Question about Cakewalk SONAR 4 Producer Edition for PC
Input Echo - audio feedback loop
I get a feedback loop when I switch on Input Echo, so I'm stuck only recording a single channel, or getting bleed over
  • Anonymous Mar 30, 2008
    After a track is recorded it'll bleed over to a new track.
    Problem Solver:
  • 19 Answers
Do you record from
a) mic
b) line input ?
if a)
turn off your speakers, and use headphones.
or at least turn down the volume, and change the mics position (as far away from speakers as possible)
if b)
dont route the allready recorded channels to your master while recording (-> or mute them)
Posted on Mar 31, 2008
My purple coded mic bleeds over to other channels
Poor shielding will cause it. An being to close in frequency.
Jul 18, 2017 | The Audio Players & Recorders
How to install into pedal chain to input on amp
This mixer does not have inserts on the channels which you would normally use. Instead it has a single effects send and return, you set hw much is sent and returned on a per channel basis but unfortunately are stuck with just the one effects chain for all inputs.
If this is all you need then fine, you can apply your effects chain to all the inputs by as much or as little you want, this may work for echo and reverb on vocals or a single guitar on one input but for anything beyond this you are better off getting a decent mixer with proper inserts on all channels as well as sub and master inserts.
Feb 17, 2014 | Peavey PV6 Mixer
I need to sync my snowball into cubase sx... its only recording on the left input not the right input of the audio wave. please help get back to work.
This is strictly a software setup problem. I use Sonar, but Cubase has to have the same features. Look for a PAN control and also where you MIGHT be able to select that both channels of the stereo are mapped to the single input. A work-around might be to bounce the input to a second track and then do a channel swap on one of the stereo channels, then combine them. I think Cubase uses the word "flip".
Search your documents for keywords: flip, bounce, swap, pan, and assign input. You can also copy and paste the recorded channel to a second stereo blank channel before flipping it and combining.
Mar 14, 2013 | Blue Microphones Snowball Professional...
There is a horrible echo whenever i try to record and then there's a loud noice that sounds like a very high-pitched whistle and i don't know what to do.
This type of audio feedback loop can happen on any mic if you are playing back audio at a loud volume on speakers that are close to the mic while the mic is on - which tends to happen on Skype calls. Try lowering your speaker volume or using headphones to hear the audio, then speak into mic, and the feedback should be reduced.
Apr 12, 2012 | Labtec Microphone Microphone
Im trying to connect my mpc 2500 with pro tools 8. im using an mbox 2 pro as my interface. I can get pro tools and the mpc to sync...but i cant seem to understand why i cant hear any of my samples from the...
Check if the Mbox2 has an echo setting that echos the audio from its input. If you want the audio to loop through the PC then it will have to echo there instead. Check that in "Sound and devices" of the PC are all set to transfer via the MBox for voice and playback instead of the internal PC audio system.
Apr 12, 2011 | Akai Mpc2500 Music Production Center
Lost manual. I need to know how to hook a TDK-3826 dual recorder to a PA System at church to record the services and what CDs to use.
Hi wpless43!
The TDK-3826 supports analog input/output, digital coaxail input/output, and digital optical input/output. To connect a PA system, you'll have to determine what type of connection it uses. If your PA system uses an analog connection, it will have two audio cables, one for the left sound channel and one for the right channel. These are color coded and can be connected to analog connections on the back of recorder. Coaxail and optical connections are both single cable connections, and can be connected to their respective locations on the back of the recorder.
Regardless of the connection used, you'll want to connect one of the outputs of the PA system to the recorder if you want record. If you want to use the recorder to play back audio over the PA, you'll want to connect the output of the recorder to the input of your PA. Most PAs support multiple outputs and inputs, so you should be able to connect the recorder input and output at the same time.
You'll want to use CD-R/RW discs to record, but make sure they are audio discs (See image). joehaydu.jpg
You can find a copy of the manual for the TDK-3826 at Hope that helps!
Mar 05, 2011 | Computers & Internet
I have just got a Behringer uca202 usb interface, have wired it all up correctly and yet some how there is HUGE static noise when recording and playing back in my monitors/headphones, the monitors are not...
Two things... Make sure echo function is off and ALSO that ALL equipment is powered from the same receptacle to insure no ground loops.
One other thing is to make sure all anti-virus and other background programs are idled while recording. Even things like wireless LAN running can interrupt the smooth flow of data from the device.
Jan 25, 2011 | Behringer UCA202 Audio Interface
I get a high pitched noise when in pro tools
I don't know what devices are connected to your audio input ports, sounds like gain is too high on a microphone or guitar or speaker setting too close to your work station, sound like feedback loop.
Nov 02, 2010 | M-Audio Fast Track USB (FASTTRACK) Audio...
Hi folks, my problem is when rec. audio the tracks start to bleed onto next track and my fx do the same thing.i'm a 20 yr. musician with a month of cakewalk time a.k.a.(novice) please help. in dire straits...
hi mate no worries heres a fix for ya lol in music creator 4 go to transport then click on recording options in the lower part titled "loop recording" click store takes in a single track you done no more bleeding i know that really sux
Oct 25, 2009 | Cakewalk Music Creator 4
Echo indigo io recording problem
dont plug mic into output, it is input
May 24, 2008 | Echo Indigo IO Sound Card
Cakewalk SONAR 4 Producer Edition for PC Logo
479 people viewed this question
Top Cakewalk Computers & Internet Experts
Parshiv Luthra
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
