Question about Dishwashers
Hotpoint Aquarius DWF31 Dishwasher Inlet Valve
No water is entering the machine at programme start, so I suspect the inlet valve solenoid. I have put a meter over the terminals of the solenoid. The resistance is 3.8k ohm. Is there any other test I should try to confirm that a new valve is deeded before I blow £40 odd on it?
  • Kevin_Parsk Feb 11, 2008
    Thank you, Yalmer. I'll check you mains supply once I can find the crocodile clips for my meter probes!!
  • Anonymous Mar 16, 2014
    euroart inlet solenoid valve
  • 552 Answers
Please verify that the hose screen is not plugged.
3.8k is good.
Did you try putting your hand carefully on the body of the valve to check for the clicking sound/vibration at the solenoid?
If you here/feel something, you may just have a plug-up.
Otherwise if there is no noise and since the solenoid coil checks out, You should also check to see if there is voltage to the solenoid coil.
The solenoid could also be stuck and a few taps could loosen junk from it.
Always observe safety!
If there is voltage, by putting a meter across the coil terminals, then you do have a stuck or shot solenoid and the entire valve/solenoid assembly should be replaced.
Posted on Feb 09, 2008
My dishwasher starts ok then stops 2 flashing lights appear on control panel does anyone know why
Possible that the inlet valve, inlet filter is clogged and so there is low pressure or flow of water into the washer. Secondly the water level sensor can be faulty and so since there is no detection the processor is shut down..
May 03, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Kleenmaid DW3 dishwasher not running.
HI,
If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Sep 12, 2008 | Dishwashers
Dishwasher wont take in water but pump is working, had side off and checked in coming supply. could it be the electronic valve on the supply in?
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it's not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it's not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. Here is a video checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models. All parts come with installation instructions.
Sep 24, 2010 | Hotpoint 24 in. DF55 Free-standing...
Hotpoint aquarius not working due to error message on screen, it does spin but looks like no water can enter the machine.
check that the there is water to the machine and the isolating tap has not been turned off , if ok then check electronic water inlet valve
Jan 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
My washing machine wont rinsewhen i put it on for a wash
Check for a cold water supply problem, since cold water is what is used in the rinse. Check the water inlet valve. Remove the water supply hoses and check the small screens inside the water inlet valve ports (especially on the cold water side). The solenoids can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a bad solenoid. I will attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Sep 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Granddaughter just bought second hand hotpoint aquarius extra wms38 1200 spin .fixed it all up water coming through the ppipes but not in to the machene not filling up or doing anythging any advice please
Soumds like the water inlet valve is not working. You will have to remove the top of the casing and replace thr inlet valve. If the valve is ok then the trouble will be at the programmer. Usually it is the inlet valve.
Jun 09, 2009 | Washing Machines
Dish washer not filling with water when put on
There are a few things that can cause this problem, it could be a defective water inlet valve, it's usually located behind the lower kick plate on the left or right hand side of the dishwasher, When the washing cycle is started it sends voltage to the water inlet valve to open which allows water to enter the machine, or it could be a faulty float switch, when water enters the machine the float switch raises up which signals the water inlet valve to shut off, the float switch is located inside the dishwasher at the bottom, you can check the float switch by raising it up and down to see if it's stuck in the up position. Good luck.
Mar 21, 2009 | Dishwashers
My dishlex dishwasher overflows
The only part that physically allows water to enter a dishwasher (upon receiving power from the control) is the inlet water-valve. I would test the inlet water-valve located directly where you in-coming water line is connected to.
Shut-off power to the dishwasher and remove the 2 prong connection to the water-valve solenoid (small, black, batter size). Test the solenoid for continuity; if bad, replace the entire inlet water-valve (cost about $20)
Jun 15, 2008 | Candy 24 in. CD623 Free-standing...
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Don't forget to rate!
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Dishwashers Logo
813 people viewed this question
Top Dishwashers Experts
