Question about Averatec 3200 Notebook
My laptop's battery cannot charge
My laptop cannot be turned on without plugging. when i turned on my computer (ac power), total battery remaining is always 0%.
  • 2 more comments
  • lorenz08 Feb 09, 2008
    model name:E12K Li-ion
    i cannot see a level indicator...
    help pls...
  • Anonymous Mar 06, 2008
    I'm having the same problem: The laptop has to be plugged in to use it, if you unplug it, it will die in about 10 seconds. I bought a new battery but it did not fix the problem...?
  • Akhiker Mar 16, 2008
    My Averatec 3200 laptop has this problem. It seemed to suddenly stop charging. The Lithium - Ion battery (11.1V, 4.0Ah) will not charge. Always shows 3%. Coputer works fine when plugged in to adaptor.
    Doug.
  • ajb1029 May 19, 2009
    I have the same problem. The battery is still at 0% even when plugged in and the battery light indicator flashes green and orange.
  • 749 Answers
Check your battery if it is not dead, remove the battery and find a soft button near to a level indicator... pressing it will check if it lights less than one-half or none at all then the battery is dead... In that case, you need to change it with a new one.
Hope this Fixya the problem...
Posted on Feb 09, 2008
Power light flashing amber
Follow the steps given below. (Please be careful when handling computer electrical components like batteries and AC Adapters)
  • Remove the battery and hold down the power button for few seconds (to drain all remaining power)
  • Power up the computer without the battery with the A/C adapter plugged in.
  • Wait for few seconds and plug the battery back in
After a few tries the computer should start charging normally. The amber battery stops blinking and turn green when fully charged.
Feb 13, 2015 | Acer Aspire One Kav10 Netbook
NEW Battery not properly charging
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
Feb 16, 2012 | Gateway MD7818u Notebook
The initial battery of my Acer Travelmate 2480 packed up and I ordered and installed a new one. However, the laptop remains on "AC Only" power and the battery is not charged, giving a...
RTFM You can download the manual by googling "acer travelmate 2480 manual" (without the quotes). Or just click here
According to the Acer manual:
"Conditioning a new battery pack
Before you use a battery pack for the first time, there is a
"conditioning" process that you should follow:
1 Insert the new battery without turning the computer on.
2 Connect the AC adapter and fully charge the battery.
3 Disconnect the AC adapter.
4 Turn on the computer and operate using battery power.
5 Fully deplete the battery until the battery-low warning appears.
6 Reconnect the AC adapter and fully charge the battery again.
Follow these steps again until the battery has been charged and
discharged three times.
Use this conditioning process for all new batteries, or if a battery hasn't
been used for a long time. If the computer is to be stored for more
than two weeks, you are advised to remove the battery pack from the
unit.
Warning: Do not expose battery packs to temperatures below 0°C
(32°F) or above 60°C (140°F). Extreme temperatures may adversely
affect the battery pack.
By following the battery conditioning process you condition your
battery to accept the maximum possible charge. Failure to follow this
procedure will prevent you from obtaining the maximum battery
charge, and will also shorten the effective lifespan of the battery.
In addition, the useful lifespan of the battery is adversely affected by
the following usage patterns:
• Using the computer on constant AC power with the battery
inserted. If you want to use constant AC power, you are advised to
remove the battery pack after it is fully charged.
• Not discharging and recharging the battery to its extremes, as
described above.
• Frequent use; the more you use the battery, the faster it will reach
the end of its effective life. A standard computer battery has a life
span of about 500 charges."
Jun 16, 2011 | Acer TravelMate 2480 PC Notebook
Its that the battery is not charging, and on the power meter icon its blinking four times orange and one time green. If I remove the battery, the laptop works with ac adapter. but if I reinstall the...
Check for a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 06, 2011 | Dell Latitude D610 Notebook
My Acer 5315 will not charge I plug it up an nothing happens no charging light, or anything what do I need to do?!
Hello
Following could be the reasons for such failure:-
Computer AC/DC cable is bad not allowing the computer battery to charge
Verify that the AC/DC cable is not bad by removing the battery from the laptop and seeing if the computer can power on without the battery.
Battery is bad and/or old
If the power plug is good it's likely that your laptop battery is bad. If you're using a laptop with Microsoft Windows consider getting and installing BatteryCare on the computer to look at the total capacity of the battery.
Try leaving the laptop connected to the power with the battery inserted for at least two hours. If the battery still doesn't seem to charge, i suggest having the battery and/or the laptop serviced or repaired.
If the computer and/or battery is not in warranty we suggest replacing the battery as it's very likely that it is just a bad battery.
Battery charger board is bad
If the battery has been replaced or an alternate battery from an alternate identical laptop does not work in the computer, it is likely that the power or charger board within the laptop is bad. It's recommended that the laptop be sent in to be repaired.
Hope it helps, if so do rate the solution
Dec 24, 2010 | Acer Aspire 5315 Notebook
I have ac adapter plugged into the wall, and into the computer, the charge pack light is green, the battery is in the computer and the computer won't turn on at all
You probably have a bad or loose DC jack on the laptop:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
http://www.insidemylaptop.com/laptop-dc-power-jack-repair-techniques/
Nov 30, 2010 | Gateway SL1450-30145063 Notebook
I have dell c840. Suddenly only the left most light of the three lights gets orange when power is switched on and then there is no activity and screen remains blank. Bty light when plugged in also remain...
hello
shut down computer - unplug power cord from laptop - remove the battery from laptop - plug Ac adapter into computer and Ac outlet (wall)
turn on computer
if computer does not turn on, replace the AC adapter and cord - then place battery back into computer
plug in new Ac adapter and cord - recharge battery - if orange light stays on after 4-6 hours of charging battery, you need new battery as well - replace battery, charge it up and it should be fine
if you have attempted these steps before and no change occurs, then you may have issue with power connection in computer - locate a service centre to replace power connection on computer
Nov 07, 2010 | Dell Computers & Internet
Won't turn on. Battery is plugged in and lit. n
Try removing your battery pack. Then connect the power adaptor (even without the battery) and connect is directly to the power outlet. If it powers up, then the battery pack might be defective or totally drained.
If the battery is just totally drained, simply place the battery to the laptop. Do not turn the laptop on. Plug the power adaptor to the laptop and plug it to the power source. If you see that the charging LED is blinking in your laptop, then just leave it charging up to 5 to 8 hours.
Never use a laptop on battery mode while it is plugged in to a power source. This is the number 1 reason why laptop batteries don't last longer.
Jun 06, 2010 | Sony VAIO Notebook
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Laptop won't turn on
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Averatec 3200 Notebook Logo
282 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
General Systems...
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
