Question about Electrograph Systems DTS42PT 42 in. HDTV-Ready Plasma Television
Electrograph Plasma TV
I don't have the remote and when I try to use the keys on the front of the TV it says "front panel locking" and shows a padlock. I need to do a channel scan in order to use a cable DCT but I can't use the buttons on the TV.
  • 182 Answers
You could buy an all for one remote control. i bought the kameleon 6 for 1 and its very easy to programme. just put in one of the codes supplied in the book for the brand of tv you have, once youve put in right code there should be no problem setting up the tv. The best place ive seen for the kameleon remotes is ebay, very cheap compared to what i payed. hope this helps
Posted on Feb 09, 2008
Key lock on soniq plasma tv witout remote control
Unfortunately the key lock cannot be deactivated without a remote, for it will defeat the purpose of key-locking. You can order a replacement remote, you need to have the exact information of your TV's model/version ( the barcode on the back of the TV starts in REVxxxx).
Sep 28, 2012 | Televison & Video
Tip
Toshiba 50HP95 Front Panel Lock Reset
Toshiba 50HP95 Plasma TV Front Panel Lock Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV Front Panel Lock?
Have you forgotten your Front Panel Lock PIN, passcode or password?
If you forget your Front Panel Lock passcode, you can unlock the front panel without entering your password:
  • When your PIN is requested, simply press RECALL four times withing five seconds.
  • The Front Panel Lock passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
________________________________________
Download Toshiba 50HP95 Plasma TV Manual
on Jul 03, 2010 | Toshiba 50HP95 50 in. Plasma Television
I have a hitachi 50 "plasma that was given to me
First do you see a light indicating that the TV has power? There are two power buttons on the TV (the main power and the regular power button). The red standby light will light up when the main power switch is on. This indicator is just to the left of the remote I/R sensor. You can find the main switch on the bottom front of the tv (it is under the tv forward of the stand). Turn on the Main power if it is not on. Then try the power button on the control panel of the TV again.
Does the standby light change color or blink? (Red is standby, orange is power savings (no signal), blue is on.) If the main switch is on and the standby light doesn't come on, the TV has a problem at the power supply. Try unplugging the unit for a bit (at least 30 seconds) and then plugging it back in. This will reset the internal circuitry. If you see a blinking light, then the TV is reporting a self-test failure. I do not know the codes for this model Hitachi Plasma TV.
The manual for the Hitachi P50H401 TV is available from Retrevo: http://www.retrevo.com/support/Hitachi-P50H401-TVs-manual/id/1233ci869/t/2/ . You will need to enter a code to access the pdf.
I'm assuming you don't have one of the special versions that were intended for large audiences that were only controlled by remote (no control keys on the front of the TV). Remotes.com has the original remote or a substitute remote if you need it. See http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13104063628240&smodel=P50H401&brand_pn=HITACHI_P50H401 .
I hope this helps.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
TV has blue vertical lines and no picture
I have a 42" Electrograph plasma and it has a 2" black vertical line on the left side of the screen.
Aug 02, 2010 | Electrograph Systems DTS4230 42 in. Plasma...
Bought display w/ no remote, and am hoping to use my Logitech Harmony 880. Any idea how to get it working? The logitech software recognizes the DTS4230 model, but the TV does not respond to the remote.
Hi. If you do not have the original remote for the device, you can call Logitech support. They have the ability to copy in commands for you that other customers with the same model TV as you have learned.
Hope that helps :)
Dec 15, 2009 | Electrograph Systems DTS4230 42 in. Plasma...
Hi, I have a DTS42W Electrograph that turns on but no image coming on but i can see the on screen menu perfectly, help please!!!
check the cables going to your unit, if the graphics are ok the tv is ok, hast to be a bad connection.
Dec 10, 2009 | Electrograph Systems DTS42W 42 in....
Panel locked
Remote needed:
When Panel Lock is set to ON, the buttons (SOURCE, MENU, VOLUME, SELECT, MUTE, POWER) on
the front of the PDP will not operate. However, these buttons will operate when setting Key Lock OFF.
1 Press the Menu button. Move the joystick up or
down to select “SETUP”, then press the joystick
to enter.
2 Move the joystick up or down to select “Panel
Lock”, then move the joystick left or right to select
“On” or “Off”.
3 Press the Menu button to exit.
Jun 02, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Electrograph DTS4225PTD Plasma TV 42"
It's Y upper buffer, also cross matches, with LJ41-02760A which is for Samsung 42 Plasma
Feb 29, 2008 | Electrograph Systems DTS4225PTD 42 in....
My Tv says Keys locked
PRESS MENU BUTTON THEN UP / DOWN BUTTON TO SELECT SPECIAL MENU THEN TURN CHILD LOCK OFF
Nov 11, 2007 | LG 42PX5D 42 in. Plasma HDTV
DTS34-CRT - what universal remote setting for "TV" is compatible?
try these guys, i have had no luck online; http://www.electrograph.com/default.aspx?id=008&hid=77650348034E1B8CE3EF49687496D4C4 if you let us have the remote model number we may be able find out from that side. Hope this helps :)
Mar 17, 2007 | Electrograph Systems Electrograph...
Electrograph Systems DTS42PT 42 in. HDTV-Ready Plasma Television Logo
234 people viewed this question
Top Electrograph Systems Televison & Video Experts
Marvin
Marvin
Are you an Electrograph Systems Televison and Video Expert? Answer questions, earn points and help others
