And radio turns on but still no start.
ok all cars ran before we all know that ,what matters is only NOW and tomorrow.
the starter is dead that is the only real clue.
my sisters ranger had manual transmission does yours>?
dead or dim head lamps and wipers and blinkers dead. mean you just lost all 12vdc power, yes that hammer trick ive done for 50yeaer and is right.
radios use about 1/10 th the power of brake or blinker
blinks are 1amp, radio is 0.1amps or even less. so the radio will in fact run on a near dead, battery, even 10vdc *****.
the starter uses 3000 more power to crank and engine 300 amps
so the battery is dead. (or caused by bad alternator and you ignored the cluster charger lamp>?
here are all causes (not guess a test for each to prove it)
1; BATTERY DEAD.
2: ALTERNATOR DEAD CAUSES #1
3: JUMPER CABLE JUMP STARTS WORK (AAA TOW TRUCK DID IT?) or buy a battery charger and charge up the battery or barrow one good from 2nd good car. the battery swap trick.
4: NOT ABOVE. (ORDER MATERS) I then shift from PARK to Neutral and engine magically cranks, bad PNDRL switch.
5: bad starter relay. (if starter dead but relay is silent took, bingo relay or #4 caused)
6: stick shift gear box truck, clutch pedal switch bad, acting just like #4, and for the exact same reason bad switch.
if stranded, Not told
#4 is first. omg I'd driving home the users guide even tells starter cranks fast in NEUTRAL too, foot on brake.
