Need to have directions on how to replace drivers side power mirror on 1999 silverado
Remove that plastic piece at the top of the door panel, ( it just unsnaps straight out), use a small screwdriver or putty knife to help pry it up, it's held in place by plastic clips so be gentle.
Unplug the connector from the mirror,
Remove the nuts and the mirror assembly will come off, don't let it fall.
Installation is the reverse.
Push the mirror lens upward so it faces the roof of your Buick LeSabre.
Place the eight-pointed star head of the Torx driver into the setscrew located in the base of the rearview mirror. Turn the Torx driver counterclockwise. This releases the clamping pressure on the mirror.
Slide the mirror upwards to remove it from its metal bracket.
Place the base of the replacement mirror against the windshield, directly above the metal bracket. Slide the mirror down into the bracket. The bracket has a groove on each side into which the mirror will slide.Secure the mirror to the bracket by tightening the setscrew clockwise with the Torx driver.
