HP 1300 I just replace the fuser sleeve but the printer now is not pulling the paper. the Orange LED keeps on blinking. please advice
  • jbt18702 Aug 30, 2008
    I am trying to print 4x6 photos. I loaded the photo tray but the paper does not pull through. Then the blinking light comes on and tells me to load the main paper tray
  • 39 Answers
It sounds like your formatter board is damaged. This is the board that your printer cable/network cable plug into. I would also reseat your toner cartridge.
You might be able to find a broken 1300 on ebay for cheap money.
Good luck my friend,
SeekPCRepair
Posted on Feb 09, 2008
  • SeekPCRepair DotCom
    SeekPCRepair DotCom Feb 12, 2008
    Hello:
    How is this innappropriate? If you didn't like my solution...that's OK. But why the bad rating?
    I am sorry if my solution didn't solve your particular issue.
    Seek PC Repair
HP 1300 -- toner is smudged along the left edge after crinkly sound
Hi:
This is a common problem with some HP printers. The fuser sleeve inside the fuser assembly gets torn along the edge and print can no longer be fused in that area and the paper will crinkle there. The only solution would be to replace the fuser, which for that printer it would not be worth repairing.
Andrew
Jun 08, 2012 | HP LaserJet 1300 Printer
2 pages are accrdianed in the very back of the printer. I cannot see a way to open to get them out. Is this a case where I have to just pick them out?
Paper might be roller on teflon sleeve, take out fuser from the printer, remove paper gently to avoid damage to teflon, after removing the paper observe that is there toner particles deposited on teflon sleeve, if observed replace the teflon sleeve,other wise this problem will repeats again & again.
Note: for this process technical skills required.
Sep 24, 2011 | HP LaserJet 1300 Printer
I have hp lj 1300 printer befor problem fuser sleeve damage that is repalacing and fixing but now not working only read light bilnking how can repair sir
red light blinking gnerally for
1.door open
2.no cartridge
3.fuser element blown( measure fuser element with volt meater)
4.sensor error
and so many
these are the mejor.
Jan 09, 2011 | HP LaserJet 1300 Printer
Black marks on paper looks like a tear in the back roller. Is there a replacement roller. Cant seem to get it apart to see what I need
If you are talking about the fuser, yes there is a fuser sleeve you can buy from eBay, if you knows how to fix printers. If not then buy a refurbished fuser and ask for instructions on how to replace it.
Jul 12, 2010 | HP LaserJet 1300 Printer
My Hp 1300 laserjet printer doesnt get ready after initializing but giving orange blinking light, what could be the solution because i have checked the toner is in properly .
Remove the paper and re-loaded it, if it still giving you the blinking, turn it off and hold the go key down while turning it on then release it, this should rest any errors, worse case you have a bad fuser.
Jun 15, 2010 | HP LaserJet 1300 Printer
HP LaserJet 1300 Printer: black vertical lines on both side of paper
for this model.. first check if your toner cart is good.. if it's good.. then the cause of your problem is your printer fuser sleeve.. fuser is where the paper is heated up.. and when you start having dirty line print out.. it show that the fuser sleeve(top part of the fuser) is torn..
if you send to HP.. they will probably charge you the whole fuser.. which is expensive.. you can always replace the fuser sleeve only..and it cost not much.. you can always replace it by yourself if you are able to remove the fuser unit..other thing.when you switch on the printer, can you hear sound like paper been crumble at the exit of the printer?
May 23, 2010 | HP LaserJet 1300 Printer
Paper comes out wrinkled & dark on one side
Your fuser is worn out. It can be replaced as an assembly, but sadly it is actually less expensive to replace the printer these days.
The wrinkling is due to a worn pressure roller, and the darkness is from the combination of a worn fuser sleeve, and the worn pressure roller 9all located within the fuser)
Jul 10, 2009 | HP LaserJet 1300 Printer
Attention Light Is Rapidly Blinking Orange
sorry I got it, usually you may try:
1) check all paper road no paper inside include the area betweem input tray and cartridge unit the area wetween cartridge and fuser unit and output tray.
2) check 4 sensor input sensor near the input tray roller, marging sensor between input roller and cartridge unit, cartridge sensor at oneside of cartridge unit body, fuser sensor near fuser roller. usually need to clean or adjustment the position.
3) check input roller and cartridge unit and fuser unit at running condition when the power on.
anyone nothing running show error light blink, also show the hardware trouble if all sensors are normal.
Dec 24, 2008 | HP LaserJet 1300 Printer
HP 1300 makes noise and wrinkles paper
open the back door. see if there are small Pisces of plastic the color will brown or gray. if there is then the fuser sleeve has worn out. very common problem. part is a bout $40.00.
Dec 18, 2008 | HP LaserJet 1300 Printer
HP 1300 LJ Fuser Film
If you didn't have the orange light to start with and were replacing the sleeve due to a torn or damaged sleeve it sounds like you haven't plugged everything back in. The Error is an electrical fault with the fuser circuit.
Verify that all wires are plugged back in. Two areas to pay specific attention to are as follows. (1.) BOTH slide clips witth wires that you removed on the upper fuser edges to mount the new sleeve. Thats the connections for the ceramic element. If you get to having to uninstall and check the fuser, put an ohm meter on both ends of the element to ensure it's not shorted. My meter when on ohms has a beep when the leads are touched together when the meter is measuring ohms. Check for the beep when touching both ends of the element and that will prove the element good.
(2) On the board in the base of the machine, there are some plug in connections on the lower board very close to the rear edge and just about centered left to right. It's a cluster of about 3 or 4. Unplug the connections and pay close attention to the height of the pins inside the connection. One of those connections has a nasty habit of the pins slidding through to the other side and not making good contact. If I remember right its the right hand connection in the cluster or the one next to the right one. You can use the connections rest to it as a visual referance for the height. If the pin or pins have pushed down, carefully pull them back up with needle nose pliers or tweezers and replug the connection back in.
Hope that helps you. Just in case, heres a free manual PDF link to use to resolve. It's a 1200 manual as the 1300 wasn't listed but the processes are identical. Most of the parts are the same but check first before ordering any parts.
http://www.feedroller.com/Store/Service%20Manual/LASERJET%201200%20Series%20Service%20Manual.pdf
Jul 16, 2008 | HP LaserJet 1300 Printer
128 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
