Question about ASUS P5RD1-VM Motherboard
Boot problems led lite is glowing,power supply,processor,harddisk,RAM are all working fine but does not boot at all.no system beep too.I think the motherboard is gone haywire.any suggestions???
  • 33 Answers
This type of problem is so common nowadays. What I did is open up the casing, pulled out the RAM and by using pencil eraser, rubbed the contact pattern. Put it back and turn on your computer. Always work for me and hope it might work for you too.
Posted on Feb 09, 2008
Gateway 503gr has no power, the standby light flashes green when I remove power. Tried new PS and the standby LED stays lit. I then tried both new and old PS disconnected from board and shorted...
Disconnect everything from the motherboard except the power supply connections and cpu fan. Install one stick of RAM and connect your monitor. Then try starting up. See if you get any BIOS boot messages. This will tell you that the board and processor are okay.
With what you say you've tried already, I'm thinking you might have a bad processor. Most every other problem would result in some kind of error like POST beep codes or messages on screen. If the system still doesn't boot with the bare minimum parts installed, replace the processor.
Mar 02, 2010 | Gateway 503GR PC Desktop
Computer wont turn on
First open cpu cabinet then pull cmos cell from motherbord for 10 minutes.
Refix RAM memory.
Reattch ATX power connector to motherbord.
Reattch power cable and SATA or ide cable to harddisk.
Clean dust from all parts of motherbord.
Open processor fan and processor.
Then reattch both.
Make sure motherbord is not ground with cabinet.
When you power up the computer press F1 or F2 or "del" key then enter in bios .
Make sure in bios your harddisk is detected.
If not then change SATA or IDE cable of harddisk.
Then check .Go to boot menu nof bios then set first boot device as your harddisk.Then save settings and exit.
Let me know if you need further assistance.Thanks.
Nov 21, 2009 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
I am having the computer with Intel 845GVSR motherboard,P4 Processor,1 gb RAM Configuration. When i switch on the system, three beep sounds come and the system is not booting. But the RAM is in working...
For that first open cpu cabinet then refix RAM memory try it in defferent slot on motherbord.
Pull cmos cell from motherbord for 10 minutes so all settings goes to defaults.
Then open processor fan and processor then refix both.
Clean dust from all parts.
Reconnect ATX power connector to motherbord.
Reconnect power cable and sata or ide cable to harddisk.
If any PCI cards are installed then remove it from pci clot then check.
Make sure your motherbord is not ground with cabinet check in outside of cabinet .
Nov 10, 2009 | Intel D845GVSR Motherboard
I have a problem with Intel D845GVSR Motherboard with 2.0 GHz processor. When I power the M/B, only the Motherboard LED is on, but no boot, no cpu fan running. No beep code also. I check the SMPS, RAM,...
Think this should be an issue with the power button, Remove the wires running from the power button to MB and try starting the system with shorting the 2 lead of the power button..
Mostly, it can be due to bad power supply or Ram
Rate this solution
RNJ VINODKUMAR
Sep 26, 2009 | Intel D845GVSR Motherboard
Amd phenom faulty
Replace cpu fan , failed cpu fan might have caused CPU stoped working. If you are sure about the CPU fails then replace the CPU. If the problem seems continues after that too, then PC might have failed to boot due to other reasons. What shows on the screen once you power on the computer? There could be , motherboard , or harddisk faults too. Try unplugging other parts and see if the computer boots from CD or USD flash or floppy drive!! Once you know that motherboard works then replace the CPU. There could be BIOS setup problem. Did you check the BIOS for harddisk is set properly.
Sep 17, 2009 | AMD 2.1GHz Phenom X3 Tri-Core 8450 AM2+...
Es2 300x not boot up
Open your cpu cabinet.
Refix your RAM clean all dust from circuit bord.
Reconnect power cable and ide or sata cable to harddisk.
Reconnect processor fan and processor.
Reconnect power supply from psu to motherbord.
Pull your cmos cell from motherbord for 15 minutes from motherbord so all settings are reset to defaults.
Check in bios your harddisk is detected?
For boot your computer with operating system your harddisk must detect in bios.
Aug 15, 2009 | Computers & Internet
I cant get my pc to boot
Aug 03, 2009 | Office Equipment & Supplies
No display on monitor
this lead to cpu overheating problem
clean your cpu fan and put some thermal grease between the fan and cpu
Jul 17, 2009 | Foxconn NF4K8AC-RS-1.0 Motherboard
Actually my system is having the problem like motherboard led is glowing powersupply fan processor fan spinning but when we remove memory there is no beeps from the board so what can be the problem please...
The motherboard LED is supposed to glow, indicating that the board is residually powered, after disconnection
of external power and as a warning of this condition so that you will not further disconnect or connect any
peripherals until the charge on the power retention capacitor is properly dissipated.
The Power Supply and Processor Fans should only run while power is applied, and if the Processor fan is always running at a high, possibly noisy, velocity, additional Processor Cooling may be necessary by means of a higher efficiency heat dissipation system.
If you remove memory from the board, the system should not initiate, as memory has little or nothing to do with
the problems you cite, but everything to do with the proper initiation of your system.
Buy a larger Processor Fan Assembly and those symptoms you cite which actually are problems should cure
themselves, while those symptoms you cite which are not problems will still not be problems.
Apr 18, 2009 | Gigabyte GA-8I845GVM-RZ Motherboard
Not booting but RAM,processor,SMPS ,HD are fine.
Check without Video Card, Processor , Memory and beeps are coming
If no then this is motherboar issue, I had the similar problem. So went to the local repair shop and got the power capacitors replaced,
Jan 29, 2009 | Asrock P4i65GV Motherboard
ASUS P5RD1-VM Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
