Question about Samsung LE40R72BDX 40 in. HD-Ready LCD Television
Optical output on tv through dvd home cinema out of sync
I HAVE A NEW 40IN SAMSUNG LCD HD READY TV AND SAMSUNG DVD HOME CINEMA WITH A HDMI AND OPTICAL CABLES FITTED BUT THE SOUND ON THE TV THROUGH THE DVD RECIEVER IS OUT SYNC THE VOICES GO DEEP AND THE SOUND CUTS OUT ALTOGETHER, SOMETIMES IT WORKS FINE AT FIRST THEN IT GOES OUT OF SYNC ETC AS ABOVE. I HAVE BEEN BACK TO THE SHOP BUT NO MUCH HELP WHAT IS THE USE OF THE OPTICAL CABLE OR THIS ANYNET DEVICE ON BOTH IF THE SOUND IS ANNOYING. TV IS LE40R8 DVD HTX30. I HAVE TRIED TO SET THE AV SYNC DIFFERENT AND MOVED THE 5.1 SPEAKERS ALSO NO HELP. out of sync
  • benandi Feb 20, 2008
    I just bought a samsung le40r8
    Picture is great, but when I plug in my external audio amp the audio is completely out of sync with the picture.
    In fact, the audio coming out of the phono sockets is out of sync with the internal speakers so if you listen to them both you get a phasey echo effect.
    Is that normal?!
  • vick11 Mar 01, 2008
    new samsung tv and home cinema but after a while they go out of sync...when watching tv is so annoying when sound out of speakers dont match what is being said on tv...
Up front, i copied this from another site, so kudos to the OP there if this works for anyone...
This same problem had been bugging me when I bought my LE37B650, everyone suggested adjusting the delay time on my AV amp but unfortunately mine does not have this function.
Anyway I finally fixed the problem using the following steps
Before you start make a note of your menu settings as you will have to reset them after this procedure
Turn off the TV then press Info -> Menu -> Mute in sequence then turn the TV back on again. This will get you into the secret Service Menu. Go straight to the AUDIO page of the menu. Don't be tempted to fiddle with things in service menu cos you can end up in a right old pickle!
In the AUDIO page you willl notice that there is a time delay set for the internal speakers of 100ms but for some reason this is not set for the external output so all you need do is dial in a 100ms delay there and that should sort the problem. Well it fixed it for me.
Note that as soon as you enter the service menu, all your other standard menu settings are lost and the screen will be set to dynamic for some reason so you have to go through and change everything back after you have done this.
Hope this Helps
Original link: http://www.hometheaterforum.com/forum/thread/280579/audio-delay-on-samsung-650-lcd-tv
This would suggest that you CAN fix the problem with an analog amp.
Also interested to see if a 2 year old thread is alive!
Posted on May 26, 2010
I've finally found the solution to this - after several calls with Samsung.
Basically, the analog audio output is the same signal as the digital, optical output. Both of these signals are sent _ahead_ of the picture, to give a digital amp some time in which to do its audio processing.
Samsung's solution is that I need a digital amp with an 'AV sync' setting, so I can add a bit of delay to the sounds so it waits for the picture to be in sync.
What this means, is that this Samsung TV only works properly with digital amps having 'AV sync', and it cannot work with any analog amp.
Nice.
Posted on Feb 28, 2008
2 Suggested Answers
SOURCE: optical output on tv through dvd home cinema out of sync
I just had the same problem. I returned it to currys and got an exchange because I thought there was somethink wrong with the surround sound itself. I have just tried , and left for ages as it goes out of sync gradually as you said ,the red/white cables (rca , i think it's called)and it works perfectely. You can find the wire for quite cheap just type it in google.
Posted on Oct 15, 2007
I have a sky+ hd box connected to an lg 42LH300 tv through hdmi and an LG HT805SH home cinema through optical cable. Whenever i turn sky over i lose sound and have to turn cinema on/off to sound returns ...
One of the way to connect the whole system is using only HDMI cable version 1.3a. There is audio return channel built into the cable.So you do not have to connect the optic cable.
Sky box to TV using HDMI
LG HT805 to TV using HDMI. Even the Sky box audio will come back to the LG-HT through the audio return path.
Mar 08, 2011 | LG Televison & Video
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
I am unable to connect my sky+ HD box, surround system and LCD tv together.I was only sold a scart cable and HDMI cable with the surround but am sure I need an audio cable or optical cable with it! please...
you need the fibre optical cable, that connects from your dvd to your tv and then you need to set the output on your dvd to digi in, that can be done by pressing aux on cinema system remote or function on the system it self.
i hope this does fix your problem, if it does please rate.
Sep 05, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Connecting a Samsung HT-Z310 home cinema to a Series 5 Samsung TV and Games consoles, will only work with DVD currently. How do I get the cinema system to work for TV and consoles?
Do you have an Optical Audio cable going from the A/V receiver to the TV? If not, you need to get one. Since the HT-Z310 only has HDMI output and no input there is not audio bypass. Once you connect an Optical Audio cable from the receiver to the TV, anything that goes through the TV (cable audio, PS3 or Xbox 360, DVDs, Radio) will go through the receiver, too.
May 28, 2008 | Televison & Video
Not getting sorround sound from my tv
only the hd channels get great surround sound. if your tv has an optical audio out and your surround has the optical in input. then i suggest buying a fiber optic wire for the audio you'll hear a big differance. just hope that the audio stays in sync unlike my cheap *** koss system
Dec 10, 2007 | Samsung HTP-1200 System
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
Optical output
optical output from the tv can only go to an optical input on another device.
hdmi is for picture only.
what tv and home cinema make and models do you have?
Nov 12, 2007 | Samsung HP-R5052 50 in. Plasma HDTV
Sep 17, 2007 | Televison & Video
Set up help!!
Firstly connect your home theatre outpu HDMI to HDMI input1 on the TV. Then connect the PS£ HDMI to the other HDMI input on the TV. Now connected the optical cable from the PS3 to the optical input of the home cinema system. Your should now have surround sound from the PS3 and DVD.
Sep 11, 2007 | Samsung HTP-1200 System
Samsung LE40R72BDX 40 in. HD-Ready LCD Television Logo
1,990 people viewed this question
Jerry Greenberg
Jerry Greenberg
