Question about Canon ImageRUNNER 1670F Copier
Eror 355 how i can resolve.
Please help me how to resolve this problem,i replace DC controller already with counter PCB, Dimm rom, but still E355.same as before please give me your best advise or instruction thanks. ...joey...
  • Canon Expert
  • 1,326 Answers
Enter service mode(additional funcation # ) then scroll down to item 12 ( clear ) and press the set key then scroll to ERR and press the SET key twice then the display should display Clear OK and it should return to the stand by mode. And that is it. Done
Posted on Feb 11, 2008
Error code e0000674 solution to resolve it
an error has occured in communication between fax controll PCB and main controller PCB.Check the connection of the cable between the fax controll PCB and main controller PCB.rEPLACE THE rom dimm of the fax control PCB.Replace the fax controlPCB.Replace the main controller PCB.
Jan 29, 2015 | Canon ImageRUNNER 3570 Copier/Printer
Hi . my copier is aficio 700 .The error is sc 900 .that relate to electical counter .I Check the connection between the NVRAM and controller. Replace the NVRAM. Replace the controller. but the error not...
Other possibilities
A095/A096/A097
SC 900
[SC900] - replace fuse 8 0 4, DC power supply
A109/A172/A199
SC 900
[SC900] - replace black total counter
A133/A195/A217
SC 900
[SC900] - CN4 0 3 SCU PCB, poor connection
A133/A195/A217
SC 900
[SC900] - replace SCU PCB, see FSM page 5 64 for rom and dip switch info
A193/A224/A264
SC 900
Total counter error: Fuse #5 on PSU blown
A193/A224/A264
SC 900
Total counter error: Total counter defective
A229
SC 900
[SC900] - NV ram defective
A230/A231/A232
SC 900
[SC900] - re load copier firmware
A246/A247/A248
SC 900
[SC900] - replace counter harness
A292/A293/B098
SC 900
Electrical counter fail - Replace Mechanical Counter
A292/A293/B098
SC 900
Electronic counter error - Replace NVRAM-B098 9590.
A292/A293/B098
SC 900
[SC900] - replace IOB PCB
A294/A295
SC 900
[SC900] - NVRAM defective
B010/B188
SC 900
Electrical total counter error - NVRAM data defective
Jan 28, 2011 | Ricoh Aficio 450 Copier
Hi canon IR 1510 error E 355 what is it? Please help me
Hi
On general canon machines error code of E355 indicates, 'When turning on the power, inconsistency among the serial No. PCB, the controller PCB (SRAM), and the counter memory PCB is detected.'
If this helps?
Jan 19, 2011 | Canon iR 2016i Black and White Copier
Hp laserjet 3550 keeps on giving me error message of code 59.99 what do i do to solve the problem please thank you.
ur developing motor gears worn out replace them ur problem will be resolved...............
and
This error also shows the faulty secondary transfer engaging mechanism.
1. Faulty secondary transfer engagement sensor.
Action: Replace the secondary transfer engagement sensor.
2. Faulty secondary transfer engaging solenoid.
Action: Replace the secondary transfer engaging solenoid.
3. Faulty feed motor.
Action: Replace the feed motor.
4. Faulty DC controller PCB
Action: Replace the DC controller PCB.
good luck, and do rate the solution if helps
Nov 30, 2010 | HP LaserJet 3550 Printer
DEAR I AM FACING PROBLEM IN IR2000 ROM ERROR SO I NEED FIRMWARE FOR THIS MODEL OR GIVE ME A SOLUTION. THANKS
When the ROM Error message is displayed on the control panel, this will indicate an issue with the Flash DIMM on the Image Processor PCB.
re-flash the system software/or replace the DIMM Assembly.
When replacing the DIMM, you may be required to flash the system software to it's latest version.
iR 1600/2000 FG6-9978-000, Dimm assembly.
As a temporary work around, power on the iR while holding down the STOP key. This may boot the iR to a ready state and copies can be made.
Service Mode=Additional Functions #
Aug 05, 2010 | Canon iR 1600 Laser Photo Printer
Error message: ROM ERROR, what does this mean?
Error :
ROM Error message
Workaround :
In attempting to resolve the issue, reflash the system software for that specific model. If system software does not resolve the error, replace the DIMM Assembly. When replacing the DIMM, you may be required to flash the system software toit's latest version.
Jun 05, 2009 | Canon imageRUNNER 2000 Copier
MY CANON PHOTOCOPIER SHOW EO30
E030 (The total copy counter fails to operate.)
1)Turn OFF the power, and remove
J104B from the DC controller
PCB. Set the tester range to
x1KW, and measure the
resistance between J104B-2 and
J104B-1. Is it about 500W? NO
Check the wiring from
the DC controller PCB to
the total copy counter; if
normal, replace the total
copy counter.
2)Connect J104B to the DC
controller PCB, and turn ON the
power. Set the tester range to 30
VDC. Does the voltage between
104B-2 (+) and J104A-6 (–) on the
DC controller change from about
24 to about 0 and then to about
24 V when the Copy Start key is
pressed? YES =replace the totalcopy counter.
NO =Replace the DCcontroller PCB
Apr 03, 2009 | Canon NP 6035 Copier
Hi, i have 2pcs of canon iR2016 Digital copiers which displays error codes of E246 AND E247. these errors are not in the service manual, please help
Sir i am a Canon trained tech. I just checked our website and my service information. I found the following. I suspect someone has been working on these machines or swapped some parts around.
Page 1 of 2
MODELS AFFECTED / SERIAL NUMBERS AFFECTED:
Digital Copiers, Including All imageRUNNER Products
SUBJECT:
Information About The New Soft Counter Circuits
GENERAL TECHNICAL INFORMATION
GENERAL:
This Technical Publication presents information about the new Soft Counter circuit that replaces the mechanical counter
used in the past. There are three (3) PCB’s associated with the new Soft Counter circuit; the Counter Memory PCB,
Main Controller PCB and the Serial Number PCB. A description of their function is provided below. Use this
document as a reference for current and future models that use the Soft Counter circuit.
Counter Memory PCB
On the latest Canon digital copiers, such as the imageRUNNER 5000, imageRUNNER 8500 and imageRUNNER 2200
series, there are no mechanical counters. Instead there is a Counter Memory PCB. This PCB is usually mounted on the
Main Controller PCB with one screw. The Counter Memory PCB is imprinted with the serial number of the machine
the first time power is turned ON and cannot be moved to another machine. Attempting to do so will generate an E246
error code. In the event of a Counter Memory PCB failure, a new one from stock (see Note 4) can be installed into the
machine. At that point the Main Controller PCB will transfer its present total count as indicated in “Counter Check” on
the control panel (recorded the last time power was turned OFF) to the new Counter Memory PCB and the total counter
will increment from that count on. Never attempt to operate a machine without the Counter Memory PCB
installed!
This may generate an E245 code, which can only be cleared by “zeroing out” the Main Controller PCB by
one of our A.P.R.F.’s (Authorized Parts Repair Facilities).
Main Controller PCB
The Main Controller PCB, aside from performing other tasks, retains the total count by means of SRAM with a battery
back up after power has been turned OFF. If, however, the Main Controller PCB has been replaced with either a new
one or a used one, it will read in and record the total count from the Counter Memory PCB retained the last time power
was turned OFF. The total count will then increment from that count on.
Note 1:
Even though the total count will be the correct value for that machine after replacing the Main Controller, the soft
counters in Service Mode will not. If a new Main Controller was used for the replacement, then all soft counters in
Service Mode (service counters in “Counter Mode”) will be zero. If, on the other hand, a used Main Controller was
used for this replacement, the soft counters previously recorded on that PCB would be shown. At that point it is
advisable to clear these values in Service Mode using Function>Clear>CNT-MCON.
All Main Controllers sent to our A.P.R.F.’s for repair will be “zeroed out” before being sent back to the dealer.
Page 2 of 2
GTI-T151
04-30-02 GT I
Note 2:
The Counter Memory PCB and the Main Controller PCB should never be replaced simultaneously!
This will
generate an E354 code and assistance from the Canon Reseller Technical Support Center Hotline will be required. If
the Main Controller is sent to one of our A.P.R.F.’s for repair, you must remove the Counter Memory PCB
before sending it out!
Failure to do so will only increase down time for your customer.
Note 3:
If the Main Controller PCB is replaced, ensure that connector J1023 is connected. If it is not, an E350 will be
generated.
Serial Number PCB
The Serial Number PCB’s main function is to identify the machine’s serial number. This PCB cannot be moved to
another machine.
Attempting to do so will generate an E355 and assistance from the Canon Reseller TechnicalError codes not listed in the Service Manual:
There are various error codes that are not listed in the Service Manual. Canon U.S.A., Inc. reserves the right to treat
these error codes as Proprietary Information. If you encounter any of the following error codes, contact your Canon
E245 E246 E247 E350 E354 E355
Note 4:
Please be advised that Canon U.S.A., Inc. treats the Counter Memory PCB and Serial Number PCB as “restricted” parts.
When a dealer orders these components they will be asked to provide the reason for their replacement, and the original
PCB will have to be returned to Canon U.S.A., Inc. for evaluation.
Jan 07, 2009 | Office Equipment & Supplies
Ir 8500 E000246
A E240 is the reg. clutch or the DC controller or a loose wire, a E246 to me would be a problem with the DC controler or a loose wire going to the pcb. And the E225 or E226 has something to do with the counter pcb or the DC controler pcb. Also I would check the rom version of the copier. Also, was that the problem you went there for?? If not retrase your steps..
Oct 01, 2008 | Canon imageRUNNER 8500 Copier
ROM Error for Canon Image Runner 2010F
re-flash the system software for that specific model. If system software does not resolve the error, replace the DIMM Assembly. When replacing the DIMM, you may be required to flash the system software to it's latest version.
iR 2010F FG6-9454-000, Dimm assembly.
Mar 12, 2008 | Canon USA - COPIERS - ImageRUNNER 2010F...
Canon ImageRUNNER 1670F Copier Logo
275 people viewed this question
old marine
old marine
