Question about HP Photosmart C3135 All-In-One InkJet Printer
My scanner always scans with blurry lines across scanned images from it
HP Photosmart C3135 always brings up blurry or moire lines all over the scanned image, is there a solution for this?
  • 2 more comments
  • suika Feb 09, 2008
    When I make a copy, it doesnt make the moire lines, only when scanning images.
  • suika Feb 10, 2008
    Hi, thanks for the reply, but when I get to the Device Manager window, I can't find the Imaging Devices option or the USB composite device under the Universal Serial BUS controllers option.
  • Anonymous May 01, 2009
    its ***
  • Mohammed Rizwan
    Mohammed Rizwan May 11, 2010
    Hi,I was working for HP as Sr. tech support for All in One printer Department, newly joined at Fixya to test my technical skills.
    First we have find whether its an hardware Issue OR software Issue!..
    When you try to make copy, do u get the same result as u mentioned?If u get the same problem while copying, its an Hardware issue, plz update me about this.Let me know what happens when u make a copy?
    Thank You
    Guru:
  • 731 Answers
I believe that you are trying to scan via HP solution center.
Did u tried scanning from Scanners and Cameras in control panel, and did u notice any lines?
If u get the same lines, we have to remove the USB Composite device and imaging device drivers.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Check for Imaging Devices, click on + sign, then u will see "hp photosmart c3100" right click on it and click Uninstall. Then, Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HO DESKJET F300)
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
7.Try scanning.Please let me know after following the steps!
Posted on Feb 09, 2008
  • Mohammed Rizwan
    Mohammed Rizwan Feb 10, 2008
    1.Click start - >run then type "twain_32" click OK.
    2.A window will open and click EDIT menu-> select all, then delete all the files and folders.
    3.Click start - >run then type "services.msc" click OK.
    4.Look for service called "HPZ PML Driver", Doubled click on it, check whether the "startup type" is "Automatic", if not changed it to automatic.Checked the "Service status" is "started".If not click on "start" button.Click Apply and OK.
    5.Right click on "HPZ PML Driver" and click "Restart".Close the window.Click start - >run then type "%temp%" click OK.A window will open and click EDIT menu-> select all, then delete all the files and folders.If u cant delete them its ok, just close the window and go to step 6.
    6.Disconnect the Printer USB cable, Insert the installation disk of your printer.If Installation wizard pops up, click on cancel/exit.
    7.open My Computer, right click on your CD/DVD ROM Drive , then click "open".Look for folder called "UTIL" then look for folder called "CCC".There you will see a file that says "Uninstall_2". Double click on that file.
    8.A run box will poppup, click OK, now you will see the command windows, hit enter the Driver that is necessary for comunication which are corrupted will be removed.
    9.After that, restart the PC and Insert the Disk and install the printer.Connect the Printer USB only if the PC prompts you to connect.After installaton completes, check the scanner.
    Thank You.
What is descreen option in Hp G3110 scanner
It Is used when scanner painted documents that are printed by using screen me that such as newspapers. It stop moire patterns from being generated on the scanned document. There are strange curved (normally) Patterson. De-screening doesnt always remotely these totally but should help. If you haven't seen moire pattern in before, hold 2 piece of net curtain up against a light source, you'll see it as you move one across the other.
Sep 19, 2014 | HP Scanjet G3110 Color Photo Scanner, 4800...
I am trying to scan a document and it is not working, I have a hp photosmart c4280 printer. How do I install a usb cord
hi
Place the document or image into the scanner for scanning. A scanner with a paper feeder will only receive flat papers and photographs, but a flatbed scanner opens to accommodate books, fabrics and leaves along with flat papers. There is even a attachment for feeding photo slides into flatbed scanners.
  • Step 2 Start the scanning softwaremag-glass_10x10.gif. If the scanner does not engage the software automatically, press the "start" or "scan" button, or click the scanner icon on the computer screen to initialize the software.
  • Step 3 Activate the scan. Click the "file" menu and select "acquire," "import," or another practical choice that applies.
  • Step 4 Preview the item to be scanned. Most scanners have a preview option. This will show the scan area inside dotted lines. The lines can be moved with the mouse to relocate, enlarge or crop the scanning area.
  • Step 5 Set the resolution for images by number of dots per inch (dpi). For computer screen viewing, 100 dpi should suffice. Use 200 to 300 dpi for items to be printed.
  • Step 6 Use the appropriate setting for scanning black and white text. If the scanner does not show a preset for text, use "line art" or "black and white" at 300 dpi. Then use the optical character recognition (OCR) program to convert the image of the text into a file for word processi
  • Jun 09, 2010 | HP Photosmart C4280 Aio Printer
    Using my F380 all in one, how do I scan to my
    Scan an image
    You can start a scan from your computer or from the HP All-in-One.
    This section explains how to scan from the control panel of the HP All-in-One only.
    To use the scan features, the HP All-in-One and computer must be connected and turned on.
    The HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) must also be installed and running on your computer prior to scanning.
    ● On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running.
    Note Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software.
    ● On a Mac, the software is always running.
    Tip You can use the HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) to scan images, including panorama images. Using this software, you can also edit, print, and even share your scanned images. For more information, see the onscreen Help that came with the HP All-in-One.
    To scan to a computer
    1. Place your original print side down on the left front corner of the glass.
    2. Press Scan.
    A preview image of the scan appears on your computer, where you can edit it.
    3. Make any edits to the preview image, and then click Accept when you are finished.
    To stop scanning ➔ Press Cancel on the control panel.
    If this doesn't work for some reason you should also be able to scan using windows camera and scanning wizard, the link will show you how if you have XP, just scroll down past the "how to print" section.
    http://www.microsoft.com/windowsxp/using/setup/hwandprograms/printfaxscan.mspx
    or this if you have Vista:
    If you cannot find the scanner wizard it could be because your version of vista doesn't have it, I'm not 100% but I think it was only packaged with the business version of vista.
    If this is the case then you can download a free program called IrfanView from there site: http://www.irfanview.com/
    Click the Start icon. Click All Programs .
    Click Windows Photo Gallery .
    Click File and then click Import From Scanner or Camera .
    Click Import .
    Click Scan .
    I hope that helps..
    Regards
    Mike
    May 26, 2010 | HP DeskJet F380 All-In-One Printer
    Why does my HP Photosmart C3135 printer always print a test page every time I connect it to my computer? What a waste of ink!
    that is alignment page just scan it and press the scan button it will complete the process and next time it wont print.
    Jan 19, 2010 | HP Photosmart C3135 All-In-One InkJet...
    I scan a document and then I click on
    I suppose you should have some software running on your system to accept the file.
    Check the user guide.
    Scan an image
    You can start a scan from your computer or from the HP All-in-One. This section
    turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software
    HP All-in-One overview
    Note
    2. Press Start Scan/Reprints.
    finished.
    Dec 19, 2009 | HP Photosmart C3180 All-In-One InkJet...
    HP Photosmart C3135 is slow scanning documents
    You can speed up process by choosing a low quality of scanning. Decrease the DPI ( Dot Per Inch -parameter) to 100 dpi or 200 dpi
    Mar 07, 2009 | HP Photosmart C3135 All-In-One InkJet...
    HP Photosmart C3135 All-In-One InkJet Printer Logo
    1,349 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
