Nintendo Game Boy Advance Console Logo
Posted on Feb 09, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Xbox goes xboxlive from xbox side yet through pc i cant play it even tho pc has picked xbox up but when i do network check from xbox side it says ip adress failed
Anonymous
Level 2:
  • Expert 106 Answers
  • Posted on Jul 23, 2009
Anonymous
Expert
Level 2:
Answers
106
Questions
0
Helped
10210
Points
107
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
asd-100
Anonymous
Level 1:
  • Contributor 21 Answers
  • Posted on Feb 09, 2008
Anonymous
Contributor
Level 1:
Answers
21
Questions
Helped
8211
Points
27
Instead of letting the xbox automatically obtain an ip change set the ip your self.
most likely the ip address is already in use
How to connect my xbox to xboxlive in nigeria
if you have a usb modem and a laptop it is real easy. I hav been playing xboxlive in nigeria since i move here, but it is not as much fun. your ping or latency is goin to be really high because of the facts that there is no xboxlive in nigeria and nigerian internet aint that good. you will hav to join British or American xboxlive. its sumtimes fustratating. ill give the steps in any case
1) connect xbox 360 to laptop with ethernet cable
2) change ur ip of xbox to 192.168.0.2, and ur pc ip to 192.168.0.1
3) do not do anything to DNS
4) Go to network and sharing center >> manage network connections >> right click on dail up icon >> properties >> click on sharing tabs, and check all blocks. click apply ok and what not
5) try to connect to xbox live, it wont work right away, so try and try
6) if u hav any problems, search it on google
NOTE: Thins is for Windows Vista and Windows 7
I hooked up my xbox at a freinds and i got to play live but i set it up at my house and i cant play i have a router and ethernet cables
If it works are your friends but not yours. It is probably your network configuration. Just let the XBOX perform its connection check and it will tell you if it is getting a network address (i.e. 192.168.0.xxx). If not, it is probably a bad cable or maybe DHCP is not turned on in the router settings. If it gets an network address and fails, maybe your router firewall is blocking connections or just is not compatible with the XBOX. Here is a list of compatible hardware (http://support.xbox.com/support/en/us/nxe/xboxlive/getconnected/CompatibleNetworkEquipment/CompatibleNetworkingEquipment.aspx)
Can't connect to xbox 360
If your XBOX can't connect to XBOX Live, then here is the trouble shooting procedure:
Your ISP (or router) might be blocking ICMP. From a PC connected to the router, open a command prompt and type
"ping www.xboxlive.co.uk" you should get the following
Pinging www.xboxlive.co.uk [213.171.195.53] with 32 bytes of data:
Reply from 213.171.195.53: bytes=32 time=45ms TTL=246
If you don't get the reply then check the firewall settings on your router for ICMP. If this is enabled, run the following command on the PC
tracert 213.171.195.53
You'll get a line of IP addresses, and if the trace doesn't complete, it will tell you where in the network ICMP is being blocked.
(These are the addresses for the UK, other countries will be similar)
Bought fable2, knothole island DLC and my save wont load.
Was this purchased while connect to your friends connection? if so then the problems is that it was purchased with his connection and not your own
2answers
My xbox 360 wont take ip anymore
go to your router. find what your ip pool is. choose an ip that is in that pool. set up your xbox's internet manually. you need the gateway, DNS, and everything (you can find this on your router online) this will give your xbox a static IP and might fix your problem
7helpful
4answers
My NAT type is on moderate so I cant play Xbox Live
I tried everything and eventually figured this out.  Do this!
Enable DHCP set the start ip to 192.168.1.100, and remove any static IP address on your xbox 360 (have it automatically detect connections)
Set the MTU to 1364.
enable UPnP.
if you are using wrt-dd (if you aren't, you should be)  setup QoS so xboxlive has premium priority.
And you have hit the ground running.  Even microshats own website wont' help you fix this stupid problem.
I promiss this will work ;)
1helpful
7answers
Cant get into xboxlive
PHONE UP XBOX OR PRESS THE X SIGN ON YOUR CONTROLER AND IT WILL COME UP SIGN UP FOR XBOX LIVE YOU NEED A WIRLES ROTER SO YOU CAN GO ON THE INTERNET
2helpful
2answers
No connection to xbox live
i cant play x-box Live and i just played it just a few hours ago and its saying, Cant connect to XboxLive select Test conection to trouble shoot, or try recovering your profile.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
