Question about Canon imageCLASS D860 All-In-One Laser Printer
E003 From Mark Langenfelder Accurate copy products. I need service manuals on this copier. A customer called me with a E003 code. When I turned it off and back on it cleared the problem but I want to know why. Please email me at mark951201@hotmail.com
Problème d'installation d'une imprimante canon lbp 1000 laser son driver ne fonctinne pas
Posted on Feb 09, 2008
How do i solve an error e000-0000 canon ir 2202 please
Dear
Its related to the fixing temp. do the error clear on service mode. then check the fixing film assy. heater circuit contact points for corrosion. Replace it.
Thanks.
Dec 12, 2014 | Canon Office Equipment & Supplies
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
this should give you some sort of understanding of the error and
you might be able work your way through the problem
Title : E003-0000 is displayed upon recovery from sleep mode
Error :
Workaround :
When a machine is in sleep mode and is recovered an error code "E003-0000" was displayed.
It is caused during the fixing temperature control at recovery from sleep mode, electrical noise affected the thermistor.
In order to increase the length of time for idle rotation of the drum (by 30 sec) at start-up and prevent electrical noise from affecting the thermistor, make the following selection:
Service mode (Level 2)> COPIER> OPTION> BODY> DRM-IDL = change the setting to '3'
Note: The length of time for idle rotation is being increased by 30 sec.
This mode will delay start of the machine by 30 sec.
or
Product : imageRUNNER 7086 imageRUNNER 7095 imageRUNNER 7105
Title : E003
Error :
E003-0000 Error Code can be displayed when the reading of the main thermistor is below 70 deg. C for 2 sec. after it has exceeded 100 deg. C.
Workaround :
1. Although the fixing heater or the temperature-detecting thermistor may be faulty, before replacing these parts, check J508 on the DC controller PCB for poor contact and refit it if necessary.
2. Make the following selections to clear the error code: [Service mode > COPIER > Function > CLEAR > ERR > OK]
Jul 18, 2013 | Canon imageRUNNER 5000 Copier
Error E0
Error E0 results from the copier being turned off and on immediately after an error. Most likely there is another underlying error on your copier that needs to be resolved, but in some cases leaving the copier powered off for a couple hours can resolve the problem automatically. If you see another error code (most likely E000, E001, E002, or E003), your copier may need repairs.
May 10, 2012 | Office Equipment & Supplies
I have an error code E000 on my canon copier what could be the problem
A E000 code means the error history has detected any one of the following error codes 4 times :E001;E002;E003.
The error can be cleared in the service mode.
Contact Canon Consumer Products 800-828-4040
Mar 20, 2011 | Office Equipment & Supplies
Inherited this 2200 w/ new political office. Was working fine and making clear copies - then error code E000000-0000. Restarted machine - tried Press * Press 2 Press 8 Press * - got nothing. Help.
E000
Indicates either of the following: the main thermistor (TH1) has poor contact
or an open circuit; the thermal switch (TP1) has an open circuit; the
main/sub heater has an open circuit; the main power supply PCB is faulty;
the DC controller PCB is fatly; the door switch is faulty.
In the case of E000 through E003, the code will not be reset when the main
power switch is turned off, requiring the use of service mode
(COPIER>FUNCTION>CLEAR>ERROR).
However, if E001 or E003 is detected within 3 sec after the front door
switch is identified to have been opened or closed, the code will be reset
when the main power switch is turned off and then on. This consideration is
to prevent a service call in response to an error detected when the switch
operation is not fully stable (as immediately after turning off and then on
the main power switch).
Feb 03, 2011 | Canon imageRUNNER 2200
System error E000
A E000 coeds means the error history has detected any one of the following error codes 4 times :E001;E002;E003.
Mar 24, 2010 | Canon imageRUNNER 2010F Copier
System error E000
The problem discription is very long to be shared here, basically what you have to do is reset the copier
E000
The error history indicates any of the following error codes 4 times: E001,
E002, E003.
Action 1) Clear the error.
Execute '#4 PRINTER RESET" under '#7 PRINTER' in service mode to clear
the error.; then, turn back on the power.
It might be a good idea to get a service manual to get a good insite, here is the link for it;
http://www.techmanualarchives.com/canon-ir1630_1670-service-amp-parts--manual-25159.html
Feb 22, 2010 | Canon ImageRUNNER 1670F Copier
Canon NP 7850 keeps blowing the fuser lamp in half!!
Your lamp is not turning off, could be the SSR, could be control board. Replace the lamp, thermistor and the SSR, but monitor fuser operation, make sure the lamp turns off.
If you have a digital thermometer, check the temp when the lamp finally turns off. If it is in Spec. then run a few copies this should cool the rollers and cause the lamp to relight.
If the lamp reached optimal temp but does not turn off, then the control board could be your issue.
Hope This is of some help.
Ed
May 13, 2009 | Canon NP 6085 Copier
Canon iR2200 Copier
E003 is a fixing unit error code. Have you been having power problems? Is this the first time it showed up? If so you need to reset the code in service mode..
Resetting Code: Press "*" additional fun.
Then at the same time "2&8" Then the "*", then touch "Copier", "Funca", "CLR", "ERA", then "OK"... then turn the main power off then on.
Jul 10, 2008 | Office Equipment & Supplies
System Error: Code E000 Product manual: Turn off for 10 minutes. "if you cannot solve the problem" "call your service representative" I don't have a service rep. Please help. David717
I posted a note with a contact number..this appears to be a service level request
Contact Canon Consumer Products inactive_ln.gifcall_small_off.gif800-828-4040us.gifinactive_r.gif
Mar 13, 2008 | Computers & Internet
Canon imageCLASS D860 All-In-One Laser Printer Logo
205 people viewed this question
old marine
old marine
