Heavy Duty Speed Queen top loader, HA 4011-3062, with a slow spin
After replacing both the drive and pump belts, the clothes are still wet after the spin cycle. While looking inside the machine while the spin cycle starts, you can see the "clutch" disingage as the motor speeds up, but after about 50 seconds the clutch ingages again. I am not sure if I am getting maximum speed out of the motor?
  • Damp Feb 10, 2008
    I have spent a lousy day staring at the inside of this washing machine as it goes through it's whole wash and spin cycle. I had a previously washed large load in the tub which I did not add any new washing soap to, so it was just washing with water the second time. i.e. no soap.
  • keith kirschner May 11, 2010
    how much soap do you use?
I have a related problem and I just learned on the net that the Vbelt is supposed to slip in "idle" mode while the water pump will do more work.
It is also supposed to slip slightly while speeding the spinning up so as to not cause motor overload.A kind of half clutch function that allows for slipping. This slipping is controlled by the tensioner.
My guess is that your machine's v belt slips too much and thus does not spin fast enough. You replaced the belts, I would look at the tensioner now.
Posted on Apr 07, 2011
Speed queen heavy duty has problem leaving some oil/grease spots on clothes, for a couple of years now. Now the past two days the agitation and spin cycle sounded out of balance, but when I rearranged the...
Oil spots on clothes is from a seal on the drum. The balance issue is from shocks or springs that may be loose or broken and the spin issue is due to transmission. You may have a problem finding parts
May 26, 2017 | Speed Queen AWN432 Washer
I have a 2 month old Speed Queen top load (542) after the spin cycle, the clothes are still very wet
i assume the majority of the water is being pumped from the machine? if the clothes are very wet check your "fabric Select" setting and ensure you are not wahing on delecate handwash or wool wash (knits) setting, in this setting there will be a very slow or no, spin so the clothes will not stretch and have to be laid out to dry this is normal. if you are on a Permpress or regular setting the spin should be faster, also check your cycle selection is for Regular or permpress and spin is not missed .
I hope this was useful
Feb 15, 2013 | Speed Queen AWS52NW Top Load Washer
My machine seams to go slow with a light load 500mb h/duty
500mb from memory was a Hoover top loader ??? It could be just the belt slipping underneath, but also have a look inside the drain pump hoses for blockages. These were notorious for blocking with coins and other foreign objects. . If the machine couldnt pump out properly, when it went onto spin, it would only go very slow as the machine wasnt able to build up any speed with a full load of clothes and water.
Jul 26, 2011 | Washing Machines
Motor rund but drum dont spinon speed queen heavy duty washer
Fluid Drive clutch greasy or worn,
Pump blocked or drive belt too loose
Feb 23, 2010 | Speed Queen AWS75NW Top Load Washer
Water does not fully spin out. clothes are wet.
Not sure which model you have, but it sounds like the belt is slipping on the pump. Which will also cause a slower spin speed as well. I would suggest a new belt. Note that it can be a "bugger" to change the belt on a Speed Queen because of the pump mounting. Again depending on which model it is.
Jan 01, 2010 | Speed Queen Washing Machines
Washing Machines Logo
104 people viewed this question
Top Washing Machines Experts
