a hard drive logic board issue since the computer bios recognizes the drive but the computer operating system does not. Not good.
Jun 25, 2017 | Western Digital Passport 160GB External...
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I have the 80GB WD passport and it suddenly stopped working one day.  The unit lights up but nothing else.  Finally I cracked the case open and found, as I suspected, that the drive is simply a SATA laptop drive with a SATA-to-USB conversion card built in.  I suspected that the card was **** so I disconnected it and used a USB hard drive adapter (http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3770&name=USB_Hard_Drive_Adapter) and I can read/write to the drive just fine.  Best part is that the adapter I use has its own power supply so I'm not pulling juice through the USB cable for a SATA drive.
Even though mine "works" again I don't recommend these drives to anyone.  They're just not sturdy enough or well designed.
Sep 09, 2008 | Western Digital Passport WDXML800UE...
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
64 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
