Question about Gateway 4535GZ Notebook
Laptop freezes when it is moved and the backlight is pinkish
Everything works well when the laptop is on the desk or a table but when try to move it or place it on my the lap it just freezes. it happens a lot of times. and also the backlight is pinkish then the backlight just shuts down, the lcd is working though.
  • 39 Answers
Although, you should have this one looked at by a qualified Laptop technician...the most likely culprits are:
1) bad harddrive or harddrive needs to be reseated
2) bad ram or needs to be reseated
3) on soem laptops there is an access panel on the back for a video card...these get loose...and some have two small wires that snap on the board...check those.
4) lastly, the cable that attaches the LCD to the motherboard. This will not be easy for the novice to find...you will have to remove the bezel and probably the keyboard...don't attempt unless you are confident.
Good luck.
Posted on Feb 09, 2008
How do i fix my slimbook
seems like a software loop wherein you are not able to get past a particular software. this may lead to software damage and information and data.
call 1-877-805-1027 for expert help.
Aug 12, 2015 | Computers & Internet
Lower screen is pinkish
The screen's backlight is dying. Sooner or later this screen will be pinkish and later it will be darker and black. You need to replace the whole screen (it is not easy to replace the backlight).
Feb 28, 2014 | Toshiba Satellite L510 Laptop AC Power...
My screen has a pinkish overtone, when I restart everything looks normal for a few seconds after I log into my name and then it goes red again. Everything works fine, but it pretty much hurts my eyes.
That means the backlight on your LCD display is on its last legs. I say that but I have had laptops with the pink screen that lasted like that for over a year. Or, it might go dark tomorrow. It is not the inverter, which is an easy fix. Only a replacement of the backlight (a flourescent tube built into the display panel) will fix it. So Replace the backlight at repair shops...THANK YOU
Aug 13, 2013 | ASUS Computers & Internet
Recently tried to power computer on and computer tries to boot up but screen will only show colored lines. You can see faintly behind lines are icons like computer is trying to turn on. When shut down you...
Hello.
I'm not certain if a power issue or graphics / display issue.
If a power issue, the most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
If a display / graphics issue, connect an external monitor to your laptop. If an external monitor works, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation, the inverter would be indicated.
In either case, a technician in your area should be able to help. Evaluate to see if the repair is cost-effective.
It's also possible that your graphics card is faulty and needs to be replaced.
Hope this helps.
Feb 27, 2011 | Compaq Computers & Internet
When i turn the power on,on my toshiba satellite l445ds5976 the only thing that comes on is the power indicator light
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Ultimately, your motherboard could be faulty.
If your system is powering, but no display, connect an external monitor to see if the display itself is the problem. If an external monitor works, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
Hope this helps.
Feb 26, 2011 | Toshiba Satellite L455DS5976 Notebook
Monotor not working
Hello !
Since an external monitor works, it is the display's backlight or inverter board.
Here is the disassembly guide:
http://www.irisvista.com/tech/laptops/ToshibaM35X/satM35X_1.htm
Hope this helps.
Oct 24, 2009 | Toshiba Satellite M35X-S161 Notebook
I have very weird problem with my laptop Normally it works, if i hold it or when its on bench. But, if its working on stable ground and then i'll move it ... it's just freezes, no respond, no any beep,...
Since your OS is running from a Live CD, I suspect that your CD player is very sensitive to movement.
So when you move the laptop, the CD read-head moves slightly and loses its place on the disk.
A live CD distribution requires constant access to the CD for everything it does.
Sep 05, 2017 | Sony VAIO V505DX Notebook
IBM T40 shaking problem
it is your HHD. apparently the internal mechanism hs shaken loose. so when you tip it one way or the other the mechanism will work and the other way, it will stop.
Mar 26, 2009 | IBM ThinkPad T40 2373 Notebook
Laptop freezes
To me, this sounds like this laptop been beat to almost death...i would prepare for a total failure by backing up everything you want to save, and buy a new laptop...
..or pay a repairman about the cost of a used laptop to try to fix what sounds like a bunch of breaking or broken connections....
May 27, 2008 | Acer Aspire 5610-4648 Notebook
Gateway 4535GZ Notebook Logo
127 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
