Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Acessing the router
I tried to set my router to act as an access point to another network. However after that I could not access the router via lan cable. I tried different computers, different cables, and any IP address that may have been assigned to the router, all without sucess. So I tried to reset the router to factory settings with the small button at the back. I still cannot get into it! I'm not sure if I am using the right IP address or if the router retained some of the previous settings. I cannot find the box or instructions that it came with either :( so I have not been able to find the original information.
  • Kroova Feb 16, 2008
    Thanks for the input guys! Turns out the cables were in the right places, but there were two other problems. The first was the reset didn't work - needed to hold it down for much longer and then it seemed to work. After that I was able to figure out the factory settings and get back in to fix the network. The second was that the ADSL connection wasn't coming through my modem and, after much experimentation, that was because the power adapter had been changed over by mistake. I'm not sure what the difference was between the two adapters (different brands) but once they were put back in their proper places the connection worked again.
  • Mohammed Rizwan
    Mohammed Rizwan May 11, 2010
    Are u able to TELNET the Router?If u can telnet your router, please let me know!
    Thank You
I had the same problem and can definitely confirm that resetting to factory settings is the best and only option I had. Not sure if you need to contact your isp as theu need to update their end with new settings. Let us know how you get on.
Posted on Feb 13, 2008
  • 178 Answers
Ok i know what you are doing. You have to run a cable from the first router out of one port to the access point labeled internet. But make sure you connect your access point to your computer first and set it up in the router setup page. I sell and use belkin myself and if you need any futher questions let me know
Posted on Feb 11, 2008
I have just bought an acer iconia w3-810. When starting the set up process I can't connect to the Internet. It says I have no connection to internet. Tried setting up a network and it can't find my...
try connecting to another location like the public library. it could be that your router security setting may be set too high.
http://brandzone.bz/files/catalog/upload/5/8/planshet-acer-iconia-w3-en.pdf
Wireless networks - 29
Installation speed and simplicity Installing a wireless LAN system can be fast and easy and eliminates the need to pull cables through walls and ceilings. Components of a wireless LAN To set up your Wireless network at home you need to have the following:
Access point (router)
Access points (routers) are two-way transceivers that broadcast data into the surrounding environment. Access points act as a mediator between wired and wireless network. Most routers have a built-in DSL modem that will allow you access to a high speed DSL internet connection. The ISP (Internet Service Provider) you have chosen normally supplies a modem/router with the subscription to their services. Read carefully the documentation supplied
with your Access point/router for detailed setup instructions
Feb 03, 2015 | Tablets & eReaders
I am trying to connect my belkin surf n300 to my existing network. I want to use it as an access point so i can plug my TV in via ethernet cable to the Lan port. However i am having problems setting it...
You will need a crossover cable to connect the two routers. They are different than standard LAN CAT cables and are available here:
ONLY THE ORANGE ONES ARE CROSSOVER CABLES
http://goo.gl/tRvLI
Jul 28, 2011 | Belkin COMPONENTS WIRELESS ROUTER N+...
How do i set bridge mode?
Depends if you need a wireless or wired bridge?
Here is some info for you.
Infrastructure Mode
With a wireless Access Point, you can operate the wireless LAN in the infrastructure mode. This
mode provides wireless connectivity to multiple wireless network devices within a fixed range or
area of coverage, interacting with wireless nodes via an antenna.
In the infrastructure mode, the wireless access point converts airwave data into wired Ethernet
data, acting as a bridge between the wired LAN and wireless clients. Connecting multiple Access
Points via a wired Ethernet backbone can further extend the wireless network coverage. As a
mobile computing device moves out of the range of one access point, it moves into the range of
another. As a result, wireless clients can freely roam from one Access Point domain to another and
still maintain seamless network connection.
Wireless Bridging Overview
Using Wireless Router as a Wireless Access Point
May 03, 2011 | NetGear RangeMax WPN824 Router
I don't know how to reinstall the linksys access point!!! Our wireless network that we made simply disappeared, so I'm trying to re-make one. However, when I tried that with a flash drive, it couldn't work...
T
o access the Access Points Setup, and the LAN IP address has not changed, then computer must have an IP address of 192.168.1.XXX. If the Access Point is plugged in via Ethernet to a Linksys Router and the computer is also connected a Linksys router via Ethernet, then the PC should already have a correct IP address (unless the LAN IP Address of the Router has been changed). If unsure, please assign the computer a Static IP Address so it will have an IP address in the same range as the Access Points IP Address.
If the Access Point is being connected to a hub/switch/router via Ethernet, then use the cable that was provided with Access Point. If the Access Point is being connected to the computer directly, then a Cross Over cable must be used. Cross over cables can be purchased at most electronic stores.
    Remember: When ever a change is made in the Setup of the Access Point, the Apply button must be used to save the settings to the Access Point.
  1. Open a web browser (such as Internet Explorer or Netscape)
  2. When the browser opens, go to the "Address" bar and input the IP address of the Access Point.
      Default IP addresses:
    • WAP11 v2.8 - 192.168.1.251
    • WAP54G v1.1 - 192.168.1.245
  3. A "User Name" and "Password" prompt will appear, leave the "User Name" field blank and input the Access Points password (The default password of a Linksys Access Point is admin) into the "Password" field.
May 14, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Can't connect to my router
Try this;
Just set it again via wired connection or LAN. Access it via Network Connections, and under Network connection look for for your LAN. Right click Local area connection,click properties, then highlight Internet Protocol(TCP/IP), click properties. Under General choose "Use the following IP Address ".
Input on IP address you should have router tutorial. Commonly its default is 192.168.1.1
Subnest Mask 255.255.255.0
Default gateway 192.168.1.2
Under it choose " Use the following DNS server address"
Input DNS address DNS of your ISP
Click ok
goto Inernet browser tab input 192.168.1.1 this will direct you to router configuration setting input its user and pass. If unchanged see tutorial of your router or at the bottom of the router. Then you can change setting of your router.
Hope it helps.
Apr 08, 2009 | Zyxel Prestige 660R Router (P660R)
Netgear FWG114P Print Sever not functioning on upper level of LAN
if you set your dynalink's dhcp list up to a certain number (example: .1-.99). connect cat5 cable from dynalink lan port, into print server lan port. make sure print server can be setup as access point. if so, turn access point setting to on. make print server static ip address the next number outside of dhcp range (example: .100).
.100 ip address is the port number you should then be printing to, using a tcp/ip port.
if print server can be set up this way, then it now becomes wireless access point for all wireless devices. i am assuming, since you didn't mention it, that the dynalink is NOT wireless. if it is, the the print server just becomes another device on your existig network, taking the place of the network adapter the printer doesn't have. just set it up the same way you would set up another workstation on the network. except, make it static.
Apr 02, 2009 | NetGear FWG114P Router (FWG114PAU)
D-LINK DI-514 LAN Ports not working
  1. Connect a cable from your PC to one of the four plugs. Not the WAN port.
  2. Setup the wireless the way you want it.
  3. Then give this router a different IP, like 192.168.0.2
  4. Then you have to disable the DHCP server in the router (keep in mind now you have to set your desktop or laptop that is conencted to it to a static IP to still communicate with the router)
  5. Once this is done just plug you existing network into one of the four ports. Not the WAN port.
  6. It will now act as a wirelessa access point.
Althoug this is doable it is not recommended as this router is a pile of **** and the wireless is crappy.
I would suggest a dedicated wireless access point.
Dec 06, 2008 | D-Link DI 514 Wireless Router (DI-514)
Unkown IP addresses
try to go to command promt and try to type this.
ipconfig
after you see the ip address type this on again.
ipconfig /renew
then type exit
try to restart your computer
Mar 26, 2008 | NetGear DG834G Router
How to use this unit as a Access Point for an existing Wireless Home Network
set the second router through the web menus to a different ip address, cant have 2 devices on the same (default) 192.168.0.1 address, try 192.168.0.2 (example only) to stop data collisions
connect by cable secondary router lan port 1 to the primary router lan port 4 (any lan port to any lan port),
drag secondary router upstairs on its cable and install it wherever you want
set two routers on different channels.
set all wep settings on both routers the same.
set all pcs to 'auto channel' select
wireless adaptors in pcs will then select strongest signal at any point and transmit thru that router
Feb 15, 2008 | D-Link AirPlus DI-614+ Wireless Router
Netgear WG602 wireless router,
Hi, Assuming that the WG602 is fully operational, when you did a hard reset, the router reverted to its original factory setting as you posted. The default pre-configuration: act as a DHCP client; if the WG602 does not find a DHCP server on the Ethernet LAN, it defaults to this IP configuration: DHCP Client - Enable IP Address ? 192.168.0.227 IP Subnet Mask ? 255.255.255.0 Gateway ? 0.0.0.0 Your PC need to be connected via a LAN cable to one of the Ethernet ports of the AP/Router to be able to configure it again to your desired network settings. Further it is necessary likewise to manually configure the connected PC's networking configuration to match the router. Manually configure your PC's IP Address to 192.168.0.228, Subnet Mask ? 255.255.255.0, Gateway - 192.168.0.227. You can now try configuring the router through its web interface (192.168.0.227). This is better explained in the user's manual available at the Netgear site ( Hope this be of some help/idea. Post back should you need additional information. Good luck and kind regards.
Oct 03, 2007 | NetGear WG602 802.11g/b Wireless Access...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
96 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
