Epson Stylus Photo R300 InkJet Printer Logo
Posted on Feb 09, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
R300 paper jam
Helo i have a epson prenter model r300 i have masseg ( paper jam ) please how i can to remove this proplem
thanks
Anonymous
Level 3:
Genius:
  • Master 2,985 Answers
  • Posted on Feb 09, 2008
Anonymous
Master
Level 3:
Genius:
Answers
2985
Questions
0
Helped
1027645
Points
5636
Shut the printer down.
Remove the software from the computer.
Come off line.
Disable the Antivirus software
Re install the printer software following the prompts exactly
Come back for more help if this did not do it
5helpful
Epson Photo Stylus R300 paper error
Please replace holder shaft & Roller ******
Sk. Abdus Sabur
EPSON R 300 SAYIN PAPER JAM WHEN NO PAPER JAMMED
Make sure that the paper path is completely clear and clean the paper sensors with a q tip. They get very dusty!
Paper feeds ok but after a second it advances an inch then get the error paper jammed. wont print please help
When turn on status ok, but when star to print, it feed paper then jammed? Problem with head carriage. Check chip and connector chip at carriage. Try to use another ink tank.
Printer showing error as paper jam
This means the IR indicator is dirty with ink or something. You need to clean it.
I wish I could post pictures to show how to do this...
Epson R300 Constant Paper Jam
Take it apart,as fas as you can.clean out all of the paper and chips. The print 5 pages only, twice as the Epson manual says to do , in order to clean itself out.
4helpful
EPSON R300 PRINTER NOT FEEDING PAPER INTO MACHINE.
my epson r300 makes all the right noises when feeding paper but will not draw the paper through can you help
adrian
Will not pull paper into printer...half the time
What sort of paper are you using? What sort of volume has the machine done? Have you ever had a jam and pulled the paper back out through the auto sheet feeder instead of feeding it through the exit rollers?
Epson R300
Make sure the photo paper is not curling when it goes in. I had same problem before, with paper jam error even though the photo paper did not appear jammed. I noticed the photo paper was slightly curled, so I flattened it out and that solved my problem. Also, if you are loading multiple sheets at one time, try just loading one sheet and see if that fixes it.
Epson stylus photo R300
>disconnect printer from the computer
>powercycle the printer
>check for obstructions / torn papers inside unit
>if issue still persists - hardware issue
>warranty starts from the DATE OF PURCHASE better check
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
