DC Power supply specifications
I have a Zonet ZFS3008N 8 port Ethernet hub which requires a
dc adapter to connect it to 110 volts. The device itself gives no clue as to how many dc volts the adapter has to be or the polarity of the tip. Could you please give me this information so I can network my computers? My E-Mail address is TURK08@q.com This information would be greatly appreciated.. I've been looking for a couple of hours with no results!
Thanx
Joseph
  • Anonymous Jun 27, 2008
    what is the polarity
  • 84 Answers
Here is the info you need...
Input Power 100~240V, 50~60Hz
9V DC,1A Max
Hope this helps...
Posted on Feb 09, 2008
Internal transformer is:
DVE
Switching power Supply
Model: DSO-15W-05
Input: 100-240V - 0.4A 50-60Hz
Output: +5V === 3A
Posted on Feb 03, 2009
  • gregoryE Feb 03, 2009
    If anyone can figure out where to get a replacement for the internal power supply for this router, I'd love to get a link. I'm having trouble finding the exact item and I'm not necessarily savvy enough to figure out a non-exact replacement.
  • Fireeye190
    Fireeye190 Feb 24, 2012
    link?
I have hub4 friend giving me hub 5 so I just change it over and that all I do
Should be just a changeover the hub is not very intelligent so there should not be too much issue. Speed of hub ports ? 10/100/1000 Mb/s
hubs basically repeat the network packets to all ports .
what feeds into the hub what speed is it at and what speeds does the hub support is the only issue you may have. Assuming you have ethernet hubs.
MUST use 5 hubs power supply AC to DC adapter with the 5 hub device.
do not just pull power plug out of 4 hub and put it in 5 hub device unless you know they are compatible with same DC voltage and current rating it is much simpler not to mix them up.
Sep 13, 2016 | Computers & Internet
How many volts is the power adapter
The speakers use a 10 Watt power supply
Sep 06, 2011 | Sony SRS-A37 Computer Speakers
THERE IS A LONG TIME AGO SINCE I DONT WORK WITH MY MICROTEST PENTASCANNER AND I DO NOT KNOW IF THE AC ADAPTER HAS AN OUPUT OF 9.VOLTS I AMP AC OR 9 VOLTS 1AMP DC PLEASE TELL ME WHICH IS THE RIGHT AC...
An AC adapter should output DC. The device should say next to the power plug what voltage input it requires. Also, check the AC adapter, it may say something like "Input 110-120VAC Output 9VDC".
Apr 26, 2011 | Microtest PentaScanner 350 (8180-00R)...
Yesterday I bought an STP-120 SIMA power inverter
you inverter was not fully charged because it requires a 110/220 v ac as specified in the manual; to charge it so it is impossible for the aircraft 15vdc to charge it
Jan 27, 2010 | APC DC to AC power inverter ( external ) -...
I replaced the USB adapter chord and know there's not enough power to run the drive. I think I need a DC adapter, 5V, 1A, that fits the drive.
If you get an error message "Insufficient power to operate USB device" when you plug in a USB device into the computer's USB port then this device is drawing power that the USB port can supply.
In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Dec 06, 2009 | SimpleTech SimpleDrive Portable USB 2.0...
Power supply for Targus 4 hub usb 2
Most USB hubs do not need an external power supply, except when a connected USB device draws more power than the computer/laptop USB port can supply. In this case an external power supply will need to be connected to the USB hub.
Normally this would be a 5 volt power supply, but make sure the polarity on the connector matches the power connector on the hub, check the label on the hub, sometimes it states to power requirements of the hub as well as the polarity on the connector. Normally the pin on the hub's power connector is positive (ie. +5V)
Nov 13, 2008 | Targus PAUH217U 4-Port USB Hub
Dell power supply ADP-220AB B output schematic
It may be possible that your adapter does not receive the rated power it should receive. You may have plugged your adapter to a 110 v outlet when the required input is 220 volts. See your adapter for the specific requirements.
Oct 26, 2008 | Computers & Internet
DC power adapter
The adapter for the DE-805TP supplies 9 volts dc at around .5 amps
Jan 13, 2008 | D-Link DE 805TP (DE-805TP)5x10 Mbps...
Computers & Internet Logo
1,474 people viewed this question
Alun Cox
David Payne
David Payne
