Cisco  2106 (AIR-WLC2106-K9) Logo
Posted on Jan 13, 2010
DeleteReason 4 on WLC, any idea what could be the reason.. Error codes list of Debug ouput of WLC Thanks..
1helpful
2answers
Dishwasher won't shut off,stays on 1 minute
You haven't indicated the model number so I'm going to guess its is an SGS or SGV model. The problem with these models and the fault you describe is the pressure chamber or hose (pressure chamber to sump) is blocked and the microswitch is being activated because the water is not entering the tank quick enough. Isolate from electric, remove lid and left panel (looking from the front). There is a plastic chamber bottom right of left side with two microswitches, either this is blocked or the hose that runs from it to the right and along the back of the kick panel and into the sump. Clear either or both (make sure all hoses are pushed true when repositioning). This should sort the problem. If the pressure chamber is excessively blocked it will probably need replacing. Costs approx 25pound direct from Bosch service division (BSH Home Appliance Ltd). There is also the possibility that the heater is not operating, but try the attached suggestion first.
Best of luck
Washer will not stop filling. Any ideas?
The water level control whisch uses a sensor responsible for shutting off the power to the fill valve and redirects the power to the timer to start the washing machine running once the correct water level has occurred. The WLC itself could be bad. The WLC uses a hose that the water level pushes air into to tell the WLC what the water level is inside the washing machine...the hose could be pinched, fallen off of the tub spout, has a pin hole, clogged up with calcium or soap curd and the WLC cannot "sense" or "tell" what is happening inside the washer.
Microsoft visula c ++ runtime error how to fix it
I assume here that you are writing an app in VC++. If the problem is that the code runs in Debug mode, but crashes in Release mode, the usual reason is a pointer overflow bug. This is commonly when a pointer is not initialized or a buffer is too small for the data written to it.
In Debug mode all variables are surrounded by guard bytes (allowing the app to run...), but these are removed in Release mode. The guard bytes are the main reason that Debug builds are about 2x the size of a Release build.
Set Debug mode, and hit F5 to run the app. It will probably stop at the source of the error. If not, then you'll need to put in some MessageBoxes in various places to locate the code region that has the bug.
sd www.pixcl.com
DeBug appears whenever
what IE are you using?
the debug will appear when you using IE6. the reason is that most of th web site have activex. IE6 can't handle it. you need to install IE7 sp1.
1helpful
Epox EP 8RDA3I
Hello tenkist:
Many error codes in mother boards are similar.
Saying that, you need to get to the maker of the board, and find the information from them.
Sending them an email under support, will most likely solve what you need.
2answers
9helpful
3answers
Programming comcast remote with a samsung dlp HL-T4675S
I went to the website listed below and followed the directions for "Searching For Your Code"
http://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Hope this helps. It worked great for me!
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
