Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint Aquarius WT540
My washing machine as above is holding up water,makes an uncommon sound i.e grinding noise and smells like there is some rubber burning.I figured out that if I use the rinse and spin option it might do the trick. It did spin but when it came to to the final spin the above keeps on happening and the reduce creases, mini load as well as the on/off button starts to blink. The pump out option did not work as well ......btw I can even open the door to take out my soaked washing ... i guess it is because it is still filled with water ..?
  • 1 more comment
  • meme01 Apr 19, 2008
    rinse hold and mini load lights flash and water just flows in and immediate pump out. on/off light flases also. cant get it to reset
  • hannah124 Jul 31, 2008
    Machine stopped full of water - pump out option did not work - emptied water through outlet at bottom right - tried to reset by turning of at socket - when turned back on the on/off light and door locked lights come on but will not start any cycle.
  • bigbazlow Nov 23, 2008
    i have a similar problem the 2nd and 4th button leds are flashing and it wont pump out help
    Scholar:
  • 90 Answers
Sounds like the water pump is plugged with something. The pump could also just be locked up. The smell is probably the belt slipping on the pulley. To drain the unit you will need to lower the drain hose into a bucket and let it drain that way. Most pumps can be opened and cleaned. It will be inside and attached to the drain hose. It has a pulley on it where the belt rides. If it has a clamp holding the bottom on remove it and the clog. You may be able to do this without removing it from the unit. Let me know if you need further help.
Posted on Feb 10, 2008
My washing machine is not working
Sounds like a communication error. remove lid and unplug top consol panel for 5 mins ,make sure connections on bottom pcb are tight ,if that dont work replace your PCB
Mar 08, 2015 | Hotpoint Aquarius WT540 Front
Hotpoint Washing machine keeps flooding kitchen
For the age of it, you can either replace it or get it fixed. I would personally get a quote first for repair.
May 18, 2012 | Hotpoint Aquarius WT540 Front
My hotpoint aquarius TCL770 isn't drying clothes
Good evening
There is most likely something wrong with the electricity in the machine.
Kolbrun
Feb 26, 2012 | Hotpoint Aquarius WT540 Front
Hotpoint aquarius wt540 - it has started to malfunction
Most likely a control board failure, you need a service tech to come out.
Oct 27, 2017 | Hotpoint Aquarius WT540 Front
Got a hotpoint washing machine aquarius WT540 think catch is broken how can i open the door
If the catch is broken you are going to need to get at it from inside to release it.
This is usually best done by taking the top or back off and reaching in to release the lock.
Make sure you disconnect the electricty and water before trying this.
Jan 25, 2010 | Hotpoint Washing Machines
When we wash..you can see oil in the wash tub and smell of strong oil odor.
sounds like the spyder has leaked oil from the bearings into the drum, does it make a grinding noise on spin?
Nov 09, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Drum will not move
Try to remove drum belt, and then turn drum by hand, if it does not turn , then you have either siezed drum bearigs, or some thing jammed between the inner and outer drum
If drum turns freely, then check motor to see if it is free to turn.
Please rate my solution.
Thanks.
Jul 24, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius 1100 - Grinding Noise From Drum
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
Oct 29, 2006 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
1,368 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
