Question about Fisher and Paykel E522BRXFD Stainless Steel Bottom Freezer Refrigerator
Fischer and paykle E4028
The fridge seems warm but the freezer seems ok, the digital thermometer is lit half way i am wondering how i can get it to get colder in the fridge?
i would appreciate some advice to know what i should do.
Thanks.
Pam.
  • Mister Spock Mar 05, 2008
    My fridge was warm but freezer was ok,i found the channels which suck the cold air up to fridge compartment fully frozen up (bloody great for a frost free fridge).after i melted all the ice out with a ladies hair dryer (took 4 hrs) i started it up & all was well.Next day a continuous beeping was coming from back of fridge,after talking to fridge techs (a mission in itself) at F&P it was ascertained i had possibly melted the thermal fuses around the evaparator in the freezer compartment( it takes 70 degrees to do this), have ordered part & will see what happens.Overall as a patriotic kiwi i think i'll be taking consumer magazines advice & by an asin LG electronics fridge/freezer as F&P have no post sale backup a couple of years down the track and obviously dont have a very good product.
  • 943 Answers
Hi thanks for the question the problem is the fan motor in the freezer its not blowing cod air the the fridge side look at this part first. thanks the appliance doc
Posted on Sep 17, 2008
Amana fridge is not cold but freezer is working
If freezer is ok and cooling ( 5 degrees or less) one thing you might want to check is that the flow of cold air to refrigerator is not obstructed by the items in your freezer. The ductwork has to be available. Also check the opening of the damper if fridge is not cold enough. And is the fan operating at full speed - are the bearings dirty and slowing it down?
Also check your freezer temp - there are degrees of freezing. Water freezes at 32 degrees but a good freezer should go down to about zero. And the colder your freezer air is the colder your fridge will be.
Sep 21, 2017 | Refrigerators
GSL22JFRE BS Freezer OK but not Fridge ??
Clean the condenser grille, rear and under unit
Apr 24, 2012 | GE GSL22JFR Side by Side Refrigerator
Freezer 8 degrees, fridge 48 degrees. Fridge fan was replaced and worked ok for a month.
Sounds like both are about 8 degrees over optimum, if your thermometer is accurate. Can your freezer keep ice cream hard?
Usually, one control affects the temps of both chambers, and the other affects the balance between them. Your balance seems ok, so if you're unable to set it to run longer/colder overall, and your ice cream is not firm/hard, this could indicate a more serious problem. Airflow is important, so you should avoid loading in such a manner that restricts airflow within either side, and verify that fans run when door switches are actuated.
May 18, 2011 | Samsung RS265LABP Side by Side...
Fridge not cooling, Freezer is working (upside down fridge/freezer)
We experienced a smilar problem with your Fisher & Paykle fridge/freezer.
The fan that sends cold air to the Fridge section of the appliance didnt appear to be working leaving the Fridge poorly cooled.
I suggest the first step is to turn the fridge off and leave it to totally defrost.
Build up in ice in the freezer section seemed to have an impact on the proper operation of the fan which seems to relie on a thermostat for its operation.
Having defrosted and cleaned the fridge the problem was solved.
The fans have a delay before switching on after the door is closed. Place a magnet over the door sensor switch and wait to see if the fan works.
The problem could be that the unit has iced over itself over a period of time and defrosting it could solve the problem.
Feb 28, 2011 | Fisher and Paykel Active Smart E522B...
GE bottom freezer model PDS22MBRBWW gets too warm
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE Profile PDS22SBRR Stainless Steel...
My Maytag fridge is not working, but my freezer works fine. What do I do? The freezer is on the bottom, with the fridge being on top
Hi
Do you have any ice cream in the freezer? If it is soft than the freezer is also too warm. If you do not have icecream then you will need a thermometer to check freezer temps. Freezer needs to be 10 degrees F or colder down to -10. fridge should be 34-38... Sometimes freezer temps can seem cooler than they are with out a thermometer to test it. Also look for frosting up inside the freezer. Check that your door seals are in good condition. check that doors are closing completely.
Please let me know If I can help further.
Apr 14, 2010 | Maytag MBF2556HEW / MBF2556HEB /...
Zanussi fridge freezer alarm keeps sounding
If the refrigerator and freezer are both working properly. Then the only problem would be the alarm, It's either the placement of the alarm thermometer or the alarm thermometer is stuck closed.
Mar 15, 2010 | Freezers
F & P E4028
A bad thermostat. Your cooling is out of control it is the thermostat that controls the frig. The thermostat is behind the knob that lets you turn up or down the temp. Most of the time two screws to take loose behind the knob. It should just pull off.
Dec 15, 2009 | Fisher and Paykel E522BRXFD Stainless...
Refrigerator is not working, freezer is working
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 08, 2009 | Maytag MFD2560HES Bottom Freezer French...
Fisher and Paykel E522BRXFD Stainless Steel Bottom Freezer Refrigerator Logo
422 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
