Question about Kelvinator 12 cu. ft. / 340 liter Chest Freezer KDC-47
Kelvinator fridge water puddle each morning
  • Andrewb2 Feb 18, 2008
    I have a Kelvinator side by side fridge/freeze rmodel NE63OT that leaks a small puddle about once a week. I have checked the drain pan and it is fine. However there is a build up of ice on the floor of the freezer which appears to be blocking the vent at the back of the freezer, which I assume is where the defrosted ice drains to. I have cleared the ice by defrosting with a hairdryer and then the problem doesn't occur until about three weeks when i all starts again. What would be causing the build up of ice?
    regards
    Andrewb2
  • Anonymous Feb 25, 2008
    Model - No Frost - 640 - ice on floor pan of freezer section an almost identical in that there is a puddle each week - i will defrost and remove the ice on thje floor plan and remoive the block of ice at the rear of the unit and look to see if the drain hole is blocked - where is the drain hole located? - i assume on the right hand rear section as this is where the most ice is located.....James Camilleri - Kew
The defrost cycle in the freezer melts the ice each day and the resulting water drips out of the freezer compartment through a short pipe and in my Kelvinator 520F it drips into a small funnel in the fridge section right under the short pipe from the freezer. In my case that was behind the chiller section. The small funnel clips into the back wall and directs water into a concealed pipe that empties the water on top of the compressor where the heat will evaporate it. In my case the small funnel was clogged with old frozen debris from the bottom of the freezer. The funnel overflowed into the fridge section and then onto the floor. It was very hard to see if you didn't know what to look for.
The inner floor and back wall of the freezer can be unclipped,(there was one screw) which revealed where all the spillages had gone over the last 10 years. Yuk. Job for the vac.
Put the funnel back in and tip a small quantity of water into the drain in the back of the freezer, watch it come out on top of the compressor/motor. If it doesn't freely flow then the pipe is also blocked. Try the vac to unclog it. If it doesn't flow freely then the funnel will overflow for sure so you will have to find another way to clear the concealed drain pipe. Maybe wire or compressed air.
Good luck
Posted on Feb 14, 2009
    Sergeant:
  • 288 Answers
The freezer defrosts every day. the puddle is from that. It is supposed to go into a pan at the bottom and evaporate. You need to look at the pan and determine if it has a hole or the drain hose is leaking somewhere.
Posted on Feb 16, 2008
Kelvinator fridge freezer
  • If your refrigerator leaks water, you have a problem with either a water line or a drain line. If your refrigerator has an automatic icemaker or a water dispenser, the water supply line could be broken. Automatic icemakers have a drain line that runs down to the drain pan beneath the fridge. Mold build-up inside the drain line can lead to a rupture that allows water to escape .A broken drain line can also lead to water leaking from your refrigerator.
Dec 16, 2013 | Freezers
My Kelvinator N245C fridge freezer is ok but fridge not cooling when i open the freezer door , the cold air through to fridge air outlet ok but when the freezer door shut and than no air to the fridge the...
first look for an air vent in the bottom of the fridge(a small grill on the inside wall) & make sure nothing is blocking it, like bread eg: if there isn't then unplug your fridge & let it defrost, check the drain outlet in the back of the freezer, sometimes a small item like a frozen pea gets into the drain & the water freezes around it causing the air not to return to the freezer from the fridge, to push air into the fridge you must be able to get air out or it presurises,
Nov 01, 2011 | Kelvinator 12 cu. ft. / 340 liter Chest...
Old Kelvinator Cyclic 340. Freezer is Ice cold
Read the below :-
http://www.fixya.com/support/r3886637-refrigerator_not_cooling_enough_or_not
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 16, 2010 | Kelvinator 12 cu. ft. / 340 liter Chest...
Kelvinator fridge freezer is a geiger counter
something could have fallen into the fan between the two compartments
Nov 10, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Fridge not getting cold
unplug unit to "reset." pull unit out from wall and blow the coils out on the back of refrigerator. if that does not work- call service man to come check freon level.
Aug 09, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Kelvinator Inox Freezer not switching off
hi! theres no funny when you smell burning please switch off the power and you che
Jan 20, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Kelvinator Fridge/Freezer C 340 RM does not switch off
the problem is your thermostat in your frig.the dial with numbers on it.it is no longer sensing properly and theres nothing you can do but replace.that is as long as your dial is not broken[the plastic pice with the numbers] God bless ,tom
Jan 10, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Temperature Setting Dial in Fridge
Hi. thanks for the question. # 9 is the high, 1 is low. and it will run for 24 hrs to get on track .thanks the appliance doc
Oct 05, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Freezers Logo
2,070 people viewed this question
Top Kelvinator Freezers Experts
Mike Squire
Victor Nwachukwu
Victor Nwachukwu
Are you a Kelvinator Freezer Expert? Answer questions, earn points and help others
