Question about Soyo GVTL3727AB Television
Connecting my Laptop to the Television
I don't know what channel I have to put the television on...and what is the pc audio imput for?
    Brigadier General:
  • 6,966 Answers
There is no need to select any channel on the TV to watch the video from the laptop, rather you need to select at which external source/connector the laptop is connected to. These area:
1. HDMI
2. D-Sub (HD-15)
3. VGA
4. S-Video
5. USB
6. RS-232
Often used are either the: a) VGA, or the b) S-Video. Of course likewise to be connected with the Video would be the audio out of the laptop (green) to Audio INput of the TV.
To your post of "PC audio input for", they (blue) are used to plug in any any audio source external to the PC such as a cassette deck, an analog audio from a camera, from an analog mixer and others of the same variety.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Feb 09, 2008
Element tv wont see laptop
Connecting laptop VGA port to HDMI port on a TV
VGA to HDMI converter is required to connect a laptop to a TV with HDMI input. The VGA signal does not have an audio component. You need to connect an audio cable from the audio/headphone port on your laptop to the audio connector on your TV. There are HDMI converters with Audio input so you do not need to connect an audio cable to the TV. The audio is connected to the HDMI converter and then passes the audio with the video data to the HDMI cable to HDMI port on the TV. Check out these WEB site for these HDMI converters. http://www.aten.com/products/productItem.php?model_no=vc180 http://www.sybausa.com/productInfo.php?iid=1174 http://www.topbuy.com.au/tbcart/pc/Audio-VGA-to-HDMI-Video-Converter-Box-HD-HDTV1080P-p164633.htm
Mar 14, 2013 | HP Pavilion Computers & Internet
How to hook up a sound bar to this tv
I don't see any audio outputs on this television. Without them it is not possible to connect a sound bar. However I am currently using a sound bar with a television with no audio outputs. I am connecting my devices to the television with the video cables only and connecting the audio cables directly from them to the sound bar. I am pleased with how doing this turned out.
Aug 14, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
How do i use it a a PC monitor? i am connecting it and receiving a "not supported mode" display
To hook up your television to your PC, first you need to get the appropriate cable which is the cable you use in connecting your CPU to your monitor, then turn the back of the television and try to connect it to the port that is on the television.
Then turn on the television, and go to the AV mode, select from the different AV channels you have to be able to access the laptop.
That is how to hook up your television to your PC.
Take care
Oct 11, 2010 | Samsung LN-T2342H 23 in. LCD HDTV
What channel do i go to for svideo cable??
The TV doesn't output the TV as such, UNLESS it has what is called a "Monitor" Output Sockets on it. Then you can connect up to, say another "Screen" or Take the Outgoing Video, & Sound, and "Record" it to a PC, via a Video INPUT via a TV/Video INPUT card. BUT you cannot play the TV on the laptop, FROM the TV. like you wish to do. If your laptop has a TV card INSIDE your laptop, then you could use that and display the OUTPUT from that TV cards' tuner, on the TV. But not the "other" way around. That SVHS is ONLY an INPUT out from your PC. You can put you system into either "Cloned"mode, IE: Whats displayed on laptop screen,is also displayed on the TV, Or, you can have as you seem to now, Extended Desktop. I hope this clears things up for you. Also when using that SVHS connection the Audio comes OUT on the Red & White AV sockets on the set. So you need that cable and another pair for the Audio..
Mar 23, 2010 | RCA L32WD14 32 in. LCD Television
Lost remote want to get to input channels using side buttons on TV
Try using the manual buttons and keep pressing channel down until you see the lowest station you receive, then go slowly.
Maybe Insignia put the inputs into the channel search automatically.
Apr 27, 2009 | Insignia LCDTV26 26 in. Television
No audio on vizio from source
there should not be a special setting that you need. When hooking the analog audio to the HDMI 2 input, it should read automatically. Note: The HDMI Input is for HD Video and will only support 640x480 at 60Hz from a PC. Use the RGB
PC input for a greater selection of PC formats.
Mar 23, 2008 | Vizio GV42L 42 in. LCD Television
Imput channel or imput switch
if you scan down below channel 2 doesn't video show up? otherwise there should be a input / video button
Dec 31, 2006 | Zenith B27B40Z 27" TV
Bad Cable Input
Try using your RCA imput to see how the picture looks compared to the tuner picture,is possible your tuner imput is bad,make sure the conector is not loose,the overall picture should look different but not fuzzy all over,using a dvd picture thru the aux (rca)imput should show you the difference.If the conector is loose only it could be repaired but if it is solid the tuner might be bad and it will need to be replaced along with any board it might be mounted to.Let us know how it goes or if you need more information.
Oct 17, 2006 | Polaroid FLM-2632 Television
Television will not program channels 2-7
It seems you have already try everything We might suggest< I dont know if you have tried using the video and audio outputs in the dvd/vcr combi unit conecting them to the audio and video imputs of your tv and the selecting maybe one of the AUX channels to watch it,If you have a tuner problem in your tv this will be a way to bypass it and control the channels from you combi unit.We would like to know the outcome,please let us know.
Oct 09, 2006 | RCA F27669 TV
Soyo GVTL3727AB Television Logo
74 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
