Question about Kenwood KW85 Air Conditioner
Kenwood deishwasher kdw243a
What is fault e3 on kenwood dishwasher kdw243a?
  • aviculturist Sep 30, 2008
    Kenwood KW85 Air Conditioner - does not run - displays E3 message
  • 86 Answers
No idia
Posted on Mar 17, 2008
What does e3 mean on kenwood dishwasher
It means it is not heating the water enough. The manual says.. Longer heating time but not reaching required temperature. The possible causes: malfunction of temperature sensor or of heating element
Apr 30, 2012 | Kenwood KDW243A Builtin Dishwasher
Kenwood KDW 243A Dishwasher has an E3 fault and will not wash the dishes, can you tell me what is causing this please? Thank you
The error (E3) relates to the water heating but not reaching the required temperature. This can be due to a couple of things generally. The sensor which detects the water temperature can be faulty or the heater element itself is faulty and not heating the water to a high enough temperature. I think it's needing to be replaced.
Check to see if there is a thermostat screwed up into the underside of the tub on the rear right side. If there is, test the thermostat to see if it's open circuit, if it is you'll need to change it.
Jun 12, 2011 | Kenwood KDW243A Builtin Dishwasher
Kenwood diswasher kdw243a/a e3 fault code?
e3 means there was a longer heating time but not reaching required temperature could be a malfunction of temperature sensor or of heating element. E3 is a temperature error. There are two theromstats, 90 degrees and 78 degrees. I suggest you to call the competent person to substitute either of these thermostats.
Jun 05, 2011 | Dishwashers
My Kenwood KDW243A built in dishwasher is desplaying what I assume is an error code, E3. What does this mean? The washer is not washing properly.
E3 means the base is full of water. A quick fix is to tilt the machine back for 10 mins or so but you need to find the cause of the leak and repair it
Jun 03, 2010 | Kenwood KDW243A Builtin Dishwasher
SHOWING E3 ON DISHWASHER
Had the same problem (apart from the code) and the answer is to stop putting plastic in the machine ! It seems the dishwashers need the heat radiated from the Ceramic plates, stell knives etc to help dry. The plastic simply absorbs some water and then your dishwahser spends most of its drying time trying to get that water out again. Also Plastic doesn't radiate any heat to help. As soon as we stopped putting plastic plates and tupperware containers in, hey presto the dishes are drying again
Apr 13, 2010 | Kenwood KDW243A Builtin Dishwasher
E3 showing on Kenwood model KDW243A
E3 means longer heating time. Usually this indicates the heater element has failed.
Aug 01, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
E1 fault on kenwood dishwasher kdw243a
error code E1 refers to "lack of water inlet pressure" the valve the elctrically lets in the water might be at fault
Jan 18, 2009 | Kenwood KW85 Air Conditioner
Dish washer is not working
Hi kssami9,
I'm Harvey the Master Plumber.
Your problem is: Your dish washer kenwood model kdw243a is not working and displaying the error code E3 please give you the solution.
First try to reset the d/w. Just turn it off at the circuit breaker for ten minutes.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 27, 2008 | EuroTech Dishwashers
Kenwood dishwasher kdw243a
kdw243a code E3 what doesthis mean. ??? pleae.. adres Poland,,,,,, e_mail wiesiekwro@poczta.fm
Dec 14, 2007 | Kenmore Dishwashers
Kenwood KW85 Air Conditioner Logo
264 people viewed this question
Top Kenwood Heating & Cooling Experts
Marvin
Marvin
john h
Are you a Kenwood Heating and Cooling Expert? Answer questions, earn points and help others
