Question about Baby Gear
1988 honda accord
88 accord running rich how do i adjust it?
  • 50 Answers
If its an injection model there is a large air mix screw on the air flow side just screw it out if its a carb theres a small mix adjuster with a metal cover over it also screw that in hope this helps
Posted on Feb 09, 2008
  • 3 Answers
Probably a problem with the automatic choke not opening fully. May need a new one.
Can a non-certified Honda mechanic install a carburetor on a 88 Honda Accord 5 speed?
hi yes no problem, and to be honest its an old car so it wont effect the warranty of the vehicle, hope that helps
Dec 15, 2010 | 1988 Honda Accord 4 Door
88 Honda Accord revs when turn on the A/C
most have idle up solonoid to raise any rpm lost by compressor.. if still too high when compressor is engaged then that may be problem... is adjustable
Mar 31, 2010 | 1988 Honda Accord 4 Door
Can not get JUICE to fuel pump replaced pump & relay will run if i put gas in CARB?88 honda accord
Did you check #1 fuse 15 amp to see if it were blown? This fuse also controls the fuel pump. This Test procedure is from Mitchell Repair.
moz-screenshot-1.png9769a1b.jpg v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0
Nov 25, 2009 | 1988 Honda Accord 4 Door
1988 5 speed Honda Accord
Ensure your spark plugs,wires (ignition coil and spark) and your filters (air and fuel) are within 2 years of installation It's erratic at 800 rpm as the engine is cold and they like the 2200 range for 3 minutes before they kick down on their own. Press the pedal twice before inserting your key. The owners manual states depending on the outside temperature, the engine will require more priming. Update if possible.
Oct 25, 2009 | 1988 Honda Accord 4 Door
Car stalls when i stop
it sounds like a low idle either caused by poor adjustment or a dirty throttle body. clean the carbon out of the throttle body. if that does not work bring the revs up with the idle screw
Apr 06, 2009 | 1988 Honda Accord 4 Door
I have a 88 honda accord with carb that i cant get to idle down
Should be an idle adjusting screw on the side of the carburator that you can adjust to move your idle down.
-Captain Jake
Feb 13, 2009 | 1988 Honda Accord 4 Door
Lots of engine oil in air filter
Do you have good vacuum at the PCV valve? Remove your spark plugs and run a compression test. Sounds like you have a lot of blow by. Combustion gases blowing by the piston rings.
Dec 29, 2008 | 1988 Honda Accord 4 Door
1988 HONDA ACCORD BLOWER WONT WORK
i just had the same problem on my 88 honda accord lx had to replace ignition switch
Dec 25, 2008 | 1988 Honda Accord 4 Door
1988 Accord hard starting
possibility your distributer is on its way out...the cam sensor in it gets hot and isnt sending the correct info...same with the coil ...cech for spark and fuel on next hard start
Oct 01, 2008 | 1988 Honda Accord 4 Door
Baby Gear Logo
71 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
