Images are unclear
When I print images they are unclear because everything is printed with a shadow that is either red or pink. Even if there are words in the images and they are black they have a red shadow that makes them unclear.
  • karthika2 Feb 10, 2008
    My printer is an HP Color Laserjet 2600n. Dileep thanks for the advice, but knowing me if I did what you told me to my printer would be broken. Ok so I exchanged the printer for another one, but tell me how now I have a problem with the black ink causing images to be blurry. The weird thing is that when I print in garyscale the images are clear, but if I print normally they are unclear.
  • SeekPCRepair DotCom
    SeekPCRepair DotCom May 11, 2010
    Hello:
    A couple of quick questions to help me resolve your issue for you:
    1) LAser or DeskJet
    2) Color or black & white
    I look forward to helping you resolve this.
    Take care,
    SeekPCRepair
  • 983 Answers
If you are good at taking things apart and not destroying them, then the problem can usually be fixed easily.
Remove the ink carts.
on either side of the carrage there is a screw, remove both of them.
CAREFULLY slide out the silver bar those screws are holding. Be sure to note its orentation for putting the thing back in later.
also carefully remove the silver "fingers".
remove the black clip/cover on the right side of the carrage that covers the ribbon cables.
lift the head (you see 4 nipples in there-- that is the top of the head assembly)
gently pull out the ribbon cables.
on the bottom of the head is 2 screws, remove them
now the head will come into 4 parts. Nipples, Gasket, nozzle block, and a metal guard.
get some windex with amonia.
soak the parts for a day or 2.
blot dry, then let it set for atleast 2 days to be sure it is COMPLETELY dry.
reassemble, charge the ink, do the printers head cleaning, and boom. back in business.
this works 90% of the time
Posted on Feb 09, 2008
MY CANNON PRINTER IP3600 IS PRINTING RED IMAGES IN PINK
go to Edit > Color Settings, how is Photoshop Elements currently set? The first thing I would do is try setting it to "No color management" and see if you get better results. If this works for you, you're in luck, because color management gets tricky.In settings "No color management" does not produce acceptable results, you will have to start reading up on color management and color calibrating your devices, particularly your printer. You might want to also read Photoshop Elements Help topic "To print using color management."Most graphics software has setting for color management, but personally, I have always gotten the best results by simply turning color management off. Color management is primarily intended for people in a pre-press environment. Not everyone needs it. If you're not doing professional printing, first try working without color management before you assume you need it.
Apr 26, 2012 | Canon Pixma iP3600 InkJet Photo Printer
Text prints fine. However images are printed smeared. It looks like each image has a mirrored shadow. How can I fix this?
Fist set for default settings, calibrate color.. it will resolve the issue ..even its remin service involment must..
Sep 11, 2011 | HP Color LaserJet 2600n Printer
After changing the ink catridges and resetting the drum fuse lately (note: it is known that the fuse will be blown off after certain number of prints but otherwise is in good condition), my Epson Acculaser...
The repeating image is a ghost image, and here is described what it can be. Probably if you solve this, you also solve the red-dot problem. If possible, I would suggest to replace the wiper blade.
Repeating images on laser printerThis likely means a faint ghost of the main printout at a distance equal to the circumference of one of the rollers or photosensitive drum.
Depending on where the problem originates, this could be a bad wiper (cleaning) blade, faulty corona, or incomplete fusing.
  • If the distance between successive images is equal to the circumference of the photosensitive drum, it is a wiper blade, erase lamp, or corona problem.A residual latent image or residual toner is sticking to the drum and not being properly cleared.
  • If the distance between successive images is equal to the circumference of one of the fuser rollers, then the fusing may not be complete due to damaged rollers or an incorrect temperature setting.
It is easy to determine where the problem is located: Interrupt a printout in mid-stride (where part of the paper is between the toner/developer and fuser. If the un-fused image has ghosting, it is a fault in the area of the drum
Jul 08, 2011 | Office Equipment & Supplies
What do I do when my CLX 3160 FN Printing shadow images.
clean the nozzles first. if you are using refilled ink then most probably its time to replace the entire cartridge since refilled ink is filled up on the old cartridge & in due time the nozzle becomes wider with use leading to shadow images being printed.
Jun 16, 2011 | Computers & Internet
I bought new ink black and color but i try to print in pink and i can't how can i print in pink
Hi alexgallo01
Do you get other colours except pink?
If that is the case,reasons could be:
1. there is not enough RED or BLUE in the cartridge.
2. you haven't selected pink colour on the text or images you are trying to print.
If you are typing a document highlight the text you want in pink, and choose PINK color for the font.
Then print the document. The printer will use color closest to your choice, if it does not have the exact color.
Hope this will help.
If it help you, please give a rating
Cheers
luciana44
Sep 14, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Sharp AR 5320 printing a shadow copy
Shadow images may caused by several things :
1. Deformed rubber of the cleaning blade,
2. Drum aging,
3. Upper heater roller aging.
Jun 22, 2009 | Sharp Office Equipment & Supplies
HELP!!
First off, I'm not too sure if that Printer is a color printer. Its a color scanner yes, but i don't think is a Color Laser Printer! Secondly, can you explain in more detail what kind of scanning and printing issues you have witht the printer? Prints unclear as in blurry or too light? are u having trouble installing the scanner or is it not scanning the images correctly? regards babb
May 02, 2007 | Samsung SCX 4521F All-In-One Laser Printer
312 people viewed this question
jasbo
jasbo
