I would suggest making sure the battery has not been recalled. https://www.facebook.com/matthew.wallace.925/map. I then would take your battery to the authorized dealer ad see if they can issue another for free or email customer service. Keep in mind, you should never leave a fully charged battery plugged in, as it can ruin it.
Hi, When a cell phone is fully charged and the cell phone randomly shuts off,IT means that the battery of the cell phone is ok ,but the cell phone memory is faulty and it need to be checked out.
I this kind of case, i would advice you take it to an expert on phone repairs tohelp you look into it. That will do..
Clean the metal contacts on the Battery and in the compartment. Then, reset the BIOS to its default settings. Next, plug in the AC Adaptor to charge the Battery.
If the issue persists then the problem may be related to the power circuitry.
You may try putting a small, thin piece of b under the battery directly on top of the small metal tab, put the battery back in, see if this pressure is enough to keep your phone on. Sometimes the cell phone deals people are getting on Ebay actually result in more frustration and disappointment.
You may consider cutting your loss and purchasing a new phone, or getting a FREE phone from one of the major carriers.
I highly recommend the following company for getting your next phone, the customer service is excellent and the selection is great. I also recommend folks in getting insurance on their new phones as well. I hope this helps you, best wishes :)
how old are the batteries and how many times they were charged without being fully drained can cause a short life for the battery. Try a new battery-fully charging it properly, but dont charge it again till it goes off by itself completely. If you have a wall charger, plug your phone in. If it stays on that way, check your 'power save' settings. That can also make your camera shut off. Try these steps first and see if it changes the 'battery' from being empty to full and stays on. hope this helps
due to tried after changing the battery and fully charge it. it might be possible that the issue is with battery. moreover, if it reamins in the same condition, then its the inside fault. you have to concern with a repairman. the battery is controlled by a charging ic that charges the battery and transfers the voltage to system.
