Question about Canon PowerShot A550 Digital Camera
Black screen water spilled on the screen of my camera. It will still take pictures but I can't see an image or the menu. I used a hair dryer to dry it after removing the batteries and sat it in the sun for several hours. BB
    Genius:
  • 2,985 Answers
If you can see 'shadow' images then this suggests the backlight has blown
If nothing at shows up then it is a circuit problem
Neither make economic sense repair wise.
Live with it or replace it.
Posted on Feb 09, 2008
Water spilled on the display
Not sure exactly what happened but I do know if anything wet spills on anything electronic... computer, tv, cell/mobile phone etc, I've gotten them all to work by pulling panels apart(when possible) and letting dry out and sometimes drying it with a hair dryer. Item should be left out to dry for quite a few days. Do not do this with any current hooked up.
Aug 05, 2013 | Televison & Video
Wife spilled water in micro model jes1651sj02 blew breaker dried spill some water still inside
Remove and use a hair dryer to dry the boards, it is important that ALL the water present within the board must be dried out.The board also can be removed and dried
Please check this link: Water in set
Jul 05, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Water spilled on dsi screen white will not turn off
Try to dry out the unit. take out the battery and use a hair dryer on it( lowest setting). If it doesnt work, replace the unit
Jan 15, 2011 | Nintendo DS Lite Console
Water
it depend on how you spill it,is it really soaked or just a litte wet?
remove the battery and dry it with a hair dryer it help
Jul 05, 2010 | LG CHOCOLATE VX8500 Cellular Phone
I spilled some water on my tv and now the sound is broken
Turn the TV off imediately. Remove the back cover and heat up the wet area with an hair dryer to thoroughly dry the board. Then try tv again.If it doesnt solve the problem look for the board that the speaker wires connect to and replace that board..You should be able to buy online.
Oct 17, 2009 | Insignia IS-LCDTV32 32 in. Television
Sony Cyber-Shot DSC-T1 Digital Camera is taking weird pictures?
imager is going bad due to moisture. try using hair dryer to dry it out. if not flat rate to sony is around 120
Jul 12, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Got spilled by water
Uh, oh, sounds bad, probably didn't get all the water. Also, you really have to open things up and let dry for several days(I leave things dry for a week, before attempting to power up). Open it again, do it quickly, I've never used a hair drier before, hum, I'd just leave it opened up(as long as it was just water that is). You need to get it opened up as completely as you can. Just try not to get impatient with it.
Mar 16, 2009 | Toshiba Satellite A100-S8111TD Notebook
Panasonic-36" Pana Black Tube - channels are continuely changing
I would suggest to let the water dry or you can use a hair dryer to blow air through the buttons, you could also open the back cover to blow air towards the front panel to dry it faster.
The spilled water is acting as a conductor, that is why the channels are changing on their own.
Good Luck.
May 26, 2008 | Panasonic CT-36HX41 36" TV
Water spilled on camera
First try the obvious, and press your DISP button once with the camera turned on. If that doesn't work, next thing to try would be to reseat the LCD ribbon cable into its connector. This is not too difficult, but it does require opening up your camera. But before proceeding, note that the camera still takes pictures at this moment. There is a possibility that something might go wrong, and the camera will no longer be operational after the repair. Please remember that it's ultimately your decision to proceed with a repair.
The following webpage describes disassembly of the A520/540. If you decide to repair it, only proceed as far as the first two pictures to remove and then reseat the cable. Follow the LCD ribbon cable to where it connects to the circuit board. There should be a connector with little hinge points that you lift with your fingernail to unseat the cable. Clean and dry the exposed end of the cable with a Qtip with a single drop of rubbing alcohol. After thoroughly drying, reinsert the cable into its connector and push down on the hinge points to reseat it. Then reassemble the camera:
http://photography-on-the.net/forum/showthread.php?t=251630
Also please note that there is a risk of electrical shock. Please read the following to learn how to mitigate this risk:
http://camerarepair.blogspot.com/2007/11/important-warning-camera-flash.html
Feb 08, 2008 | Canon PowerShot A540 Digital Camera
Very, very dark (almost black) lcd screen, but is functional
The LCD viewer is made up of the LCD screen, and the backlight. Your backlight is burnt out, or the circuit board isn't sending power to it. Backlights can be replaced separately.
Sep 04, 2007 | Logitech ClickSmart 420 Digital Camera
Canon PowerShot A550 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
