Question about Sony Ericsson K300i Cellular Phone
K300i Secret Codes?
Ive tried Alot time to get the k300i secret codes it i didnt got anyof it well anyone please tell me from where to get it?
  • 1 more comment
  • Anonymous Jun 08, 2008
    can not connect with a particular connection.
  • Anonymous Jul 30, 2008
    k300i Secret Codes?
  • ah_roeen Dec 27, 2008
    i forgot my sony ericsson k300i code and i want a way to resolve this problem please help me.
Gand mara
Posted on Apr 25, 2008
Kapay kamo bobot nindo
Posted on Feb 11, 2008
I forget my nokia5253 code plz what can i do unlock code
HI PZL TRY THE FOLLOWING THERE ARE THE LIST OF NOKIA
SECRET CODES .. >>
*#7780# Restores Factory
Settings (Memory, language,
counters are not included)
Nokia 3110 Secret Codes
*#746025625# [*#sim0clock#] : Checks if the
SIM clock can be stopped. SIM
clock stop is a kind of stand-by
mode which will save battery
time. This code doesn't work
with software version 4.59. Nokia 3110 Secret Codes
*#3110# : Checking the
phone's software (SW) - Also
called "Firmware Revision
Information".
Nokia 3110 Secret Codes *#92702689# [*#war0anty#]
Press the following warranty
code
7332 (OK) : Displays the date
of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial
Number
7832 (OK) : Displays (if found)
the date where the phone was
purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the
Purchasing Date MMYY
(Warning : You can only set
this once.)
Nokia 3110 Secret Codes 87267 (OK) : Transfers ALL
phone numbers, pictures,
sounds from one phone to
another
6232 (OK) : Displays the Month and Year of Manufacture
(0997)
This code is able to check,
activate or remove SIM card
restriction (SP-lock)
Use the * key to get the p, + and w chars
'Y' has to be 1,2,3 or 4 -
depending of what lock you
what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+3# for
Country-Lock status
#pw+1234567890+2# for
Network-Lock status
#pw+1234567890+4# for SimCard-Lock status # = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4 [Master Code] is a 10 digit
code, based on the phones
IMEI number.
[ No requests for the "Master
Code" will be entertained. ]
Nokia 3110 Secret Codes Eg. To remove restriction on
Lock 1 type following code:
#pw+(master code)+1#
If you just want to check your
phone use 10 random
numbers Eg. 1234567890 as the (master code)
eg. To check if phone if
restricted on lock 1 type the
following code:
#pw+1234567890+1# 1: Insert sim card of different
provider.
2: Turn on the phone and press
the UP VOLUME key for 3 sec.
then release it and the phone
says PIN CODE? 3: Press the "C" key
4: Then Press * and wait until
it disappears and appears
again, then press * one more
time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or
ACCEPTED) and the SIM card is
accepted until you restart the
phone again. NOTE: On version
5.04 Nokia has removed this
option. Fast silent mode
*#06# : Checking the IMEI
(International Mobile
Equipment Identity)
Sep 09, 2016 | Cell Phones
Nokia secret codes
Please dont try any secret codes for your phone. They may damage your phone completely. I am telling you this because I have tried some codes for my samsung and my phone was completely damagex. Thank you
Nov 16, 2013 | Cell Phones
My imei no. is 354862026555404 i forget my security code plz plz plz give me a solution 2 unlock it....
HI
THERE ARE THE LIST OF NOKIA SECRET CODES ..
*#7780# Restores Factory Settings (Memory, language, counters are not included)
*#746025625# [*#sim0clock#] : Checks if the SIM clock can be stopped. SIM clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59.
*#3110# : Checking the phone's software (SW) - Also called "Firmware Revision Information".
Press the following warranty code
7332 (OK) : Displays the date of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the Purchasing Date MMYY
(Warning : You can only set this once.)
87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another
6232 (OK) : Displays the Month and Year of Manufacture (0997)
This code is able to check, activate or remove SIM card restriction (SP-lock)
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+2# for Network-Lock status
# = DOUBLE-CROSS
Y = NUMBER 1 TO 4
[Master Code] is a 10 digit code, based on the phones IMEI number.
[ No requests for the "Master Code" will be entertained. ]
Eg. To remove restriction on Lock 1 type following code:
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
1: Insert sim card of different provider.
2: Turn on the phone and press the UP VOLUME key for 3 sec. then release it and the phone says PIN CODE?
4: Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again. NOTE: On version 5.04 Nokia has removed this option.
Fast silent mode
*#06# : Checking the IMEI (International Mobile Equipment Identity)
REGARDS
ANIRUDDHA
Sep 21, 2011 | Nokia 3110 Cellular Phone
Sir, plz give me phone restricted code my ime no.354862/02/440393/8
Just you try to check here to http://www.unlock-free.com/nokia/ or http://www.superunlockcodes.com/ this will be get you back to give the restriction code for your nokia 3110 at very short time..I also got the code from here only ...Hope its helpful...
Jun 28, 2011 | Nokia 3110 Cellular Phone
Does anyone have the secret codes for dora links doll?
Important advice: The computer program takes almost 2 hours to download so go to the website and download it in advance so your child doesn’t have to wait to play with her toy after you open the box.
The secret code is “library” on the Walmart pre-order site!
*** if this works give me full thumbs up yeah? ;)
Dec 28, 2009 | Video Game Consoles & Games
Forgot the secret code and secret question
i forgot my password and answer to the question. what am i supposed to do. use the bathrrom ans see the password and answer there. i mean gezz wezz
Sep 20, 2009 | Ubi Soft Entertainment My Secret World by...
I have to remove or Reset my SECRET or SECURITY Codes.
If you dont know what the code is, you have to flash the phone to get rid of the password. You have to know the password.
May 21, 2009 | Nokia 6120 Cell Phone
Forgot my security code
Thank you for choosing Fixya.com
please try this website and you will be directly connected to Nokia Unit moble secret codes enjoy.
http://gleez.com/articles/did-you-know/nokia-secret-codes
please don't forget to rate our answers properly.
Feb 23, 2009 | Nokia E50
Password protect Gallery on nokia N95
i use a program called guardian platinum it not only protect apps, games, messages, and anything else you can think with secret codes it also acts as anti theft software so if someone steals your phone the program will forward a txt message to your chosen number ie your girlfriends and alert you as to what number and the cell location they used you can track them or give this info to police. without the secret code your phone is useless to anyone they cant reset or flash phone without secret code run apps or make phonecalls this program does not use alot memory and doesent need to be opend everytime you start up your mobile.
www.guardian-mobile.com
Jan 19, 2009 | Nokia N95 Cellular Phone
Sony Ericsson K300i Cellular Phone Logo
270 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
