Question about Epson Stylus Photo R200 InkJet Printer
Cant print CD's
When I try to print on a CD, the tray comes back out and all three lights start blinking
  • 2 more comments
  • Anonymous Feb 14, 2008
    i have vista ultimate
  • Stanko Feb 16, 2008
    R200 ejects the cd/dvd tray.  Epson tech indicated hardware problem. Replace tray sensor assembly.
  • Anonymous Mar 21, 2008
    I tried to print on a cd but it won't print. The message: Remove the CD/DVD tray, then close the CD/DVD guide, keeps on coming. I need the cd/dvd tray to print on the cd, for crying out loud! I checked everything but it still won't print!!!
  • Anonymous May 21, 2008
    ya when i try to print it just spits out the tray and says it's not loaded correctly! =(
My r200 will only print part of a cd usually the bottom 1/4
Posted on May 30, 2008
Canon MP810-CD-R Tray loading-printing problem
I am trying to print on DVD with Canon MP810 but the image won't line up - seems to be taking the tray too far in and printing some of the image on the F tray! Help.... it's driving me nuts
Jun 02, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Printer is not printing
Dear, Remove the one cateridge and try to print, if it doesn't help then put back the first cateridge and remove the other cateridge. Tye to print. I hope your problem will get resolved as one of your cateridge is out of order now.
Best regards.
May 26, 2009 | HP DeskJet 920c InkJet Printer
LaserJet 1200 Stops pulling paper
If the printer works fine for you, but doesn't work properly for someone else I would assume user error. Just make sure that there is plenty of paper in the tray and that it is centered. Also look around for any small peices of paper that might've gotten stuck near the tray, preventing new sheets from getting pulled.
May 06, 2009 | HP LaserJet 1200 Printer
Paper Light Blinking
make sure the rear part of your paper tray is not pressed too tightly against rear of paper. it will prevent the paper from raising up fully to the feed roller. you can also try cleaning the feed roller if that doesn't do it.
hth,
razors
Feb 05, 2009 | Brother HL 5250DN Laser Printer
Epson 220 not printing cd labels anymore
Clean the white areas on the tray with a light solvent cleaner like windolene/windex liquid. Also try giving the tray a helping hand as it is started to be fed into the printer
Nov 08, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus R320 - cant align the CD tray to print....keeps showing error.
This printer has a bad system tray. If doesn't work in regular way, try inserting the cd tray from the back using the back slot and see what happen (usually works)
Oct 03, 2008 | Epson Stylus Photo R320 InkJet Printer
I read on another site that you must wait until prompted on the screen to put the tray into position. Opening the inner door and loading the tray before asked to and then pressing OK was the key to fixing the problem on the MP830.
It's the simple things that always get you into trouble, I guess.
Oct 02, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Printing on cd/dvds
you have to change the tray before you turn the unit on.
then check the paper path settings that you are selecting in the preferences. it should say CD/DVD on it, as well as the media type
Sep 05, 2008 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus Photo R200 InkJet Printer Logo
99 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
