Question about Hitachi 43F300 43" Rear Projection Television
My tv has a green shadow behind everything on it
I have a Hitachi 43F300 that worked great for a few years but suddenly the illignment is off so everything is purple with a green shadow... how do i fix this? I'm great with electronics and I've been told that if i take out the green bulb and shake the hell out of it that would probably fix it. is this true?
  • 934 Answers
Tim,
Gee I'm pretty good with electronics and I've never heard that joke!
What you have there is a convergence problem. Your unit takes two STK392-110 Ic's at position numbers IK04 and IK05 respectively. Also check and replace as necessary Rk50 (2.7ohm /1w), Rk62 (2.2ohm /1w), Rk63 (150ohm /2w), Rk46 (1.8ohm /1w), Rk42 (3.3ohm /1w) And Rk43 (220 ohm 2w). In fact test all of the 2.2ohm resistors in the yoke return just out in front of the amps for change in value.
Also make sure to use Sanyo original Ics and not some asian knock-offs which are readily out there.. Get them from Acme in Florida http://www.acme-sales.net/index.shtml and rest assured you're getting Sanyo originals..
Bill
Posted on Feb 09, 2008
Hitachi 43F300 TV no audio or video probs
Could you have bumped the wrong button on the remote? Make sure the TV's input is set to where the DVD is connected.
murf427
Aug 04, 2012 | Hitachi 43F300 43" Rear Projection...
Color shadowing on screen
I had similar symptoms about a year ago. Also came on sudden. The red convergence chip had burned out (poor heat sinking on this model Hitachi). Replacing the color convergence chips fixed it. ($50 for parts.) First, however, have you tried the "magic focus" function? That's explained in the manual, which is available online IIRC, but I'd have to look for the link if you need it.
Mar 02, 2010 | Hitachi 53UDX10B 53" Rear Projection...
No color only black and white picture
one of your color tube has gone out on you.
Jan 25, 2009 | Hitachi 43F300 43" Rear Projection...
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
43F300 convergence
Convergence kit # X480306 for your Model #.....
Replace parts & activate auto-focus......T.
Sep 01, 2008 | Hitachi 43F300 43" Rear Projection...
Hitachi Projection tv
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 17, 2008 | Hitachi 43F300 43" Rear Projection...
Problem in Hitachi 43" tv
Common failure called convergence mis-alignment.Needs
convergence IC's replaced by skilled technician.Good set
to keep going a few more years.............T.
Please rate this solution...................
Nov 15, 2007 | Hitachi 43FDX01B TV
Wavy lines
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 10, 2007 | Hitachi 53SWX10B 53" Rear Projection...
(Hitachi 43F300) Turning its self off
Sounds like it is going into shutdown mode. When the TV power supply and system control sense an overload the system control turns the TV off to prevent further damage from happening. I suspect it is a shorted convergence IC. It would be best to call a service center to repair the TV.
May 18, 2007 | Hitachi 43F300 43" Rear Projection...
Hitachi 43F300 43" Rear Projection Television Logo
202 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
