Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
My dish washer would not drain
By sunnypablo on Feb 09, 2008
my dish washer would not drain
Same Problem
Apr 08, 2009
-   my dose not drain eoither and dose realy clean
help-   k9fire22
Jan 21, 2009
-   i tried to clean out pump opening and it still will not drain it runs ok but can not use it
-   Guest
Jan 09, 2009
-   won't drain - 10 year old machine...any ideas?-   Guest
Dec 26, 2008
-   diswasher will not drain
-   Guest
Dec 08, 2008
-   dishwasher won't drain after washing-   Guest
Best Solution
posted on Mar 13, 2008
Very Helpful)
fixya pal
Rank: Apprentice
Rating: 99%, 9 votes
I guess you have the same problem I had when I installed a new disposal. The metal block you mentioned is a plastic plug that can be removed. If the existing drain from your dishwasher drained into the disposal, and you want to do the same, then you must remove the plastic plug that is molded into the nipple. Knock out the plug using a screwdriver and hammer. Leave the plug in if you are not going to use this drain.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Feb 09, 2008
Helpful)
yalmer
Rank: Wiz
Rating: 82%, 337 votes
Drain line/air gap
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt
One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor
If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer
Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Was this helpful?
Yes
No
5 people thought this was helpful
Solution #3
posted on Sep 04, 2008
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
get a new one
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
we are about to buy new dishdrawer lookin fisher and paykel
Answer
When I turn the machine on, the drain pump works and my program starts. However, there is no water... (More)
Answer
How do I reset miele dishwasher - drain pipe now unblocked but will not commence cycle
Answer
dishwasher programme trips out during operation, tripping the fuse constantly when tring to restart.... (More)
10 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jul 29, 2008
just will not drain the water .does not seem to be plugup.it is a frigidaire gallery model no. fdb636gfs5
Comment by Guest, posted on Jun 06, 2008
dishwasher washes dishes... doesn't drain. Instead the water recirculates in the dish holding area
Comment by Karen60, posted on Feb 18, 2008
dishwasher will not drain. After reading the prior problems herein I took the drain tube away from the "new" garbage disposal and ran the rinse cycle. The dishwasher drained into a bucket. Could there be a cap or block that needs to be removed in the garbage disposal prior to attaching the dishwasher drain hose? It appears to have a metal block about an inch and half into the disposal drain input. Any ideas? I am hoping this is a simple repair that I can do without calling a plumber or appliance person. Thanks
Karen
Comment by kathyann, posted on Feb 09, 2008
Whirlpool WJU-36001
Comment by gl50, posted on Feb 09, 2008
the dishwasher runs through all cycles but at end water has not drained
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dishwashers:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
