Question about Canon PowerShot S500 IXUS 500 Digital Camera
Canon ixus 500 digital camera
The memory card door catch has broken and will not stay closed can I buy a new door
  • Anonymous Jul 11, 2008
    I have the same problem my memory card door cover is broken and I am having trouble getting hold of a new one the supplyer wanted to sell me another camera ??
    I am happy with the camera I have where could I get hold af a new part ??
  • fixya950 Aug 21, 2008
    Tiny bit of plastic broken off, currently using a rubber band round the body to keep door shut.
You can buy original/oem spares on US ebay with instructions to fit
Posted on Aug 21, 2008
Hey if this is still usefull...
you dont nescesarly need a new door, there is a small black pin at the very top of the slot on the camera body and a grey piece of plasitic sticking out on the door. The camera wont turn on unless the pin is pushed in (normaly by the piece on the door) so just find a way to keep it pushed in. you wont need a new door.
Posted on Aug 12, 2008
    Problem Solver:
I have never done this, however I have heard that u jut take the camera to the place u bought it from or any other electronic shop and ask for a new catch. If the camera is a common model then parts should be easy to get. This must be quite a common problem I would imagine so I am sure the retailer u bought it from can help, don't forget your proof of purchase,
I can't imagine the new door will be free.
This sort of thing with the door happened to me the other day and I thought I would have to buy a new door, however I was able to get someone else to put it back in place.
Posted on Feb 12, 2008
Canon IXUS 970 IS will not recognise 2GB SD card although it used to do so
The memory card might have been damaged.If it was a problem with your camera it might not have recognized your 32k sd card.
So buy a new sd card.
Jun 10, 2012 | Canon IXUS 970 IS Digital Camera
I bought two new 8GB SDHC memory cards for my canon ixus500. the old memory card is 1GB ad still works but i wanted more memory cards. neither of the two new cards work. they both say memory card error AND...
If your camera is the type that uses SD cards, then your problem is that the camera was developed in 2004 before SDHC cards were invented. Your camera cannot use them.
Sep 15, 2011 | Canon PowerShot S500 IXUS 500 Digital...
Memory card error
Put off the card from your camera, then try to put on again properly and turn on your camera.
If the problem persist, take the memory card in a card reader and plug to your PC, if the PC still recognize it then the memory card still reliable. But if even the PC don't recognize it, I suggest you to buy the new card for your camera.
Hope this help and be kind to rate this answer please.
(^_^)
Jan 06, 2011 | Canon PowerShot S500 IXUS 500 Digital...
The memory card door does not close
Most likely reason is that you have inserted the wrong type of memory card or put the right type in the wrong way around. If the camera is using the memory card alright, then it may be that the catch is broken, but I would have expected you to have called that "door does not stay closed".
Oct 20, 2010 | Olympus EVOLT E-500 Digital Camera
Ixus 500
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Aug 25, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
Canon PowerShot SD 630 Digital Elph problem
Gee that's a bit of bad luck ,
It would be a very fiddly thing to attempt to repair , at the risk of damaging & losing the Memory card function itself...Rendering the camera useless !
Repair by a technician to replace the ejector mechanism is probably possible , not sure what it would cost .
Try increasing the thickness of the card itself very gradually with sticky tape , to make it less likely to fall out easily.
Try not to leave curled edges with the sticky tape , begin & finish the wrap at the center. so it does'nt get Too stuck !!
Mar 27, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon ixus 75 digital camera reset?
The manual states that the battery door was opened during use. Close the battery door and turn it on and off. You may need to push it closed to make sure the battery connections are made.
Mar 21, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Lens cover mechanism is broken
It will need replacement if under warranty
A repair will be almost as expensive as buying a new camera
Jan 21, 2008 | Canon PowerShot SD30 / IXUS i Zoom Digital...
Camera working but really slowly
How long you have been using it ? , its better to change SD card before changing charger or battery try changing SD card may be it take long time to write into card.
Dec 06, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
CF card slot cover
Is the card inserted correctly?
Is the card release button- under the cover locked down?
This needs two pushed to get it to lock in.
Oct 16, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Canon PowerShot S500 IXUS 500 Digital Camera Logo
67 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
