Question about Canon Speedlite 550EX TTL Flash
Speed of camera always maxes at 250 by default when external flash is put on.
I am a rookie but I can't figure out how to override the external flash for shooting inside at basketball games. No matter what I seem to do the camera always decides to go to a speed of 250. I need 400 or more.
I am using a Canon 30D with the 580EX. I have it set on aperature priority so I can get more light.
Thanks for any ideas or help.
Jeff
Thanks for offering the help.
I fixed it by just sitting down and going through every setting through trial and error.
A huge pain in the rear end. I got lucky and figured it out.
Thanks,
Posted on Feb 10, 2008
Camera want flash sony dsc-h3
If it flashes when you take any photo then you have the flash set to manual override for each shot or you're just shooting in areas too dark for any photos without the flash. Check your flash settings or try a factory default reset from the camera's menu options.
Oct 14, 2014 | Sony Cybershot DSC-H3 Digital Camera
I currently have a Canon 40D, the problem is... 1)When I take pictures, the bottom 4/5th of the screen is cut off, as in it is black. But the top will show the picture 2)The Liveview function works, but...
Shutter speed too high...1/250 violates the max flash synch speed of most FF cameras....the shutter is not fully open at that speed when the exposure is made, and you are seeing one curtain at the black band.
May 05, 2011 | Canon EOS 40D Digital Camera
My D90 won't shoot the 4 frames per second. Is something turned off that I can't figure out?
The 4 frames per second shooting speed really only applies when you're shooting on manual focus. If you're not shooting a well lit scene or using an off-brand lens your camera will take a bit to auto-focus on your subject. Also if you're using the on-board flash, your camera will take a few seconds to recharge and fire again for the next picture.
Mar 06, 2011 | Nikon DSLR D90 Digital Camera
How do I change the shutter speed?
You can't change the shutter speed on a point-and-shoot camera. You can change modes and some settings that will force the camera to fire the shutter at faster speeds. For example, if your camera has a "sports" mode, that will fire faster. You can set the ISO to a higher setting to cause the shutter to fire faster.
May 14, 2010 | Nikon Coolpix S1 Digital Camera
Canon Macro Settings for 100mm lens and Sunpak 12R ring flash
Firstly, be sure to check flash voltage. Your 30D may accept max 6V so that your camera can be shot if the flash unit has higher voltage than 6V.
1. Use low ISO to keep low noise....around f/8 or more depends on your need and how much DOF you want.....Set the shutter speed around 1/125 to your max speed to stop any movement (your subject or camera itself shaking).
2. Above is set in Manual mode (iso100, f/8 1/125 or 1/250), then you just need to leave the flash to work in TTL mode.
3. It needs battery, the connection is for syncing to trigger and release a proper flash power (in TTL mode).
Hope this help!
Mar 26, 2009 | Sunpak DX-8R TTL Ring Light Flash
Shooting in low light with a canon rebel xt
Hello parr_alp,
Please keep in mind that when shooting in low light, you will ALWAYS get some amount of blur when you are hand holding the camera unless you use a flash. The only way to increase your shutter speed is to crank up your ISO setting to 800, 1200, 1600, etc. If there is no tripod handy, brace yourself against a stationary object and remember to keep your elbows tucked down near your body when shooting (no sense in holding up your arms, too).
There is no way to increase the ISO limits of your camera while maintaining quality of your images. And once again, you will ALWAYS get a certain amount of blur when hand holding the camera.
The external flash not firing is an entirely separate issue. This could have to do with your metering, a bad flash, bad connection in the hot shoe, what shooting mode you're in — the possibilities are numerous. The next time your flash doesn't work, write down all the settings of your camera and keep track of them (i.e. shooting mode, metering mode, flash settings, current lighting situations, etc.) You may start to notice a pattern and perhaps we can help you here.
Anyway, happy shooting, and if this response was helpful, please rate it! Thank you!
Jeff
Mar 13, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Keep getting ERROR 5. Dont know how to fix....also, cant increase shutter speed beyond 250. Not good enough for HS football action...
Depending on the flash you are using, 250 may be as fast as you can go. That may be the limit for the internal flash. A big external flash can go faster because it requires more power.
Dec 08, 2008 | Canon EOS-20D Body only Digital Camera
Internal Flash not working-Canon Eos 40D
I've had this happen to me too and I've been researching about it. Aparantly it happens because the camera still think the external flash is attached. If you go into the menu and under flash control, try ot enter the settings for built in flash. If this is the problem it will tell you here that the external flash is still attached. From what I have read to far, I'm not sure how to fix it. I would reccomend taking it in somehwere. I dont htink its a hard problem to fix.
Dec 06, 2008 | Canon EOS 40D Digital Camera
Shutter speed
Hi Till. If I am not mistaken, the shutter speed on the FD-83 is automatically set and does not provide for manual override. I will check today with our product manager to verify this.
Sep 08, 2005 | Sony Mavica MVC-FD83 Digital Camera
Canon Speedlite 550EX TTL Flash Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
