Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
After replacing stk392-110 convergence chips
I did an auto convergence, and everything seems to line up but the red is blurry. When I go into the manual convergence the red line is about 4 times the thickness of the others. Any ideas what could cause this?
  • mastivee Feb 11, 2008
    I did as suggested and the focus doesn't make the situation go away, it makes it a little better but not good. I ran a self check on the tv and it cam back with everything ok witht the exceptions below.
    SYNC M: OK S: NG HD: NG
    AIO NG 9 YC OK
    Any thoughts?
Behind your front panel is two rows of small black knobs that adjust the lamps brightness and focus. a phillips screwdriver might be needed to turn them. you need to adjust the red guns focus.
Posted on Feb 09, 2008
Screen is a little blurry and can not seem to get color just right
Projection TV sets have two very common problems oulined below.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio/Video - TV Makes Chirping Sound
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 23, 2010 | Philips Magnavox 60PP9701 60" Rear...
Picture seems too bright and blurry
Your TV most likely has one of two possible problems.
  • Screen looks 3D
Dec 05, 2010 | Philips 60PW9383 60" Rear Projection...
Rca big screen 5-8 years old, power shut off this morning while watching then when I powered it back up now blurry and has a red and green outline around everything onscreen
If you have the original remote to that tv, click on menu, then select set up from the on screen menu, then select convergence. you might see auto convergence as well as manual for blue and red convergence.
If you see Auto, select it, this will line up your tubes.
If no auto convergence, you will have to select each one, and follow the instructions to aline your tubes.
Oct 09, 2010 | RCA R52WM24 52" HDTV Projection Television
Tv was blurry them turned off and wont come back on and the red light on front blinks
The blurry must be defined as out of convergence or out of focus,If there is a lines of color on the pictures edges, its convergence, if the picture is not sharp the focus is the problem.The common cause of convergence problem is the convergence drive chip(stk) and might be the cause of shutdown too.The focus problem is commonly contributed by the projector lenses, in most cases the coolant liquid leaks and drip on the board, this causes shutdown too.The lenses must check first for any leak before the replacement of IC(stk).
Sep 23, 2009 | Toshiba 43H71 43" Rear Projection...
Hitachi 57F500 blurry picture
How can I fix it? The magic foucs goes to two or three lines and goes back to the picture. The sides are blurry, like red and green.
Mar 18, 2009 | Hitachi 57F500 57" Rear Projection...
There is a picture but it is blurry with a big yellow blur.
Your TV most likely has one or more possible problems.
  • Screen looks 3D
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Dec 30, 2008 | Philips Magnavox 51MP392H Rear Projection...
Red and Green Arch
You may have a convergence problem. Here are some of the most common symptoms and example photos.
  • Screen looks 3D
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Jul 07, 2008 | Philips 60PP9363 60" Rear Projection...
JVC AV-56WP74 self check question
Each picture tube (red,green,blue) has a magnifying lens assy that sits on top. On each lens assy is a manual focus adjustment with a wing nut that tightens it. The image bounces onto the mirror and shoots it onto the front screen. If you're not a technician then I don't advise you to do this adjustment. You could touch something in the high voltage by accident.
C-Dog
Feb 11, 2008 | JVC AV-56WP74 56" Rear Projection...
Red convergence wont move
if the red line is blurry and you have adjusted the screen focus control and does not work then you prob have a bad red CRT or bad red CRT fluid.........
convergence STK have nothing to do with the red being blurry
Dec 09, 2007 | Mitsubishi WS-55809 55" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
298 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
