Question about JVC MX-KA3 CD Shelf System
MX-KA3 SAYS PROTECT
WHEN I TURN IT ON IT SAYS PROTECT WE MOVED IT FROM ANOTHER ROOM AND NOW IT JUST PLAYS A CD THROUGHT HE HEADPHONES HOW DO I FIX IT
    Scholar:
  • 44 Answers
I need a little help on this one. Did it go into protect after the move or was it in protect mode before? If it went into protect after the move, did it get dropped or roughly handled? Sounds like something got knocked loose in the move. You should be able to open the unit up and check the connections. Reseat all connection whether they look loose or not. Sometimes it only takes a very small bump to get the connector acting up. After reseating all connectors, if it still does not work let us know.
Posted on Feb 09, 2008
How do i get the cd component to open
The CD open/close button is the far right button of four beside the center control. It's marked with an up arrow. http://resources.jvc.com/Resources/00/00/33/76.JPG
Jun 22, 2014 | JVC MX-KA3 CD Shelf System
Can this record cd's
Yes it can the blurb for it states: "Full-logic control, dual dubbing cassette deck with CD syncro start recording"
Mar 11, 2013 | JVC MX-KA3 CD Shelf System
Protect on display and nothing works
probably your stk output ic is faulty.....................................nacho
Jan 07, 2011 | JVC MX-KA3 CD Shelf System
Machine 'protect' msg
his appears to be a very common problem here on the board. It means the unit has shut off the outputs because of either a bad speaker or shorted wire, or some failed part in the amplifier. If the trouble continues after you disconnect the speakers, the unit will require service to diagnose and replace the failed part(s).
I've never worked on this model, but in many brands the amplifier integrated circuit is a common failure. They are often not properly mounted for efficient cooling and burn themselves out. Another typical failure is some power supply part that is under-rated and just goes bad, and this is showing up as the protect failure.
Without a diagram and no direct experience, I can't suggest any specific action you could take, other than checking with a local shop for a repair estimate. (You might try contacting JVC on their website or by phone to see if they have any service bulletins. If something becomes a chronic issue, the manufacturer sometimes extends warranty service to cover the repair. Never hurts to ask!)
Feb 12, 2009 | JVC MX-KA3 CD Shelf System
'PROTECT' MSG EVERYTIME TRYING TO OPERATE
This appears to be a very common problem here on the board. It means the unit has shut off the outputs because of either a bad speaker or shorted wire, or some failed part in the amplifier. If the trouble continues after you disconnect the speakers, the unit will require service to diagnose and replace the failed part(s).
System automatically shuts itself off after a few seconds.
I have no Idea, I have My JVC system sitting in a closet. I got it in 2004, and It was working fine, and all of a sudden it stopped and went into protect mode. I have no idea what to do about it.
But this is what I did.
I unplugged it and I let it sit for 24 hours to see if it would Reset the microprocessor, that did nuttin'. So I took it apart ^_^ That was fun! and I checked all the wires for loose connections, and I made sure te cables were in there tight. My unit is a pretty old though, I have a surround sound system, but usually a good blast of canned air may clean the circuit board and the components.
Cheers!
Mar 03, 2008 | JVC MX-KA3 CD Shelf System
Protect
You've got a fried output no doubt. Need to go to the repair shop. Good luck.
Feb 06, 2007 | JVC MX-KA3 CD Shelf System
System keeps sayin protect
The word PROTECT appears because there is a short. It can be in your speakers, try running it without the speakers plugged, or look if the wires arent shorting. If it stil ldoes that, its cause there is a short in it, from the output section. The system does that to prevent from damaging the electronic components inside.
Nov 17, 2006 | JVC MX-K30 CD Shelf System
JVC MX-KA3 CD Shelf System Logo
134 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
