Question about Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer
Water problem with stackable Maytag Neptune
I have a stackable Maytag Neptune and water is not getting into the actual washing machine to wash clothes. A professional said the water valve was the problem but that has been fixed and the issue is still occuring. What could be the problem why the clothes are not getting wet?
  • 868 Answers
You have to make sure your self if water is getting through the hoses first.Remove the hot& cold hoses on the back of unit.Make sure there isn't a clog in side of the water valve screens ,if so clean them.Still not filling?Possibly a blown fuse.
Posted on May 26, 2008
MAYTAG NEPTUNE TOP LOAD DOES NOT FILL TUB WITH WATER HEAR NOISE BUT NO WATER AND STOPS AND 24 MIN QUICK WASH CYCLE, NOT SURE WHERE TO START.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The cold cycle on my Maytag Neptune front load washer is not working. It works fine with hot water.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
Neptune stackable -water left below the drum after cycle complete
Some water yes. a lot of water no.As long as the water stays below the wash tub you should be OK.
You might want to pull your water pump off and check for a restriction.
Mar 23, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune stackable washer dryer stopping
Maybe a water fill problem ,washer will stop if no or not enough water enters the tub in a given time
Dec 04, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Maytag neptune front load odor
its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Water wont drain all the way
I have the same problem and am trying to get it fixed. You can find good info here: http://www.applianceguru.com/
Search for the model name and number of you appliance. Good luck!
Aug 24, 2008 | Maytag MLE2000 Front Load Stacked Washer /...
Maytag Neptune Stackable washer continues to fill with water when unit is off
If the machine continues to fill even after the power has been switched off, this sounds like a stuck inlet valve. To identify the valve, look at your model in the "parts store" section of Maytag's website. The valve is item 21 on the "Control Panel, Top & Lid" drawing. From the drawing, the valve looks like a fairly standard item; I suspect you might get something suitable a bit cheaper elsewhere. A
Feb 05, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer Logo
175 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
