Review the descaling procedure on pages 27-28 of the user manual (
saeco Talea giro plus User Guide ( English )
) One possibility is that dirty contacts in the control knob rotary switch block the signal informing the controller that you have reached step 13. In that case, it may not reset the servings since last descaling counter.
Go to pages 37-38 of the service manual (
https://www.manualslib.com/manual/800239/Saeco-Talea.html?page=48#manual), and work your way through to the second section of the diagnostic record menu. If the descaling counter shows an unexpectedly large number, then the machine is skipping the reset. Also, check whether the water filter change number makes sense.
A switch contact problem could cause flaky behavior in other functions using the same switch positions. If that is consistent with what you are seeing, the switch needs to be serviced. This requires disassembly to get at the control board. This should be done at a static-safe electronic service bench - remove the water tank and other food-related parts and put them in a clean bag or closed container before this is done. (Whatever you do, don't spray contact cleaner in the kitchen. That stuff doesn't belong around food, period.) Once the switch has been cleaned or replaced, and the machine reassembled, it should be OK to use; just clean using the standard procedure.
Workaround ("...does it really matter if the light continues to flash?"):
If the machine is not correctly tracking when it needs to be descaled, use the diagnostic menu above to find the descaling interval the machine uses. Make a tally sheet to post by the machine to manually track how much water goes through it (# of servings times size of servings). Descale when the tally adds up to that amount, and replace the tally sheet or cross off the used tally section and start another one. To save arithmetic, transcribe the tally data to a spreadsheet regularly and watch the running total. If the use of the machine is very consistent, you could simply go by calendar interval and regularly schedule descaling.
We never know when it's in the descaling cycle until there is water all over. I turned it on this morning to warm the water and when I went back to the kitchen from my office, water was everywhere.
