Question about IOGear MiniView GCS62 2-port KVM Switch
IOGear GCS62 2-port switching problem
I am failing to switch from one PC to another. I am not the one who set up and do not know the hot keys to use. Is there a way I can do it. It's my first time to use it and I found the manual missing when I joined this company. It is working fine I am sure but only that I do not know how to switch to another PC.
Give the hint or tips.
  • tima579 Nov 20, 2009
    i have a belkin 2 port kvm switch with built in cabling ps/2 and up to yesterday was working fine changing between 2 computers by press scroll lock twice and the down arrow. However it does not work anymore - I have checked that all the wiring etc. is connected properly. Can anyone please help? Thanks.
    Tima - 20th Nov. 2009
  • SJ Noer Jun 06, 2013
    I have an Iogear 2-Port KVM and the SCROLL BUTTON twice. Does not work. Please help!
  • 38 Answers
I have a similar IOGear KVM switch. I use the Scroll Lock button twice to switch between PCs.
Hit the Scroll Lock button twice see if that does it for you.
Posted on Feb 10, 2008
I used the keyboard, press ScrollLock twice.
Posted on Feb 11, 2008
I have this switch hooked up to my PC and Xbox 360.. everything works correctly, however when this was given to me.. it had no instructions of sorts.. how do I switch the inputs?
Press the Scroll Lock key twice to toggle between the two machines. (Either the right or left scroll lock key will work) .
There is also an auto-scan mode which is accessed by pressing the Left Shift key and then the Right Shift key within about 0.5 seconds. This shows the screen for each machine alternating at a set rate until you press the Spacebar. The active screen when the spacebar is pressed becomes the active manual.
The manual is available at: http://www.iogear.com/support/dm/manual/GCS62#display .
I hope this helps.
Sep 19, 2010 | IOGear MiniView GCS62 2-port KVM Switch
This worked great for a couple of months and now
It may be possible that the KVM has gone bad. Make sure the keyboard is plugged into the keyboard port of the KVM as this is the only port on the KVM that will recognize the hot key commands. If you have ensured the keyboard is plugged into the keyboard port and you have tried multiple keyboard and still experience problems I would assume the KVM is having problems. IOGear KVMs have a three year warranty and their support can be reached by email support@iogear.com.
Jul 26, 2010 | IOGear GCS634U KVM Switch
I am looking for the hotkey combination for our HP 336044-b21 KVM switch from a iogear KVM?
IOGEAR KVM switches uses Scroll Lock for the hot key. The models of IOGEAR KVM switches starts the letters "GCS". I don't think that your HP 336044-b21 came from IOGEAR.
Anyway, if that's an IOGEAR KVM switch, you may quickly press Scroll Lock twice + Enter (for two port KVM).
Scroll Lock twice + port # + Enter (for 4 port, or 8 port KVM).
NOTE: You need to verify the brand of your KVM switch by referring to the user manual of it.
Thank you and good luck!
May 20, 2010 | HP 336044-B21 8-port KVM Switch
Repeated IOGear KVM switch failures
As a wild guess, it sounds like a static discharge MIGHT be affecting the switcher causing it to crash.
Try increasing your humidity to 40% and grounding yourself before touching the keyboard... This is the season for these static electricity problems... get nipped all the time and you MAY not even feel it to be enough to zap the switch.
Jan 11, 2010 | IOGear MiniView GCS62 2-port KVM Switch
Lost keys to switch from one PC to the other
The GCS62 can be switched by quickly tapping the Scroll Lock key twice.
Sep 11, 2009 | IOGear MiniView GCS62 2-port KVM Switch
Can't switch ports using PC keyboard
Make sure that your keyboard is connected to the keyboard port of the switch. The USB ports on the switch has pictures that indicates where the keyboard and mouse should be connected.
The hotkey combination is CTRL + ALT + SHIFT + Port no.(1,2,3 or 4) + ENTER
Note: "tap the keys one at a time and not at the same time"
Jun 17, 2009 | IOGear USB gcs1734 4-port KVM Switch
KVM will only switch one way
Please make sure that the keyboard is hooked up on the KB port of the KVM. check underneath the GCS632U for the correct console port. you will see a keyboard and mouse icon. Make sure that the keyboard is connected to the keyboard port. tap scroll lock key twice to switch between computers.
May 13, 2009 | IOGear GCS632U 2-port KVM Switch
IOGear MiniView GCS62 2-port KVM Switch Logo
693 people viewed this question
Top IOGear Computers & Internet Experts
Jose Velazquez
Jose Velazquez
Victorman
Victorman
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
