Question about Dell Inspiron 6400 Notebook
DVD Drive problem
My DVD drive is not visible anymore. I have problems while start up. When i lookup in the device manager, it displays strange names for my DVD driver like SON[" "DVD+ - RW"DW-S5:A".
My actual DVD is SONY DVD RW+- Q58A
I read certain articles on the web suggesting that such problems might arise when u hibernate the system. I used to hibernate the system quite often.
I can only used the system only when i completely disable the drive, orelse it wont even start.
    Novelist:
  • 198 Answers
There maybe a problem with a ribbon like cable that connects your drive to the mainboard. In order to be sure if there is a hardware problem, try to boot your laptop using a bootable cd. If this works and you can read files from the cd then it maybe a windows instalation or driver problem. My best guess is however a hardware problem related to that specific cable or connector. You should try to check these if possible. If your laptop is still in warranty send it to a service center for in-warranty repairs. Otherwise I may help you on how to dissasemble it or how to check that connector.
Hope it helps,
Bogdan
Posted on Feb 09, 2008
My dvd player is not recognized by my computer anymore.
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope it helps
Jun 04, 2012 | Pioneer Bd-rom Dvd±rw Laptop Drive...
Help i have a samsung dvd rom SH-M522C i cant read dvd anymore? what do i do?
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
May 08, 2011 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
My laptop disc driver is unable to read disc contents. also when we on the laptop dvd drive is not visible on screen . only after restarting it is visible on the screen. Regards anbu
device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
make sure that the cd-dvd drive is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.hope this helps don
Mar 13, 2011 | Computers & Internet
DVD drive does not play dvd movies anymore. When we insert DVD it is not recognized. A box used to pop up where we would choose method of playing DVD. Does not appear anymore. A tech friend tried for...
Try cleaning the eye gently with a cotton swab and a little alcohol.If that doesn't work after a few cleanings then the drive itself may need to be replaced.
Jan 08, 2011 | Toshiba Satellite A215-S5837 Notebook
I cannot burn files into my DVD-RW drive anymore. I updated my audio & display drivers after experiencing problems with my audio & display. Now, the Nero program starts the burning process but the...
You may have to delete the device in the "device manager" and reinstall it with the laptop restore disk or download the latest drivers from the Toshiba site for laptops.
Also this DVD-RW may not like +R disks or +/_ Disk . It may only like -R disk.
Jun 22, 2010 | Toshiba Satellite A100 DVD/CD-RW Combo...
My CD drive won't read any disc
Plz try to clean the lens with a lens cleaner...
Mar 02, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
D: (NEC DVD) drive no longer visible
If the device is showing then try this.
Uninstall the driver and delete the device from the Device Manager.
Shut the computer down completely.
Then re-start the computer to see if the operating system detects the drive and re-installs the driver correctly.
Jan 27, 2009 | NEC (2660000400) DVD Drive
Dvd rw
Please go through the below provide steps.
Fixing Code 39 Error
If your CD-ROM drive is not visible in My Computer, you may see the following error message displayed with the CD or DVD drive item in your Device Manager. (Steps to open Device Manager are discussed later in the article.)
"Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
Using Device Manager
To fix this error, first try to update the driver from the Device Manager. To open Device Manager, right-click My Computer on your Desktop, and then on the Hardware tab, select the Device Manager button.
In the Device Manager window, identify the CD or DVD drive item (with Yellow exclamation mark), right-click on it and select Update Driver. Follow the screen instructions to update the device driver and restart your PC.
Using Registry Editor
If updating the driver does not resolve the problem, it indicates that there is a problem in the registry. To fix this problem, you may have to remove a few keys from the registry.
Note: Be careful while working with the registry editor because changes done to the registry using the Registry Editor are irreversible and mistakes can leave you with more problems than when you started. Therefore, it is recommended that you make a backup of the registry before proceeding with the changes.
After you have removed the registry keys listed below, you will have to reinstall all applications that you use for CD or DVD recording to make them work properly.
To fix the error by editing the registry, perform the following steps:
  1. Exit and close all applications currently running on your PC.
  2. On Start > Run type Regedit and press the Enter key.
  3. Next, navigate to the following registry key:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\ Control\Class\ {4D36E965-E325-11CE-BFC1-08002BE10318}
  4. Delete any of the following registry entries if they exist under this key:
    • LowerFilters
    • LowerFilters.bak
    • UpperFilters
    • UpperFilters.bak
  5. Restart your PC and open My Computer to ensure that the CD-ROM drive is visible.
  6. Also, open the Device Manager again to ensure that the yellow exclamation mark and the error code is now gone.
  7. Restart your PC and open My Computer to ensure that the CD-ROM drive is visible.
  8. Also, open the Device Manager again to ensure that the yellow exclamation mark and the error code is now gone.
Thank you........
Sep 18, 2008 | Computers & Internet
DVD Mutirecorder drive driver
hi, I have scoured the internet and this worked for me
    • LowerFilters
    • LowerFilters.bak
    • UpperFilters
    • UpperFilters.bak
It sounds complicated but it was actually quite simple, just make sure you delete the right files.
Aug 02, 2008 | Toshiba Satellite A100-S8111TD Notebook
My CD RW/COMBO drive is not visible in My computer
Removing Drive in Device Manager
Remove the drive name from Device Manager:
Select the drive name.
Click the Uninstall or Remove button (in Windows XP this is the square button with a red X, ).
Click Yes or OK to remove the CD listing.
Do not restart the computer.
Close Device Manager .
If your computer has Windows XP, restart computer!
Dec 13, 2007 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
Dell Inspiron 6400 Notebook Logo
120 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
