Question about Magellan Roadmate 760 GPS Receiver
After useing my roadmate 760, i blow a fuse in the cig lighter cord. I call customer support, they told me to use a 5 amp fuse. I was burning them up everytime I turned the unit on. I called customer support again, they said they don't have the manuals and couldn't tell me what fuse it takes. I put a 10amp fuse and know I'm frying the 15amp fuse in my car.
Any suggestions???
My God! The fuse is doing it's job!!!! When you have a short circuit, the increased amperage causes the fuse to blow. Increasing the rating of the fuse is very dangerous. It is like in the old days when a screw in fuse in your home blew and some idiots would replace it with a penny. Then when a problem occurred, a fire would start in the home wiring. You are headed for a major problem in your car. Send the unit in for servicing!!
Posted on May 11, 2008
The cord for the roadmate 760 takes a 3 amp 250 volt fast blow fuse.
Posted on Apr 04, 2008
I had the same problem, turns out the cigarette lighter adapter was the problem, I bought a new adapter and works fine now.
Posted on Jun 01, 2008
Galaxy DX949 cb radio with the 5 amp fuse (if I hook it up to the cig lighter) will it still blow?
if you have bought the cig light plug for that radio it shouldnt blow ade you having problems blowing fuses?
Mar 09, 2013 | Radio Communications
1999 chev astro van
Sounds Like You Have An Exposed Hot Wire Somewhere. I Would Try And Change Cig Lighter Wiring Harness. Be Sure And Check Your Aux Outlets So That There Are No Exposed Wires. They All Run On The Same Fuse Hope This Helps!!
Feb 12, 2013 | 1999 Chevrolet Astro
Cigertte lighter
I am not exactly sure of your problem of just saying cigarette lighter, but I assume you are saying it is not working. If this is the case, most likely it is a fuse. Look in manual if you can not find right fuse or where fuse panel is. However the fuse will be marked as cig or cigar and if that is so, pull out fuse, and replace it with same amp. It will be marked. The fuse you can easily get at any auto parts store, such as shucks, or Napa, or auto zone. Cig lighters often blow because with all these devices now a days we plug in them, they get a lot more use then years ago. For example they were actually designed originally to light cigars or cigs, but now we are plugging in i phones, computers, phones, etc,,,, so they get a lot more use and sometimes we overload the fuse and blows. I tell all my customers that it is nice to have a couple back of cig fuses in the car. There real cheap they normally come in a little tiny plastic pill size clear box, and run under 5 bucks and normally at least 5 fuses in the box. I hope this helped your problem, again I was assuming by your only posting of your problem stating cigarette lighter, Please let me know if this advice helped, or if not, let me know what else i can do for you, thanks Mike
Jun 26, 2011 | 2000 Ford Focus
Hi,i'm having trouble with the cig lighter on my car, it keeps blowing fuses. can i wire it directly to the battery with an inline fuse? How would i do this?
you could do this by running 2 wires directly from the battery to the back of the cig lighter and by fusing the positive.if it is only when using the cig lighter and not when charging a phone ect.it could be element on the cig lighter shorting
Apr 05, 2010 | 2000 Volkswagen Golf
What size fuse goes into the cig lighter adapter for the magellan roadmate 760
size or value?
4 amp is what are placed in them at the tip.
Please rate my help++++Thanks for using FIXYA
Dec 06, 2009 | Magellan Roadmate 760 GPS Receiver
2000 Buick Century lighter fuse blows when TomTom plugged in.
this is the cigar lighter receptacle causing the problem, take my word on this.
Aug 17, 2009 | 2000 Buick Century
Cigarette lighter plug not working
hopefully nothing serious. if you can, make sure your wires did not burned or got too hot.Visually inspect them. Then, if you have a voltmeter check to see if you getiing power to it. no voltmeter? Go to your nearest auto parts store and ask for a test light. Back to the lighter, if you have power on the wires or wires leading to the back of the lighter, more than like it you lighter burned out.  No power on the wires? make sure wire did not get fryed or burned, all wires look good? check fuses again.  worst case scenario, can't find problem ? you can run another wire from your fuse box to the lighter.
May 13, 2009 | 1994 Toyota Celica
Cig lighter fuse blew. renewed but cig lighter and remote key not
you probably didnt change the right fuse and had another one blown at the same time you also could have a primary fuse under the hood that blew. once fixed dont use pump again. not same amps drawn
May 06, 2009 | 2003 Toyota Corolla
Replaced fuse after popped right away
try replace the element for the cig lighter. our disconnect the cig lighter and install the fuse if it blows again somting beside the lighter is causing your problem kdc744
Jan 16, 2009 | 2001 Ford Explorer Sport Trac
Utility cigrette lighter in dashboard
you may have burned out the lighter unit.check the wires for melting also!
Sep 23, 2008 | 2004 Toyota Camry
Magellan Roadmate 760 GPS Receiver Logo
238 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
