Question about HP Photosmart C6180 All-In-One InkJet Printer
Hp photosmart c6180
Scanner will only produce a dark image ie black with faint colour lines
  • 4 more comments
  • mickos Feb 09, 2008
    ty riztech, yes the problem is the same whilst copying and uses a loada black ink if i print the image,i have reinstalled the machine n reset to factory settings, to no avail
    ty dileep, il get someone who knows what they are doing to try your solution, cheers for that
  • HaroldS Feb 18, 2008
    when i try to use copy ,I put the paper in the top and the ! mark show up with reload document and then restart job
  • teenet May 11, 2010
    Hi all,
    Can someone try to assist me here - I'm really desperate as I can't do any scans or copies - the only thing the AIO does while trying to scan is printing a black page...
    I have managed to take both parts apart - the top cover (that you lift in order to replace the ink) and the base and then I saw the 3 ribbons that are attached to the top cover.
    I had to disconnect them from the main card that is on the right side of the
    printer, but I couldn't find the "head (you see 4 nipples in there-- that is the top of the head assembly). on the bottom of the head is 2 screws, remove them. now the head will come into 4 parts. Nipples, Gasket, nozzle block, and a metal guard".
    If you have any images - that could help.
    I really appreciate your help!!!
    THANKS!!!
  • Mohammed Rizwan
    Mohammed Rizwan May 11, 2010
    As i had 18 months experiance as Tech support Engineer in HP All in one Printers, Newly joined in Fixya..
    I wanna know whether while copying u get the same result too?
  • Anonymous Mar 21, 2014
    DARK COPIES
  • 983 Answers
You are good at taking things apart and not destroying them, then the problem can usually be fixed easily.
Remove the ink carts.
on either side of the carrage there is a screw, remove both of them.
CAREFULLY slide out the silver bar those screws are holding. Be sure to note its orentation for putting the thing back in later.
also carefully remove the silver "fingers".
remove the black clip/cover on the right side of the carrage that covers the ribbon cables.
lift the head (you see 4 nipples in there-- that is the top of the head assembly)
gently pull out the ribbon cables.
now the head will come into 4 parts. Nipples, Gasket, nozzle block, and a metal guard.
get some windex with amonia.
soak the parts for a day or 2.
blot dry, then let it set for atleast 2 days to be sure it is COMPLETELY dry.
reassemble, charge the ink, do the printers head cleaning, and boom. back in business.
this works 90% of the time
Posted on Feb 09, 2008
New black very faint
1. hope you have not touched the contacts or head those protected by pink tape.
2. or the ink is dried up
Replacing Cartridge HP Photosmart C4280 All in One Printer
Apr 06, 2016 | HP Photosmart C4280 Aio Printer
Hi Folks, Sorry to bother you but i have HP 2575 all in one for past 3 years,and until now had no problems..I recently changed my colour ink cartridge cos the old one indicating low toner and some colours...
Try to clean the cartridges by taking them out and trying aligning the cartridges again... try the alignment if you have any software named as image zone or solution center
Oct 21, 2010 | HP Photosmart 2575 All-In-One Printer,...
My HP C4480 scanner only returns a black image (on
Did you repaired old drivers? if so first uninstall your products drivers and also its folders from program files, then uninstall "wrong update" and reinstall scanner. sometimes built in scanning modules comes wrong but everything works with original scanning software, use different software to scan and some of them may work perfectlly.
Feb 20, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Scanning slides produces black images. Slide
Make sure the white document matt from uner the lid has been removed. Also in Epson scan make sure you have changed the document type from reflective to Film and Colour positive.
Jul 03, 2009 | Epson Perfection V350 Flatbed Scanner
All copies and scanner outputs result in a totally black image
hi,
its could be hardware issue, if you tell me which printer, then we can try some reset on that machine..........
Regards,  raj_p5983
Jan 23, 2009 | HP PhotoSmart C4180 All-in-One Color...
How do I scan a 35mm film negative with my HP PhotoSmart C6180?
I regret to inform that hp Photosmart C6180 does not support scanning negatives.
Regards,
Sagarjd
Nov 19, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printer not printing properly
When you changed the cartridges, the printer automatically prits a test / calibration page. This page must be placed in the scanner, then you have to press the "scan" key (the green one). It will calibrate an align the system. Then you'll be able to print.
May 03, 2008 | Office Equipment & Supplies
HP Photosmart C6180 All-In-One InkJet Printer Logo
1,836 people viewed this question
Ben Johnson
