Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Fan is Noice now
I had this tv for all most 5 year now a days fan is making too much nocie it's runs all the time when tv is on it seems like it's speed is osilating when it runs in high speed it make nice like it runs under load any help or it is easy to change fan??
  • 579 Answers
Fans are easy to change and are a standard low cost part.
partstore.com
andrewselectronics.com
Posted on Feb 09, 2008
My Lennox ac is making a very loud buzzing sound and the fan blades are not turning. We replaced the dual capacitor and that seemed to fix the problem for a couple of days, now it's doing the same...
Fan motor is probably bad, if it is under 5 years old the parts are under warranty. Do not run the unit for very long without the fan working as it can damage the compressor.
Aug 23, 2011 | Heating & Cooling
Making loud gurgling sounds only when door is closed. Have called for service but 5 days away and this is constant
the loud noise come from the fan in the back of your freezer unit , but if you not expert i wouldent open the unit b/c Fisher and Pyk are very sensative units and if you do something wrong or put something wrong they wont work.
the noice is the fan that might be bad or tuch something like ice...
hop it will help you
Jan 08, 2010 | Fisher and Paykel Active Smart E522B...
Our Amanda refrigerator/freezer has been making noises on and off (buzzing) over the past two months, in particular the bottom freezer. Today everything started to melt and the buzzing is frequent every...
It sounds like your evaporator fan motor, they last about 4-5 years. Try to see if the buzzing noise comes from the motor, usually in the freezer compartment behind a vented cover plate
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). It could be that your drain hose is clogged or frozen. Maybe the temperature adjuster go bumped.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | Amana ABB1927DE Bottom Freezer...
Charger makes loud whining noice
they have a cpu fan in it, and unlucky for you you cant buy anthother part, you either get a new one, or try sparaying some WD-40
May 02, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Lazer 73: blower making a lot of noice
G M,
Your stove does need to be overhauled. The vibrations are the blower exhaust wheel being out of balance due to carbon build up. If it has been vibrating for a long time you will need to replace the motor. The L73 motor bearings are hard to get off without either bending the shaft or breaking the rev sensor. The burner pot will be another part that may need changing. It may have a warped or cracked bottom. If this is so it needs to be replaced with a new one. The burner ring will have to be replaced as will the mat. Several gaskets will need to be on hand in case you break them. All toll the above will run around $400 or so. It's well worth it considering a new one is $1750 or so. The first thing you need; though, is a service manual. Get in touch with your local dealer and get one. It will make your repair much easier.
Tom Hawkins
hawkins111@gci.net
Feb 26, 2009 | Rinnai Toyostove Direct Vent Heater:...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
