Broken TV My TV (an RCA 29" CRT) has stopped scanning and there is now a dazzling horizontal band of light across the entire width of the screen. Can it be fixed? In the good old days back in BT (Before Transistors) all that was required was to replace the vertical oscillator tube but I don't know which component to check in a newer set. Thanks, Doug
  • panaetius Feb 10, 2008
    Thanks for your help regarding the following i posted yesterday:
    The set is an RCA Model #F27668, The chassis # is CTC203AA and the Serial # is 034621278. Oh yes, and I'm mechanically deprived.
    Thanks,
    Dougl
  • Jaime Hernandez May 11, 2010
    Could you gives us abit more info, like the model and chassis number, that way we will be able to point you in the right direction.
  • 2,336 Answers
Download the service manual from the link below:
http://www.eserviceinfo.com/downloadsm/31473/RCA_CTC203.html
If you have a tuner like the one in the picture of the PDF file, more likely you will need to resolder all the grounds around the tuner shielding.
Good Luck.
Posted on Feb 11, 2008
  • 113 Answers
You have a failed vertical output Ic. It will be a 7-9 pin Ic on the board shouldnt be hard to find to replace. If you give all of the info for your tv we can get you the part number
Josh
Posted on Feb 09, 2008
What is Horizontal scan output fault? is HOT is faulty or other problem?
Horizontal scan is the scanning left to right on the screen to make up the width of the picture. The height of the picture works the same. This is not an easy thing to repair. You will have to find someone wit the experience to troubleshoot it.
sorry but hope this explains a little.
Jan 28, 2015 | Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
Rca 32 inch tv
this is a frame fault
the fact that you can still see the line when the tv is off is because you have been watching with the line and it has burnt into the crt.
time to buy a new tv
Sep 04, 2009 | Sanyo DS24205 24" TV
I need to find the pincushion circuit on my RCA F32632SB TV to check a problem with the TV displaying an hour glass picture. Where can I find a picture of this or a manual to guide me to the circuit?
The pincushion it intimately related to the horizontal circuits,the electron beam must travel farther to reach the corners of the crt and it does to the middle and so without pincushion circuits the raster would be bowed in on the sides on crts 27 inches are larger.Pincushion corrections straightens the raster by modulating the horizontal yoke current at a vertical rate.In an RCA tv the pincushion circuits are usually numbered 4800and the pin amp will probably be numbered 4801,its drive transistor should be Q4802,R4802 will be the width control,and R4805 the e/w pin amplitude. its inputs from the vertical should be Q4801 (subtractor) Q4803 (buffer) you should have a parabola waveform at 4801,yoke current can be modulated here without effecting high voltage.when Q4802 conducts voltage should decrease across Q4801 and the voltage drop across the yoke increases. The east west pin amp control 4805 controls how much of the vertical parabola is input to U4801 to compensate for changes in width caused by variations in beam current.By varying the e/w control resistor you can know if the circuit fault is in the input or output,if the picture varies in size the fault is in the input to U4801,if it does not vary check the output or U4801......hope that helps
Jan 15, 2009 | RCA F32632SB 32" TV
Thin horizontal line across the screen
you need to replace the electrolytic capacitor in the horizontal section of of your tv sets,cause the capacitor is weak.need to repair
Jan 11, 2009 | Sharp 27C-240 27" TV
RCA CRT TV thin white horizontal lines
Look for bad capacitors in the vertical deflection amp, and in the pin amp sections. This is common on most of these types of TV sets.
The caps tend to go high in ESR with age. It is best to use an ESR meter to find the bad caps. It will be a lot faster than workign out waveforms with a scope.
Wikipedia explanation about capacitor ESR:
http://en.wikipedia.org/wiki/Equivalent_series_resistance
Jerry G.
Apr 23, 2008 | Televison & Video
Standby light flashing
This is possibly a sign that there is a fault condition. Short circuit line output transistor
Jan 23, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
