Question about Sharp AR-5316 Advanced Digital Imager Copier
Sound during paper take up.
When i am making copy , machine gives very high sound and paper geting jam in feding section, this happening during manual also.
    Scholar:
  • 53 Answers
Is it a clicking noise? If so, pull out the toner unit and the drum unit-is there any toner(and developer) spilled into the back of the machine where the toner unit came from? If so, this will have found its way into the feed clutches at the back causing them to jump gears and slip the drive....you can vacuum out the spill but it is a fairly involved job to clean out the clutches, let's just hope I'm wrong.Other than that more info is required to make a half reasonable guess at the problem
Posted on Feb 09, 2008
The paper will jam when making a copy. I have cleared the paper from the door on the back of the machine. The paper dislodges in one piece. I do not see any more paper by lifting the top tray. Are they...
To answer your last question first, any copy machine or printer that uses toner, by design, will get very hot in the back of the machine. This radiant heat is coming from the fusing unit, when acts as an oven to burn the toner to the paper; and generally overheating problems will not cause jamming. More than likely you have a physical obstruction blocking the paper path, my suggestion to you would be to take a thick piece of cardstock and manually pass it through the paper transport section. This act will force out any small paper dust or debris in the transport section; also, I'd recommend spraying some canned air through the path as well. Out of curiosity, when the paper jammed, did it appear to be bent or torn in a particular area of the page?
Let me know.
-David.
Nov 07, 2010 | Samsung CLX-3170FN All-In-One Laser...
Canon NP 6650 photocopier. Begins to pick up paper, stops and gives message about jammed. Checked path and see no paper or parts of paper. Need service manual.
1)jammed issue.
2)can u try to make copies by using stack bypass or other paper deck see whether u hav the same fault.
3)or flip over your paper and put it in the paper deck again .Fan the paper ,it could be high moisture and static on the paper.
4)clean the paper dust from the pick up unit with damm cloth.
Sep 04, 2009 | Canon Office Equipment & Supplies
Can't fax or copy on brother mfc3240c machine
Sounds like you may have a small obstruction in the scanner feed. This would inhibit making copies and sending faxes. Lift this section up slightly to inspect for small pieces of paper or dust. Blowing it out with compressed air would also be a good idea.
Aug 20, 2009 | Office Equipment & Supplies
Pc920 won't make copies
the noise could be the heat rollers have squared of this happens if the machine hasnt been used for a while the pressure makes a flat on the soft roller.. it cold also be the toner cartridge has settled. take it out and give it a good shake.. if you cansee if the scanner lamp and carriadge is moving when you run the copier up it mighht be saveable.. make sure the paper is new and dry as this can cause jams in hot section.. if you can see where the paper jam is when you do one copy check the guides as well and finally take the paper tray out and look at the condition of the rollers that feed the paper as they may be dirty and sliping the paper..Good Luck A
Jul 30, 2009 | Canon PC-920 Black and White Copier
Canon image runner 7105/7095/7086
try cleaning your pick up rollers but sounds like they need replacing, just clean them with window cleaner and rag
Apr 09, 2009 | Canon imageRUNNER 5570 Copier
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
Change papaer size and frequent papaer jams
OK it seems to be a problem with pick up clutch and vertical feed rollers ( When you open the left door and hinge in level of cass you will see axis with the tree little rollers- clean it with alcohol or water).Pick up clutch is better to replace it FK2-1068 (europe code).
Jan 12, 2009 | Canon iR 2016i Black and White Copier
AL-800 cannot make copies jam light remains on with no jams
First, is the paper being fed at all? If the paper is being fed and jams at the same location then a senor, actuator or switch is bad, out of place or broken. If the device will not clear the jam light, completely power down the device, unplug from wall, let set about 30 sec. to 1 min. and then replug in and see if it reset. If the device did not reset then again a senor, actuator, or switch is out of position ( being held up in the paper path). If the paper does not feed at all then the feed section is the problem. Clean the feed tire (s) the rubber restorer or a high alcohol base cleaner. Listen to hear if the feed tire (s) are even turning. If feed is not turning then it could be clutch, motor or board problem.
Jan 04, 2009 | Sharp AL-800L Copier
Paper jam
Are you sure you have the correct size paper?
Also check and make sure the exit rollers are turning, if not then there is a broken gear in hte fuser
Jul 23, 2008 | Office Equipment & Supplies
Sharp AR-5316 Advanced Digital Imager Copier Logo
43 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
