Trying to install a new 50
Hiya, can someone out there help me?
I have connected up the Plasma to the Home cinema kit, with an HDMI lead.
The problem that Im having is getting all my other equipemnt hooked up, so that it all works & hear it through the Home cinema kit.
To my mind (although I'm not sure! lol) if everything ends up working, through the tv, then you should get the sound through the home cinema kit for everything, right?
here's what else I'm trying to hook up.
Sky + (satellite TV), a DVD RW, and a VCR. Before installing everything else (including the Home cinema with DVD) I had perfect volume etc on the TV.
I then had everything else hooked up, it all worked, but, no volume from the home cinema kit, except for when you played a dvd in the home cinema kit. There was no volume from the Sky+ at all.
Arghhhhh!!!!!!!!!!!!! My husband is a technophobe, so unfortunately, its all down to me! lol
Can you tell me, is there a specific way that it should all be connected to each other, & then to TV or home cinema kit? (I did think the HDMI lead from TV to home cinema would take care of that part)
The VCR is a real basic Sony with two Scart's, & the DVD RW is Akura (a cheap brand, but worked ok when in my old set up)
help.........in real layman's terms please! lol
thanks nicky x
  • nickynok Feb 09, 2008
    The TV is a Samsung PS50Q97HD & digital home cinema system is Samsung HTX200.
    Thanks
  • Anne Billingham Jun 01, 2008
    Hi, I have just bought a series 6 samsung plasma tv and a samsung ht-x710 home cinema.
    Currys sold me an optical cable (which I fitted between my sky+ box and the home cinema box) It sounds great when playing a dvd. but when trying to watch sky I get no sound from the home cinema or the tv, until I turn off the home cinema, then I get sound from the tv only.
    Have I got a dodgy optical cable, or have I set it up wrong?
    Please help a damsel in distress.
    Anne
Hi well i had the same problem and it took me a while to figure it out.
I have a audio out on my samsung television and i connected that to the Aux 2 on my DVD player that came with the Home Cinema System. If i set the DVD player on Aux 2 i can have the sound of any connections i have made to the television including my Wii, a lite on DVD recorder and off course my sky and the original DVD player of the cinema system.
there is a little bug though if i change to aux 2 after i have switched other system on first it takes a second or two before it comes on 2-1 speakers. Also the sound has two controls one for TV and other for the DVD. I can switch TV volume off and still can hear the Home Cinema system. So i require to set two different volumes to get the right setting. i can live with that.
hope the information is useful.
Posted on Aug 26, 2008
Have the same set up as nickynox and the solution is you need to connect the audio through a optical cable from the home cinema to the tv. the home cinema has to be on setting AUX to get sound from tv and sat :)
Posted on Jun 19, 2008
    Problem Solver:
  • 13 Answers
A good way to go is to connect the home cinema kit staight to the tv though phono leads, see if your tv has a phono in and out this must not be a av socket. you should then connect it in to your cinema kit so what ever you watch comes though ur cinema system
hope this helps
Posted on Feb 10, 2008
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
How to connect leads through home cinema system and virgin emdia box
Either use a good quality HDMI interconnect make sure that its gold plated check out this FixYa Tip here for further help
http://www.fixya.com/support/r4565785-1080i_1080p_cable_hdmi_version_need
Some home cinema systems still have a SCART lead instead of the HDMI the latter being the better option.
Dec 06, 2010 | Panasonic Televison & Video
CONNECTING XBOX 360 TO SAMSUNG HOME CINEMA SYSTEM VIA OPTICAL
For some reason you can only have the component leads with optical cable, if you put hdmi cable in there is no connection for the opticle cable out.
Jun 10, 2009 | Microsoft Xbox 360 Console
Help with connecting home cinema to xbox
if your tv supports this. go to ebay type in "hdmi" buy one for around $10.00 plug into xbox. set your tv to which port you have ,(if you have more then one). bingo,bango ,your done.
"no hdmi"? and you have com. on your tv. plug corrosponding color plugs for component ,L&R audio plugs .
change tv to comp.( not video) your done
Jan 30, 2009 | Audio Players & Recorders
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Connecting up a home cinema kit
Heya,
The good news is that the monitor and the Home cinema can be connected but you need to get a cable. Bad news is the cable did not come with it.
The monitor has D-SUB, DVI-D
so you need a HDMI to DVI-D connector then you need another cable to route the audio to the system which you should have.
like ebay item
Item number: 220341264176Hope it helps
Jan 10, 2009 | Wharfedale Televison & Video
Connections
conect ps3 audio throw optical
Dec 26, 2007 | LG MU-50PX10C 50 in. Plasma HDTV
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
Optical output
optical output from the tv can only go to an optical input on another device.
hdmi is for picture only.
what tv and home cinema make and models do you have?
Nov 12, 2007 | Samsung HP-R5052 50 in. Plasma HDTV
Home cinema/Viera link problem
Turn everything off and disconnect from mains.
Wait a few minutes.
Disconnect HDMI cable.
Turn on TV and DVD.
Connect cable.
If this does not work use a cable of different spec.
I had the same problem and now mine works .
Good luck.
T.P.
Oct 06, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Televison & Video Logo
448 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
