You can use function key +F2 or function key +F5 key to turn on camera
also make sure camera driver installed
make sure camera is enabled in bios too.
For that when you power up press F1 or F2 or del key to enter in bios then make sure camera is enabled.
Let me know if you need further assistance.
Thanks for using FixYa.
1. Turn on the computer; then, while the initial screen is displayed, press the Lenovo CareSM button. The Rescue and Recovery screen opens. 2. Enter into BIOS SETUP with F9 on start up or Click Access BIOS. The System Restart Required window is displayed. 3. Click Yes. The computer restarts, and the BIOS Utility screen opens. 4. Check whether the wireless radio is enabled. if it is disabled make it enable.
make sure that the wireless switch is on,try to press Fn F5 to enabled the wireless capability or is there any other short cout to enabled the wireless capability
hi mmi300, try to press Fn + F5 and check if it works. Pls determine if there is a toggle switch (if it is a laptop) somewhere. Disregard that step if it is a desktop...
Is the "broadcast-tower" light on (the leftmost icon on the lite-bar below the screen)? Have you got an available/working WiFi router? Have you been able to choose a network to connect to? My T400 works fine when all the above are enabled..
Check the BIOS to ensure the wireless card is detected. Also verify the Wireless setting is turned on and not set to Always Off.
If the Bluetooth device is installed, also verify the radio LED is enabled. You can turn the wireless and Bluetooth cards on or off with the wireless switch.
If the card does not show up in the BIOS or Device Manager, try reseating the card.
Try going into the Device Manager and making sure the Wireless Adapter is enabled. Click Start > Control Panel > System. Click the Hardware tab then click the Device Manager button. Now click the Plus [+] next to Network adapters then double-click the wireless adapter which is probably the Intel(R) PRO/Wireless 2915ABG Network Connection which will open the Properties dialog. Ensure the Device status reads, "This device is working properly" and Device usage shows "Use this device (enable)." If either the Device status or Device usage shows anything other than what is shown above, first try to change the Device usage, which should change the Device status. Now try again to use your wireless adapter. You might need to press Fn + F5 to turn the device on.
