Question about ASUS P4V8X-X Motherboard
Hdd Hell PC expersts, i have a little problem, i bought a new HDD, Western Digital "WD3200AAKS" I know that my Mother board supports the SATA, on the HDD is amblem- "Serial-ATA". when i Install my hardware into the PC and when i turn off the pc, the bios says that the bios cannot indentify the new hardware... pls halp me.
  • 1 more comment
  • Giedrius Feb 09, 2008
    I am not a very good computerist you know, and what did you mean with saying "check the hdd jumper and set it on sata 1" you mean that hdd can be changed from sata 2 to sata1? pls be more specific i am stressed out..
    and when i connect it to my MB the HDD make some strange sounds.. and the disk whitch is in the HDD is going around on medium speed..
  • Giedrius Feb 10, 2008
    all FIXED THX :D
    Scholar:
  • 119 Answers
Your board may support sata however it may support sata 1 not 2 and your hdd may be a sata 2 one..so all you have to do is to check the hdd jumper and set it on sata 1 and also check the bios for the right settings to be made...
good luck
bye
Posted on Feb 09, 2008
I have a 4 channel Sunluxy H.264 Network DVR, I have fitted a 300gb HDD but although the system is working and I get the 4 cameras on screen the message I keep getting on boot up is HDD not found
Guys this one stumped me for some time, here is my solution that worked like a dream
1. plug the hard drive you are using into a pc and check the hard drive is recognise and works.
2. Delete all partitions
3. ensure it has a 8 bit cache buffer!! This is the most important one. That means the system only supports older hard drives. I got 2 second hand ones from the local pc store for $50. See the list of hard drives that are know to work below.
MANUFACTURER MODEL CAPACITY ROTATION
ST3320613AS 320GB 7200 rpm
ST33500320AS 500GB 7200 rpm
ST3750330AS 750GB 7200 rpm
Seagate
ST31000340AS 1000GB 7200 rpm
WD3200AAKS 320GB 7200 rpm
WD5000AACS 500GB 7200 rpm
WD6400AAKS 640GB 7200 rpm
WD7500AAKS 750GB 7200 rpm
WD10EADS 1TB 7200 rpm
WD15EADS 1.5TB 7200 rpm
WD
WD20EADS 2TB 7200 rpm
Maxtor STM3500320AS 500GB 7200 rpm
STM3750330AS 750GB 7200 rpm
HITACHI HDT725032VLA360 320GB 7200 rpm
HDS721010KLA330 1000GB 7200 rpm
FYI for some reason the person I bought this off online "Ebay" had no idea how to support and I could not get support from their web site as they email they give just bounces back.
Cheers.
Jan 11, 2013 | Home Security
D865gbf intel motherboard sata hdd compatibility
Check with Intel ... www.intel.com/support ... look up your board, specs, and it will tell you what you can and cannot use.
May 03, 2010 | Intel D865GBF Motherboard
I need help finding a replacement power cord for western digital external hard drive WD3200AAKS What model number of cord, and perhaps where I could get one would be greatly appreciated Thanks
You can get a new external case for $18 off ebay. It is a simple operation to change the drive over to the new enclosure. This might be an easier and cheaper option for you.
\View item/: http://cgi.ebay.com.au/3-5-USB-2-0-External-SATA-HDD-Hard-Drive-Enclosure_W0QQitemZ270498649699QQcmdZViewItemQQptZLH_DefaultDomain_15?hash=item3efaf9d663
Apr 12, 2010 | Computers & Internet
Asus P5KPL SE & Sata, Bios "Not Detected Problem"..
The Asus bios won't show SATA devices.
However if you are using Windows XP with Service Pack 2 (or newer operating system then the devices should be detected. If this is not happening then enter the bios -- Storage Configuration -- Configuration Enhanced and set the IDE devices to compatible. This allows all drives to be "seen" and you should then be able to load an OS.
Jan 22, 2010 | ASUS Computers & Internet
Gigabyte 945 gzm s2 doesn`t recognize HDD Western Digital 320 GB
You might need to change your bios settings from ide to sata. Have you already checked the bios settings? If everything is in order you might have a bad board. What have you tried so far?
Nov 20, 2009 | Gigabyte GA-945GZM-S2 Motherboard
MSI RC410 - cannot detect Sata HDD
i think the problem is with ur SATA HDD. To confirm, try another SATA HDD on ur mother board and see if the problem persists
Sep 20, 2009 | ASUS P5RD1-VM Motherboard
Mother board cant detect my Sata HDD, please advise me urgenly...
I will advice you to exchange the HDD with someone or with brand new one as it seems to be problem with drivers of the sata.
Sep 20, 2009 | MSI RC410M-L Motherboard
Sata hdd not detected
Yes, go into the bios and make sure that SATA is turned on. Sometimes with motherboards that have two ide controllers the SATA is turned off by default. Also another thing to check is whether the motherboard is SATA I or SATA II. If it is SATA I then change the jumper on the hard drive to peg back to SATA I. Your new hard drive is SATA II and the motherboard may not support it.
Jun 10, 2009 | Biostar K8T80-A7 Motherboard
K8V-MX motherboard+HDD size limit
yes the mother board supports SATA However if you connect large Disks to the SATA connectors they are recognized correctly with full size. So leave your 500g and less HDs on the IDE and the big ones on the SATA. you can check this link for the manual for more information ftp://ftp.chiligreen.com/Desktop/Manuals/manual_a_k8v-mx.pdf hope this helps .thanks and Godbless pls appreciate by rating as fixyaa
Oct 03, 2008 | ASUS K8V-MX Motherboard
Just buyed Western Digital Caviar SE WD1600AAJS 160 GB SATA
you have to enable the raid controller in the bios to see sata hdd nad have you pluged the power connector to hdd which is by the sata cable port then to your sata port in the motherboard, then install sata card drivers for your motherboard then reboot and after you have rebooted goto devise manager and see if it is reconised the driver if you have a yellow question mark then select it then right click then uninstall then click yes when removed driver goto the icon with spyglass and computer on and doubleclick on to search for new hardware once done reboot then your new hdd will be in the my computer icon.
hope this will help
Jul 08, 2008 | Western Digital Caviar SE WD1600AAJS 160...
ASUS P4V8X-X Motherboard Logo
178 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
