Question about GE WVSR1060A Top Load Washer
Ge washer my ge washer will not spin out modle n.wcsr4170goww
  • bambam1one May 22, 2008
    my washer will not spin. the tub is not tight like when I bought it.
  • Anonymous May 30, 2008
    my washer wont do anything
  • 3 Answers
I just had the same type of problem and fixed it. The door switch under the lid is not working properly. Mine wasn't working because some lint, etc. got caught around the switch wiring and as the agitator used to spin, it spun a knot around these wires. Over time, this knot started to pull on the wires and one of the wires got disconnected. So, for the time being, I "jumpered" the switch out and can operate that way. BUT, THE SPIN CYCLE WILL CONTINUE TO WORK UNTIL YOU SHUT IT OFF. IT WILL NOT SHUT OFF BY ITSELF (AUTOMATICALLY). ALSO, BE VERY CAREFUL. THE DOOR SWITCH NOW DOESN'T WORK UNTIL YOU WIRE IT BACK IN. THEREFORE, THE SPIN CYCLE WILL CONTINUE UNTIL YOU SHUT IT OFF YOURSELF (NO DOOR SWITCH IN OTHERWORDS).
Good Luck!
Posted on Nov 19, 2008
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
Will not drain water can i fix this
sounds like a bad dump valve. and yes you can replace it. take your serial number and modle number of the manufactures name plate down to your local appliance store and have them order the part and replace it
Dec 02, 2012 | GE Spacemaker Washer and Dryer Electric...
I have a Ge top load washer modle number wjre555oh The washer will fill and drain but it will not spin and the agitatior will not work. it will act like it is going through the whole cycle but will not...
your lid safety switch is faulty,this switch controls spin and agitate cycles the lid needs to be closed so this switch will be closed to make the circuit,when its bad its open all the time and can't operate these cycles,you will need to remove the top cover to replace this switch
Oct 14, 2010 | GE Washing Machines
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
Can I wash my bathroom rug in my GE washer modle WJRE5500G2WW
u can but not recommended they clog up the pump alot
Jun 24, 2009 | GE WBSR3140DW Top Load Washer
GE washer WSXH208AWW does not spin and drain out.
my GE washer does not spin out all the time on final spin
Sep 08, 2008 | GE WSXH208A Front Load Washer
GE wpse4200aoww washer won't stay in spin mode
Thanks for the question On a ge washer If you over load or the washer did not drain fast enough or over suds ing , when the washer starts to spin the forse of the spin will push water up the pressure switch hose causing the washer to start & stop spinning Thanks for the question THe appliance doc
Aug 23, 2008 | GE WHRE5260E Top Load Washer
Does not spin
the machine will agitate and pumpout the water but it will not spin
Aug 05, 2007 | Kenmore 23822 Top Load Washer
GE WVSR1060A Top Load Washer Logo
191 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
